Home » Modeling » GMF (Graphical Modeling Framework) » GEF to GMF
GEF to GMF [message #25623] Tue, 22 August 2006 09:40 Go to next message
I have a GEF based workflow editor. Is it possible to create a GMF based
editor using the core models, edit-parts and edit-part factory from GEF?
Basically, I would like to retain the granular customizations done in the
GEF controllers. The customizations include representing a tree-model on an
XY layout, allow drop only onto a certain edit-part on the viewer etc.
Re: GEF to GMF [message #26204 is a reply to message #25623] Tue, 22 August 2006 12:35 Go to previous messageGo to next message
Any help here would really be appreciated. Even if there is no way to do
this, it would be helpful to know which GMF classes should be customized to
handle my GEF customizations. Thanks alot - Barry
"Barry Dresdner" <barry.dresdner@softwareagusa.com> wrote in message
news:ecf1g1$pe$1@utils.eclipse.org...
Re: GEF to GMF [message #27275 is a reply to message #26204] Wed, 23 August 2006 10:36 Go to previous message
Originally posted by: ravikanth.pramati.com
It would be convenient to complete the graph model, and mapping model, and
then customize the generated editparts and editpolicies rather than change
the names and options in the genmodel before generating the diagram editor
code!
You'll notice there are a lot more features inherent with GMF that would
enhance your editor. As GMF wraps the GEF editparts and editpolicies, the
customizations could be traced similarly to how you did so for your GEF
editor. For a better understanding download the source code, so that you're
aware of the abstraction
Ravi
news:ecfbp4$fop$1@utils.eclipse.org...
> to handle my GEF customizations. Thanks alot - Barry
>>an XY layout, allow drop only onto a certain edit-part on the viewer etc.
Previous Topic:Problem in extracting emf validation example
Next Topic:Null pointer errors in mindmap created using cheat sheet
Current Time: Thu Nov 20 11:58:34 EST 2025
Powered by FUDForum. Page generated in 0.03190 seconds
