Home » Archived » BIRT » Runtime Hangs with frameset
Runtime Hangs with frameset [message #259294] Wed, 24 October 2007 11:02 Go to next message
I have deployed the BIRT 2.2.1 runtime in a WebSphere 5.1 environment
using the instructions contained here:
http://wiki.eclipse.org/index.php/Birt_WebSphere_Deployment
I can get http://devweb/Reporting/run?__report=test.rptdesign to work but
the frameset URL does not
(http://devweb/Reporting/framesert?__report=test.rptdesign). It is
looking like it hangs.
In Internet Explorer, the screen is blank, but if I do a View Source I can
see some html, but not the complete report. In Firefox, the buttons at
the top are rendered but the progress bar never completes.
There are no immediate errors in the logs, but I eventually get errors in
the SystemOut log like this:
[10/24/07 10:57:17:328 EDT] 277dabc0 WebAppInvoker E Unexpected internal
engine error while processing request: java.lang.NullPointerException
com.ibm.ws.webcontainer.srt.WebAppInvoker.getFullURI(WebAppI nvoker.java:410)
com.ibm.ws.webcontainer.srt.WebAppInvoker.doForward(WebAppIn voker.java:208)
com.ibm.ws.webcontainer.srt.WebAppInvoker.handleInvocationHo ok(WebAppInvoker.java:321)
com.ibm.ws.webcontainer.cache.invocation.CachedInvocation.ha ndleInvocation(CachedInvocation.java:71)
com.ibm.ws.webcontainer.srp.ServletRequestProcessor.dispatch ByURI(ServletRequestProcessor.java:246)
com.ibm.ws.webcontainer.oselistener.OSEListenerDispatcher.se rvice(OSEListener.java:334)
com.ibm.ws.webcontainer.http.HttpConnection.handleRequest(Ht tpConnection.java:56)
com.ibm.ws.http.HttpConnection.readAndHandleRequest(HttpConn ection.java:652)
at com.ibm.ws.http.HttpConnection.run(HttpConnection.java:448)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java(Compil ed Code))
[10/24/07 10:57:17:340 EDT] 277dabc0 ThreadMonitor W WSVR0606W: Thread
"Servlet.Engine.Transports : 6" (277dabc0) was previously reported to be
hung but has completed. It was active for approximately 3,103,988
milliseconds. There are 2 threads in total in the server that still may
be hung.
Here is the report log:
Oct 24, 2007 10:10:53 AM
org.eclipse.birt.report.engine.api.impl.ReportEngine <init>
FINE: ReportEngine created. EngineConfig: EngineConfig:
PLATFORM_CONTEXT=org.eclipse.birt.core.framework.PlatformServletContext@34b8abc3 ;webapplication.projectclasspath=;logLevel=FINE;org.eclipse. birt.report.engine.api.EngineConfig.emitterConfigs={html=org.eclipse.birt.report.engine.api.HTMLRenderOption@5ee7ebc0 };BIRT_HOME=;logDest=/usr/WebSphere51/AppServer/installedApp s/webdevNetwork/birt51.ear/birt.war/logs;
org.eclipse.birt.report.engine.extension.internal.ExtensionM anager
loadGenerationExtensionDefns
FINE: Start load extension point:
org.eclipse.birt.report.engine.reportitemGeneration
FINE: Load generation extension: Crosstab
loadPresentationExtensionDefns
org.eclipse.birt.report.engine.reportitemPresentation
loadQueryExtensionDefns
org.eclipse.birt.report.engine.reportitemQuery
FINE: Load query extension: Crosstab
loadEmitterExtensionDefns
FINE: Start load extension point: org.eclipse.birt.report.engine.emitters
FINE: Load html emitter org.eclipse.birt.report.engine.emitter.html
FINE: Load pdf emitter org.eclipse.birt.report.engine.emitter.pdf
FINE: Load postscript emitter
org.eclipse.birt.report.engine.emitter.postscript
FINE: Load ppt emitter org.eclipse.birt.report.engine.emitter.ppt
FINE: Load doc emitter org.eclipse.birt.report.engine.emitter.word
Oct 24, 2007 10:29:19 AM
org.eclipse.birt.report.engine.api.impl.ReportEngine openReportDocument
FINE: ReportEngine.openReportDocument:
systemId=/usr/WebSphere51/AppServer/installedApps/webdevNetw ork/birt51.ear/birt.war/test.rptdesign,
file=/usr/WebSphere51/AppServer/installedApps/webdevNetwork/ birt51.ear/birt.war/documents/WE5O26KxqbjHG700Ibn4Rlq/6ec9e2 3c/test.rptdocument,
options={semanticCheck=false,
resourceFolder=/usr/WebSphere51/AppServer/installedApps/webd evNetwork/birt51.ear/birt.war}
org.eclipse.birt.report.engine.api.impl.ReportEngine openReportDesign
FINE: ReportEngine.openReportDesign:
name=file:/usr/WebSphere51/AppServer/installedApps/webdevNet work/birt51.ear/birt.war/test.rptdesign,
designStream=java.io.FileInputStream@720cabd8, options={3}
Oct 24, 2007 10:29:21 AM
org.eclipse.birt.report.model.metadata.ChoicePropertyType validateXml
FINE: return internal name for choice eq
Oct 24, 2007 10:29:22 AM
FINE: return internal name for choice asc
FINE: return internal name for choice DataSet
FINE: return internal name for choice hide
FINE: return internal name for choice any
FINE: return internal name for choice if-realized
FINE: return internal name for choice auto
FINE: return internal name for choice hyperlink
FINE: return internal name for choice inner
FINE: return internal name for choice auto layout
FINE: return internal name for choice NoChange
FINE: return internal name for choice string
FINE: return internal name for choice static
FINE: return internal name for choice simple
FINE: return internal name for choice single
FINE: return internal name for choice normal
FINE: return internal name for choice none
FINE: return internal name for choice scroll
org.eclipse.birt.report.model.metadata.DimensionPropertyType validateXml
FINE: return dimension value with user defined unit 0%
FINE: return internal name for choice repeat
FINE: return dimension value with user defined unit 0em
FINE: return internal name for choice block
FINE: return dimension value with user defined unit 0pt
FINE: return dimension value with user defined unit 1pt
FINE: return dimension value with user defined unit 1in
FINE: return dimension value with user defined unit 1.25in
FINE: return dimension value with user defined unit 0.5pt
FINE: return dimension value with user defined unit 0.5in
Oct 24, 2007 10:29:23 AM
FINE: return internal name for choice size-to-image
FINE: return internal name for choice horizontal
FINE: return internal name for choice sum
FINE: return internal name for choice decimal
Oct 24, 2007 10:29:24 AM
FINE: return internal name for choice over then down
validateInputString
FINE: Return internal name of the choice solid
Oct 24, 2007 10:29:25 AM
validateInputString
FINE: return dimension with user-defined unit 1pt
org.eclipse.birt.report.model.metadata.ColorPropertyType validateValue
FINE: the validated color value 13421772
validateInputString
validateInputString
validateInputString
validateInputString
validateInputString
validateInputString
validateInputString
validateInputString
Oct 24, 2007 10:29:26 AM
validateInputString
validateInputString
validateInputString
validateInputString
validateInputString
validateInputString
FINE: return internal name for choice after
Oct 24, 2007 10:29:27 AM
FINE: return internal name for choice text-box
FINE: return dimension value with user defined unit 100%
FINE: return internal name for choice bold
FINE: return internal name for choice center
FINE: return internal name for choice html
FINE: return internal name for choice right
FINE: return internal name for choice page-number
FINE: return dimension value with user defined unit 1.354in
FINE: return dimension value with user defined unit 5.083in
Oct 24, 2007 10:29:28 AM
createGetParameterDefinitionTask
FINE: ReportEngine.createGetParameterDefinitionTask:
reportRunnable=org.eclipse.birt.report.engine.api.impl.ReportRunnable@276aabda
Oct 24, 2007 10:29:32 AM
org.eclipse.birt.report.engine.api.impl.EngineTask setAppContext
FINE: EngineTask.setAppContext: context=
context=org.eclipse.birt.data.engine.cube.inmemory.size=0;or g.eclipse.birt.data.engine.dataset.cache.option=false;PARENT _CLASSLOADER=
com.ibm.ws.classloader.CompoundClassLoader@59462bc0
Local ClassPath:
/usr/WebSphere51/AppServer/installedApps/webdevNetwork/birt5 1.ear/birt.war/WEB-INF/classes:/usr/WebSphere51/AppServer/in stalledApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/ax is-ant.jar:/usr/WebSphere51/AppServer/installedApps/webdevNe twork/birt51.ear/birt.war/WEB-INF/lib/axis.jar:/usr/WebSpher e51/AppServer/installedApps/webdevNetwork/birt51.ear/birt.wa r/WEB-INF/lib/chartengineapi.jar:/usr/WebSphere51/AppServer/ installedApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/ com.ibm.icu_3.6.1.v20070906.jar:/usr/WebSphere51/AppServer/i nstalledApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/c ommons-cli-1.0.jar:/usr/WebSphere51/AppServer/installedApps/ webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/commons-discov ery-0.2.jar:/usr/WebSphere51/AppServer/installedApps/webdevN etwork/birt51.ear/birt.war/WEB-INF/lib/coreapi.jar:/usr/WebS phere51/AppServer/installedApps/webdevNetwork/birt51.ear/bir t.war/WEB-INF/lib/dataadapterapi.jar:/usr/WebSphere51/AppSer ver/installedApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/ lib/dteapi.jar:/usr/WebSphere51/AppServer/installedApps/webd evNetwork/birt51.ear/birt.war/WEB-INF/lib/engineapi.jar:/usr /WebSphere51/AppServer/installedApps/webdevNetwork/birt51.ea r/birt.war/WEB-INF/lib/flute.jar:/usr/WebSphere51/AppServer/ installedApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/ jaxrpc.jar:/usr/WebSphere51/AppServer/installedApps/webdevNe twork/birt51.ear/birt.war/WEB-INF/lib/js.jar:/usr/WebSphere5 1/AppServer/installedApps/webdevNetwork/birt51.ear/birt.war/ WEB-INF/lib/modelapi.jar:/usr/WebSphere51/AppServer/installe dApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/modeloda api.jar:/usr/WebSphere51/AppServer/installedApps/webdevNetwo rk/birt51.ear/birt.war/WEB-INF/lib/odadesignapi.jar:/usr/Web Sphere51/AppServer/installedApps/webdevNetwork/birt51.ear/bi rt.war/WEB-INF/lib/org.apache.commons.codec_1.3.0.v200706111 738.jar:/usr/WebSphere51/AppServer/installedApps/webdevNetwo rk/birt51.ear/birt.war/WEB-INF/lib/saaj.jar:/usr/WebSphere51 /AppServer/installedApps/webdevNetwork/birt51.ear/birt.war/W EB-INF/lib/org.eclipse.emf.common_2.2.1.v200702131851.jar:/u sr/WebSphere51/AppServer/installedApps/webdevNetwork/birt51. ear/birt.war/WEB-INF/lib/org.eclipse.emf.ecore.xmi_2.2.2.v20 0702131851.jar:/usr/WebSphere51/AppServer/installedApps/webd evNetwork/birt51.ear/birt.war/WEB-INF/lib/org.eclipse.emf.ec ore_2.2.2.v200702131851.jar:/usr/WebSphere51/AppServer/insta lledApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/org.w 3c.css.sac_1.3.0.v200706111724.jar:/usr/WebSphere51/AppServe r/installedApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/li b/scriptapi.jar:/usr/WebSphere51/AppServer/installedApps/web devNetwork/birt51.ear/birt.war/WEB-INF/lib/viewservlets.jar: /usr/WebSphere51/AppServer/installedApps/webdevNetwork/birt5 1.ear/birt.war/WEB-INF/lib/wsdl4j-1.5.1.jar:/usr/WebSphere51 /AppServer/installedApps/webdevNetwork/birt51.ear/birt.war
Delegation Mode:
PARENT_LAST;CHART_RESOLUTION=null;BIRT_VIEWER_HTTPSERVET_REQ UEST=com.ibm.ws.webcontainer.srt.SRTServletRequest@76032bc7;
context=BIRT_VIEWER_HTTPSERVET_REQUEST=com.ibm.ws.webcontainer.srt.SRTServletRequest@76032bc7;
Oct 24, 2007 10:29:33 AM
Local ClassPath:
Delegation Mode:
Oct 24, 2007 10:29:37 AM
Oct 24, 2007 10:29:38 AM
Local ClassPath:
Delegation Mode:
Oct 24, 2007 10:30:18 AM
file=/usr/WebSphere51/AppServer/installedApps/webdevNetwork/ birt51.ear/birt.war/documents/6FByU81OFiPsfENPpvgB78P/6ec9e2 3c/test.rptdocument,
designStream=java.io.FileInputStream@68b6bda, options={3}
reportRunnable=org.eclipse.birt.report.engine.api.impl.ReportRunnable@573f6bda
Local ClassPath:
Delegation Mode:
PARENT_LAST;CHART_RESOLUTION=null;BIRT_VIEWER_HTTPSERVET_REQ UEST=com.ibm.ws.webcontainer.srt.SRTServletRequest@7f056bdb;
context=BIRT_VIEWER_HTTPSERVET_REQUEST=com.ibm.ws.webcontainer.srt.SRTServletRequest@7f056bdb;
Re: Runtime Hangs with frameset [message #259366 is a reply to message #259294] Wed, 24 October 2007 16:00 Go to previous messageGo to next message
Rob,
Can you log a bugzilla entry for this?
Also can you try just deploying the default birt.war file?
Jason
> but the frameset URL does not
> can see some html, but not the complete report. In Firefox, the buttons
> at the top are rendered but the progress bar never completes.
> in the SystemOut log like this:
> at
> at
> at
> at
> at
> at
> at
> at
> Code))
> be hung.
> designStream=java.io.FileInputStream@720cabd8, options={3} Oct 24, 2007
> 10:29:21 AM org.eclipse.birt.report.model.metadata.ChoicePropertyType
> validateXml
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> validateInputString
> Local ClassPath:
work/birt51.ear/birt.war/WEB-INF/lib/dteapi.jar:/usr/WebSphe re51/AppServer/installedApps/webdevNetwork/birt51.ear/birt.w ar/WEB-INF/lib/engineapi.jar:/usr/WebSphere51/AppServer/inst alledApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/flut e.jar:/usr/WebSphere51/AppServer/installedApps/webdevNetwork /birt51.ear/birt.war/WEB-INF/lib/jaxrpc.jar:/usr/WebSphere51 /AppServer/installedApps/webdevNetwork/birt51.ear/birt.war/W EB-INF/lib/js.jar:/usr/WebSphere51/AppServer/installedApps/w ebdevNetwork/birt51.ear/birt.war/WEB-INF/lib/modelapi.jar:/u sr/WebSphere51/AppServer/installedApps/webdevNetwork/birt51. ear/birt.war/WEB-INF/lib/modelodaapi.jar:/usr/WebSphere51/Ap pServer/installedApps/webdevNetwork/birt51.ear/birt.war/WEB- INF/lib/odadesignapi.jar:/usr/WebSphere51/AppServer/installe dApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/org.apac he.commons.codec_1.3.0.v200706111738.jar:/usr/WebSphere51/Ap pServer/installedApps/webdevNetwork/birt51.ear/birt.war/WEB- INF/lib/saaj.jar:/usr/WebSpher
e51/AppServer/installedApps/webdevNetwork/birt51.ear/birt.wa r/WEB-INF/lib/org.eclipse.emf.common_2.2.1.v200702131851.jar :/usr/WebSphere51/AppServer/installedApps/webdevNetwork/birt 51.ear/birt.war/WEB-INF/lib/org.eclipse.emf.ecore.xmi_2.2.2. v200702131851.jar:/usr/WebSphere51/AppServer/installedApps/w ebdevNetwork/birt51.ear/birt.war/WEB-INF/lib/org.eclipse.emf .ecore_2.2.2.v200702131851.jar:/usr/WebSphere51/AppServer/in stalledApps/webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/or g.w3c.css.sac_1.3.0.v200706111724.jar:/usr/WebSphere51/AppSe rver/installedApps/webdevNetwork/birt51.ear/birt.war/WEB-INF /lib/scriptapi.jar:/usr/WebSphere51/AppServer/installedApps/ webdevNetwork/birt51.ear/birt.war/WEB-INF/lib/viewservlets.j ar:/usr/WebSphere51/AppServer/installedApps/webdevNetwork/bi rt51.ear/birt.war/WEB-INF/lib/wsdl4j-1.5.1.jar:/usr/WebSpher e51/AppServer/installedApps/webdevNetwork/birt51.ear/birt.wa r
> Delegation Mode:
> Local ClassPath:
> Delegation Mode:
> Local ClassPath:
> Delegation Mode:
> designStream=java.io.FileInputStream@68b6bda, options={3} Oct 24, 2007
> 10:30:18 AM org.eclipse.birt.report.model.metadata.ChoicePropertyType
> validateXml
> reportRunnable=
Re: Runtime Hangs with frameset [message #259374 is a reply to message #259366] Wed, 24 October 2007 17:11 Go to previous messageGo to next message
I'll try the default war tomorrow and follow up the the bugzilla (if
necessary). But here is something interesting.
It finally worked...after 54 minutes of leaving the IE window open!
Here is a portion of the report log show the 54 minute "pause"
-----Cut-----
context=BIRT_VIEWER_HTTPSERVET_REQUEST=com.ibm.ws.webcontainer.srt.SRTServletRequest@19ff8f5e;
Oct 24, 2007 2:26:16 PM
reportRunnable=org.eclipse.birt.report.engine.api.impl.ReportRunnable@5a674f59
Oct 24, 2007 2:26:16 PM org.eclipse.birt.report.engine.api.impl.EngineTask
setAppContext
setAppContext
com.ibm.ws.classloader.CompoundClassLoader@395bcf54
Local ClassPath:
/usr/WebSphere51/AppServer/installedApps/ddcdevNetwork/birt5 1.ear/birt.war/WEB-INF/classes:/usr/WebSphere51/AppServer/in stalledApps/ddcdevNetwork/birt51.ear/birt.war/WEB-INF/lib/ax is-ant.jar:/usr/WebSphere51/AppServer/installedApps/ddcdevNe twork/birt51.ear/birt.war/WEB-INF/lib/axis.jar:/usr/WebSpher e51/AppServer/installedApps/ddcdevNetwork/birt51.ear/birt.wa r/WEB-INF/lib/chartengineapi.jar:/usr/WebSphere51/AppServer/ installedApps/ddcdevNetwork/birt51.ear/birt.war/WEB-INF/lib/ com.ibm.icu_3.6.1.v20070906.jar:/usr/WebSphere51/AppServer/i nstalledApps/ddcdevNetwork/birt51.ear/birt.war/WEB-INF/lib/c ommons-cli-1.0.jar:/usr/WebSphere51/AppServer/installedApps/ ddcdevNetwork/birt51.ear/birt.war/WEB-INF/lib/commons-discov ery-0.2.jar:/usr/WebSphere51/AppServer/installedApps/ddcdevN etwork/birt51.ear/birt.war/WEB-INF/lib/coreapi.jar:/usr/WebS phere51/AppServer/installedApps/ddcdevNetwork/birt51.ear/bir t.war/WEB-INF/lib/dataadapterapi.jar:/usr/WebSphere51/AppSer ver/installedApps/ddcdevNetwork/birt51.ear/birt.war/WEB-INF/ lib/dteapi.jar:/usr/WebSphere51/AppServer/installedApps/ddcd evNetwork/birt51.ear/birt.war/WEB-INF/lib/engineapi.jar:/usr /WebSphere51/AppServer/installedApps/ddcdevNetwork/birt51.ea r/birt.war/WEB-INF/lib/flute.jar:/usr/WebSphere51/AppServer/ installedApps/ddcdevNetwork/birt51.ear/birt.war/WEB-INF/lib/ jaxrpc.jar:/usr/WebSphere51/AppServer/installedApps/ddcdevNe twork/birt51.ear/birt.war/WEB-INF/lib/js.jar:/usr/WebSphere5 1/AppServer/installedApps/ddcdevNetwork/birt51.ear/birt.war/ WEB-INF/lib/modelapi.jar:/usr/WebSphere51/AppServer/installe dApps/ddcdevNetwork/birt51.ear/birt.war/WEB-INF/lib/modeloda api.jar:/usr/WebSphere51/AppServer/installedApps/ddcdevNetwo rk/birt51.ear/birt.war/WEB-INF/lib/odadesignapi.jar:/usr/Web Sphere51/AppServer/installedApps/ddcdevNetwork/birt51.ear/bi rt.war/WEB-INF/lib/org.apache.commons.codec_1.3.0.v200706111 738.jar:/usr/WebSphere51/AppServer/installedApps/ddcdevNetwo rk/birt51.ear/birt.war/WEB-INF/lib/saaj.jar:/usr/WebSphere51 /AppServer/installedApps/ddcdevNetwork/birt51.ear/birt.war/W EB-INF/lib/org.eclipse.emf.common_2.2.1.v200702131851.jar:/u sr/WebSphere51/AppServer/installedApps/ddcdevNetwork/birt51. ear/birt.war/WEB-INF/lib/org.eclipse.emf.ecore.xmi_2.2.2.v20 0702131851.jar:/usr/WebSphere51/AppServer/installedApps/ddcd evNetwork/birt51.ear/birt.war/WEB-INF/lib/org.eclipse.emf.ec ore_2.2.2.v200702131851.jar:/usr/WebSphere51/AppServer/insta lledApps/ddcdevNetwork/birt51.ear/birt.war/WEB-INF/lib/org.w 3c.css.sac_1.3.0.v200706111724.jar:/usr/WebSphere51/AppServe r/installedApps/ddcdevNetwork/birt51.ear/birt.war/WEB-INF/li b/scriptapi.jar:/usr/WebSphere51/AppServer/installedApps/ddc devNetwork/birt51.ear/birt.war/WEB-INF/lib/viewservlets.jar: /usr/WebSphere51/AppServer/installedApps/ddcdevNetwork/birt5 1.ear/birt.war/WEB-INF/lib/wsdl4j-1.5.1.jar:/usr/WebSphere51 /AppServer/installedApps/ddcdevNetwork/birt51.ear/birt.war
Delegation Mode:
PARENT_LAST;CHART_RESOLUTION=null;BIRT_VIEWER_HTTPSERVET_REQ UEST=com.ibm.ws.webcontainer.srt.SRTServletRequest@19ff8f5e;
setAppContext
Oct 24, 2007 3:20:19 PM
systemId=/usr/WebSphere51/AppServer/installedApps/ddcdevNetw ork/birt51.ear/birt.war/WEB-INF/classes/com/detroitdiesel/mc p/birt/test.rptdesign,
file=/usr/WebSphere51/AppServer/installedApps/ddcdevNetwork/ birt51.ear/birt.war/documents/MQ3PVci0heWcU6rhJjRHkhy/3baa0f 87/test.rptdocument,
resourceFolder=/usr/WebSphere51/AppServer/installedApps/ddcd evNetwork/birt51.ear/birt.war}
name=file:/usr/WebSphere51/AppServer/installedApps/ddcdevNet work/birt51.ear/birt.war/WEB-INF/classes/com/detroitdiesel/m cp/birt/test.rptdesign,
designStream=java.io.FileInputStream@7da98f56, options={3}
-----Cut-----
Re: Runtime Hangs with frameset: Resolved [message #259642 is a reply to message #259374] Fri, 26 October 2007 10:47 Go to previous message
The problem was resolved by installing the base war file without the
modifications explained in the 2.1.1 install directions.
Thanks for the suggestion.
Previous Topic:Chart in Report output pdf is not displayed
Next Topic:Referring to page number a report item is on
Current Time: Sat Nov 08 17:00:34 EST 2025
Powered by FUDForum. Page generated in 0.04655 seconds
