Home » Newcomers » Newcomers » Hide jars from Project Explorer
Hide jars from Project Explorer [message #259361] Fri, 27 June 2008 04:05 Go to next message
Originally posted by: ihatespammers.nospam.com
I have the following project:
http://www.jtict.com/temp/project_explorer.jpg
As you can see, there is a huge list jars files that is cluttering the
"Project Explorer" view.
How can I filter out these jar files from the view?
Re: Hide jars from Project Explorer [message #259372 is a reply to message #259361] Fri, 27 June 2008 06:37 Go to previous messageGo to next message
Originally posted by: groups.pellaton.li
You can hide all jars in pkg explorer:
- In the Package Explorer, open the view menu and select "Filters... "
- unselect "Libraries from external"
- unselect "Libraries in project"
- hit [ OK ]
HTH
Michael
Re: Hide jars from Project Explorer [message #259412 is a reply to message #259361] Fri, 27 June 2008 10:09 Go to previous messageGo to next message
In addition to the advice Michael already provided, I'll suggest that
you look at the Java Browsing perspective. I find it much more efficient
to use for navigating Java projects than Project Explorer, especially
when I attach a Navigator view as a Fast View for quick access to
non-Java files in the projects.
Hope this helps,
Eric
Re: Hide jars from Project Explorer [message #259450 is a reply to message #259361] Fri, 27 June 2008 15:38 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
And there's Mylyn if you want contextual filtering (ie., filter out
everything until it's marked "important" by virtue of your selecting or
opening a file).
If you're using Eclipse 3.4, you can get Mylyn 3 via its update site or
the Ganymede update site. If you're using Eclipse 3.3, you can get Mylyn
2.3 from the Europa update site or Mylyn's site.
http://www.eclipse.org/mylyn/ for more info.
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: Hide jars from Project Explorer [message #259526 is a reply to message #259372] Sun, 29 June 2008 11:37 Go to previous messageGo to next message
> - hit [ OK ]
> HTH
> Michael
Thanks for your reply. I was looking to hide the jars in the "Project
Explorer" and not from the "Package Explorer". (The Project Explorer is
the default view for the Java EE perspective.)
Re: Hide jars from Project Explorer [message #259530 is a reply to message #259361] Sun, 29 June 2008 11:40 Go to previous messageGo to next message
I see that the jars aren't visible in the project root of the Project
Explorer when starting a dynamic web project. The project of the picture
was generated by JBoss Seam-gen, so that might be the problem of all the
jars being visible in the Project Explorer.
Re: Hide jars from Project Explorer [message #506706 is a reply to message #259526] Fri, 08 January 2010 16:47 Go to previous messageGo to next message
click on menu on upper right of package explorer -> Customize View -> Content tab -> uncheck "Java Elements"
d-u-n DONE
(i hope)
Re: Hide jars from Project Explorer [message #718880 is a reply to message #506706] Thu, 25 August 2011 10:39 Go to previous message
Unchecking "Java Elements" also removes the packages. Is there a way to only remove the *.jar files and still keep the packages. Seems to work like a breeze in the package explorer.
Previous Topic:Trying to Install Eclipse
Next Topic:Boot Eclipse from another hard drive
Current Time: Wed Nov 26 00:23:07 EST 2025
Powered by FUDForum. Page generated in 0.09233 seconds
