Home » Newcomers » Newcomers » Installation problem on Windows XP
Installation problem on Windows XP [message #259303] Thu, 26 June 2008 08:52 Go to next message
Originally posted by: 4cs6fcg02.sneakemail.com
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enigE4FF0F4DA0C8583F027935F9
Content-Type: text/plain; charset=UTF-8; format=flowed
As promised, another post describing my problems on Windows.
I installed a fresh Windows XP. Did all the updates, to SP3 etc.=20
Installed quite a lot of additional software (OpenOffice, Firefox,=20
MingW, Putty, =E2=80=A6)
Downloaded Ganymede. Ran it, installed some extra packages (CDT, JDT,=20
WST, Subclipse, Texlipse, Dutch language pack). Everything fine.=20
Checked out some of my projects from svn, did some configuruing.
I then edited my user privileges, making myself non-privileged user. (I=20
suppose this is irrelevant, but you never know.)
Restarted WinXP once more to get install yet another update. After=20
restart, whenever I try to open Eclipse, I see the splash screen flash=20
by, and that=E2=80=99s it. Tried several different ways of starting it, =
no effect.
Installed it in a new location, downloaded another package, even=20
downloaded a 3.3.1 build, all the same: short flash of the splash=20
screen, then nothing.
I am out of ideas what I could do now. I am at the point of erasing the =
whole Windows installation and starting it all again, this time waiting=20
meticulously until all updates are finished before installing another=20
program or anything.
Any ideas?
Where does Eclipse store the information which workspace to use by=20
default? I have this slight impression the projects in the workspace=20
are the culprit.
Cheers, H.
--=20
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.9 (GNU/Linux)
Comment: Using GnuPG with SUSE - http://enigmail.mozdev.org
iEYEARECAAYFAkhjkRMACgkQe+7xMGD3itT9qwCeLc+BjT8b0SO1XcAQcIak qhm4
YdcAn3xMZDimhT/kqqxR2GuhgBkYTsSf
=lCSF
-----END PGP SIGNATURE-----
--------------enigE4FF0F4DA0C8583F027935F9--
Re: Installation problem on Windows XP [message #259315 is a reply to message #259303] Thu, 26 June 2008 11:43 Go to previous messageGo to next message
Originally posted by: groups.pellaton.li
What you are doing is a so called "multi-user installation":
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/reference/misc/multi_user_installs.html
Some time ago I had similar issues under Linux and the solution
was quite simple:
- Make sure the entire eclipse installation is not writable by users
- Eclipse must never be run by any user having write access to it's
installation directory (will spoil the configuration subdirectory).
HTH
Michael
Re: Installation problem on Windows XP [message #259324 is a reply to message #259303] Thu, 26 June 2008 12:52 Go to previous messageGo to next message
Just wondering why you would make yourself a non-privileged user. Many
program require the user to have admin rights. I don't know if Eclipse
is such a program, but you might want to give that a try.
Paul
> MingW, Putty, …)
> by, and that’s it. Tried several different ways of starting it, no effect.
> Any ideas?
> are the culprit.
> Cheers, H.
Re: Installation problem on Windows XP [message #259404 is a reply to message #259324] Fri, 27 June 2008 10:02 Go to previous messageGo to next message
--------------enig8F5B14407353657F0A8A5776
Paul Levin schreef:
> Just wondering why you would make yourself a non-privileged user. =20
To make up for the non-security Windows offers (you might notice that I=20
am by now a convinced Linux user).
> Many=20
> program require the user to have admin rights. I don't know if Eclipse=
=20
I did, no luck.
Other ideas?
Cheers, H.
--=20
Hendrik Maryns
http://aouw.org
iEYEARECAAYFAkhk8t8ACgkQe+7xMGD3itSaOQCfZQpJIEpDboFsOkWlNE3q fUiT
X0cAnRFb/lFsh+e+j39sSULDabmnVaZw
=tnkd
--------------enig8F5B14407353657F0A8A5776--
Re: Installation problem on Windows XP [message #259408 is a reply to message #259315] Fri, 27 June 2008 10:03 Go to previous messageGo to next message
--------------enig5361ECFCF1481031BB63963A
Michael Pellaton schreef:
> Hi
>=20
> http://help.eclipse.org/ganymede/index.jsp?topic=3D/org.ecli pse.platfor=
That site wasn=E2=80=99t very helpful. Well, yes, I now know what the=20
configuration directory is for, but the problem persists.
> was quite simple:
Hm, how to do this on Windows?
> - Eclipse must never be run by any user having write access to its
On my Linux system, I install plugins by running Eclipse as root, then I =
get them myself as well. So at least the privileged user can get access =
there.
H.
--=20
Hendrik Maryns
http://aouw.org
iEYEARECAAYFAkhk80gACgkQe+7xMGD3itQJ4wCfWZb8UsMhn8TTXv8t6v7Q 1loZ
360An1DX/juChU35pNQp1pV3jNr8AH50
=Umnl
--------------enig5361ECFCF1481031BB63963A--
Re: [solved?] Installation problem on Windows XP [message #259415 is a reply to message #259408] Fri, 27 June 2008 10:30 Go to previous messageGo to next message
--------------enig950702EAD592C42F1A4342D2
I think I have found it. There was something wrong with the Java.=20
After reinstalling Java and Eclipse, things seem to be working now.
I still have myself as non-privileged user, only an admin-account to do=20
program installation.
>> http://help.eclipse.org/ganymede/index.jsp?topic=3D/org.ecli pse.platfo=
rm.doc.isv/reference/misc/multi_user_installs.html=20
>=20
> That site wasn=E2=80=99t very helpful. Well, yes, I now know what the =
>> was quite simple:
>=20
Let=E2=80=99s see if it suffices to put Eclipse in c:/Program Files (actu=
ally,=20
c:/Programme on my German Windows) and make all other users non-privilege=
d.
>=20
> On my Linux system, I install plugins by running Eclipse as root, then =
I=20
> get them myself as well. So at least the privileged user can get acces=
s=20
> there.
Thanks again, H.
--=20
Hendrik Maryns
http://aouw.org
iEYEARECAAYFAkhk+YkACgkQe+7xMGD3itRDFwCdEpwRF6Ee/7dTeDrTgd/W 579H
u54An1FtodDliMwod9QIC/omTQy907Lj
=VWqw
--------------enig950702EAD592C42F1A4342D2--
Re: Installation problem on Windows XP [message #259733 is a reply to message #259404] Tue, 01 July 2008 11:17 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Your launch configuration includes a reference to a file in your project.
Since the absolute location of the file contains a space, this is what is
causing the problem. You need to enclose the library path reference in
quotes. Try adding this to the VM Arguments section of your launch config
(notice the quotes):
-Djava.library.path="${resource_loc:/MonaSearch/libraries}"
or
"-Djava.library.path=${resource_loc:/MonaSearchlibraries}"
BTW, all of your posts show up in my news reader as attachments. That is
why I didn't quote your entire message.
From your launch configuration:
<stringAttribute key="org.eclipse.jdt.launching.VM_ARGUMENTS"
value="-Djava.library.path=${resource_loc:/MonaSearch/libraries} "/>
"Hendrik Maryns" <4cs6fcg02@sneakemail.com> wrote in message
news:g42rsv$ov5$1@build.eclipse.org...
Re: Installation problem on Windows XP [message #259770 is a reply to message #259733] Wed, 02 July 2008 08:24 Go to previous message
> or
Thanks you very much. This was indeed the problem.
In the mean time, I also found out how to compile my JNI with MinGW, and
everything is working now. JAY!!
I really have to write all this stuff down somewhere.
Cheers, H.
Hendrik Maryns
http://aouw.org
Previous Topic:Error Log
Next Topic:GUI
Current Time: Sat Nov 08 12:30:18 EST 2025
Powered by FUDForum. Page generated in 0.10564 seconds
