| Export Report in webviewer [message #259343] |
Wed, 24 October 2007 14:32  |
Originally posted by: Carole.Hargrave.sybase.com
I'm using 2.2.1, with the viewer integrated in my webapp - and I'm using
the taglib to display the report.
When I select the Export Report button, and select XLS, the document type
is not appearing on the download dialog (from IE), and if I select Open,
the opened file is XML. If I select Save, it does save the file properly
as xls.
We are running Excel 2002 sp3.
The other issue I have is if I select export data and then Open, I get the
download dialog again.
Any suggestions would be appreciated.
Carole
| Re: Export Report in webviewer [message #259490 is a reply to message #259343] |
Thu, 25 October 2007 10:53  |
Carole,
I believe this format is for excel 2003. You may want to open a
bugzilla entry on this.
Jason
> type is not appearing on the download dialog (from IE), and if I select
> Open, the opened file is XML. If I select Save, it does save the file
> properly as xls.
> the download dialog again.
> Thanks
> Carole
FUDForum. Page generated in 0.04342 seconds
