| Annotation processing (in Java 1.6 flavour) [message #259338] |
Sun, 05 April 2009 11:18  |
I wrote a simple annotation processor catching some annotations on methods
and constructors. Apparently I can not access parameters because the
method getParameters() of ExecutableElement always return a void list.
It is because this functionality is not yet implemented or it is an error?
Federico
| Re: Annotation processing (in Java 1.6 flavour) [message #259421 is a reply to message #259342] |
Tue, 07 April 2009 14:32   |
Walter Harley wrote:
> "Federico Tomassetti" <f.tomassetti@gmail.com> wrote in message
> news:0ffbd510f9569b38f76e0fe44a3a7ded$1@www.eclipse.org...
>>and constructors. Apparently I can not access parameters because the method
> There have been some bugs fixed recently regarding annotations on
> parameters. What version of Eclipse are you using? Can you try Eclipse
> 3.4.2, and/or Eclipse 3.5 M5, and see if the problem still exists?
First of all thank you for you reply.
Under Eclipse 3.4.0 I used this code:
@SupportedAnnotationTypes("it.tomassetti.NotNullParams") // Process all
annotations
@SupportedSourceVersion(RELEASE_6)
public class CommonAnnoProcessor extends AbstractProcessor {
public boolean process(Set<? extends TypeElement> annotations,
RoundEnvironment roundEnv) {
for (Element e :
roundEnv.getElementsAnnotatedWith(NotNullParams.class)){
if (e instanceof ExecutableElement){
ExecutableElement ee = (ExecutableElement)e;
String s =
"name="+ee.getSimpleName()+",n_params="+ee.getParameters().size();
this.processingEnv.getMessager().printMessage(Kind.OTHER, "Annotated
"+s, e);
} else {
this.processingEnv.getMessager().printMessage(Kind.ERROR, "Not
executable element", e);
return true;
package it.tomassetti;
import it.tomassetti.NotNullParams;
public class TestA {
@NotNullParams("")
public void a(){
@NotNullParams("")
public void b(){
@NotNullParams("")
public void c(int a){
@NotNullParams("")
public void d(String a, String b){
In the editor I can see a note on all of my methods (a,b,c,d) and all of
theese notes reports that the number of parameters is zero.
I am going to test it under Eclipse 3.4.2 and look if it behaves
differently.
Federico Tomassetti
| Re: Annotation processing (in Java 1.6 flavour) [message #259425 is a reply to message #259421] |
Tue, 07 April 2009 14:48   |
> annotations
> @Override
> for (Element e :
> String s =
> "+s, e);
> } else {
> return true;
> @NotNullParams("")
> public void a(){
> @NotNullParams("")
> public void b(){
> @NotNullParams("")
> @NotNullParams("")
> differently.
> Federico Tomassetti
Under Eclipse 3.4.2 the correct number of params is recognized.
Federico Tomassetti
FUDForum. Page generated in 0.04513 seconds
