Home » Archived » BIRT » XML Datasource streaming issue
XML Datasource streaming issue [message #259231] Tue, 23 October 2007 20:33 Go to next message
Originally posted by: mdavis.pashllc.com
I noticed that there are several blogs and newsgroup entries using a
stream alternative to an XML file.
However, rather than directly using the stream, in the background a
temporary file is created and used.
There are several issues with the temporary file rather than using the
steam.
a. IO performance. (Self-evident)
b. Security. Some of the data I have is sensitivity. Writing to a
temporary file, that may or may not get properly or quickly removed,
causes a security issue and will not past our QA.
Suggestions:
a. Provide a strong encryption mechanism for XML data.
b. Use the stream rather than the temp file.
Sample:
The following is a synopsis of the code samples i have seen:
// Open a report design - retrieve embedded images etc.
IReportRunnable design =
engine.openReportDesign("path_to/some_report.rptdesign");
// Create task to run the report - use the task to execute the report,
task = engine.createRunAndRenderTask(design);
HashMap contextMap = new HashMap();
// some String representation of XML wrapped by a stream
ByteArrayInputStream is = new
ByteArrayInputStream(xmlData.getBytes(UTF8));
contextMap.put(
"org.eclipse.birt.report.data.oda.xml.inputStream", xmlStream);
contextMap.put(
"org.eclipse.birt.report.data.oda.xml.closeInputStream", new
Boolean(true));
task.setAppContext(contextMap);
// normal exectuion of
IRenderOption options = new RenderOption();
options.setOutputFormat( format );
options.setOutputFileName(filename);
task.setRenderOption(options);
task.run();
task.close();
I apologize if I missed something obvious.
Malcolm
Re: XML Datasource streaming issue [message #259304 is a reply to message #259231] Wed, 24 October 2007 11:32 Go to previous message
Malcolm,
Nice solution. If you happen to have a working example, I would love to
add it to my REAPI examples. Contact me direct and we can talk about how
you can get me the example.
Scott Rosenbaum
> steam.
> Suggestions:
> Sample:
> contextMap.put(
> contextMap.put(
> Boolean(true));
> task.run();
> task.close();
> Malcolm
Previous Topic:How to run org.eclipse.birt.chart.examples?
Next Topic:Compatibility between Multi select List Boxes and Drill-Throughs
Current Time: Wed Jul 23 18:07:43 EDT 2025
Powered by FUDForum. Page generated in 0.02768 seconds
