Home » Language IDEs » Java Development Tools (JDT) » How to modify the field declaration with jdt
How to modify the field declaration with jdt [message #259174] |
Sat, 21 March 2009 21:38  |
Hi, all
Here I am curious how to modify the field declaration with JDT
programmaticall.
I have a field declaration like this:
<pre>
public final int count = 3; // e.g. I want to change the count value
3 to 1
</pre>
Is there any way to change the count value, (e.g. 3 to 1)?
I found no proper setter method in IField.
At first, I try to do like this:
1. IField.delete(...) // delete the field first
2. IType.createField(...) // create a new field with new value
declaration.
but, it also came up with a new problem, after above steps, the new field
was created correctly, but the old field was not removed, so there's two
duplicate fields...
What ever, is there any wat to modify the field declaration with JDT?
Any clue is appreciated
Thanks & Best Regards!
--------ooO--(_)--Ooo--------
| Nick Tan |
Re: How to modify the field declaration with jdt [message #259178 is a reply to message #259174] |
Sun, 22 March 2009 07:55   |
Well, I find a way to do the modification with AST, but I DON NOT thinks
it's best practices, is there any better ways?
<code>
ICompilationUnit cu = type.getCompilationUnit();
// creation of DOM/AST from a ICompilationUnit
ASTParser parser = ASTParser.newParser(AST.JLS3);
parser.setSource(cu);
CompilationUnit astRoot = (CompilationUnit) parser.createAST(null);
// start record of the modifications
astRoot.recordModifications();
List<TypeDeclaration> types = astRoot.types();
TypeDeclaration typeDecl = null;
for (TypeDeclaration td : types) {
if
(td.getName().getFullyQualifiedName().equals(type.getTypeQua lifiedName())) {
typeDecl = td;
break;
boolean isDirty = false;
if (typeDecl != null) {
FieldDeclaration[] fieldDeclarations = typeDecl.getFields();
for (FieldDeclaration fd : fieldDeclarations) {
List<VariableDeclarationFragment> vdfs = fd.fragments();
for (VariableDeclarationFragment vdf : vdfs) {
if (vdf.getName().getFullyQualifiedName().equals(fieldName)) {
Expression expr = vdf.getInitializer();
if (expr.getNodeType() == ASTNode.NUMBER_LITERAL) {
NumberLiteral numExpr = (NumberLiteral) expr;
numExpr.setToken(marker.getAttribute(ISTIPletMarkar.ATTR_ENT ITY_VALUE,
"")); //$NON-NLS-1$
isDirty = true;
break;
if (isDirty) {
String source = cu.getSource();
Document document = new Document(source);
// computation of the text edits
TextEdit edits = astRoot.rewrite(document,
cu.getJavaProject().getOptions(true));
// computation of the new source code
edits.apply(document);
String newSource = document.get();
// update of the compilation unit
cu.getBuffer().setContents(newSource);
</code>
And there is another flaw that when I UNDO this operation in JAVA editor,
the whole content replaced to the old one rather than the changed field one
(e.g. count = 3;), because I invoke
which cause the above problem, it's only a little not user-friendly, I
think.
"nick tan" <missedone@gmail.com> wrote in message
news:fe79c10855cad7bad6c51027ef4dde7b$1@www.eclipse.org...
> Hi, all
> programmaticall.
> <pre>
> public final int count = 3; // e.g. I want to change the count value 3
> to 1
> </pre>
> declaration.
> duplicate fields...
> | Nick Tan |
Re: How to modify the field declaration with jdt [message #259191 is a reply to message #259178] |
Sun, 22 March 2009 16:51   |
Originally posted by: alamothe.ptt.yu
Also, if you already have an IField, it's easiest to find the corresponding
declaration in the AST using org.eclipse.jdt.internal.corext.dom.NodeFinder.
> thinks it's best practices, is there any better ways?
> <code>
> if
> { typeDecl = td;
> break;
> { Expression expr = vdf.getInitializer();
> "")); //$NON-NLS-1$ isDirty = true;
> break;
> if (isDirty) {
> </code>
> editor, the whole content replaced to the old one rather than the changed
> field one (e.g. count = 3;), because I invoke
> think.
Re: How to modify the field declaration with jdt [message #259194 is a reply to message #259191] |
Mon, 23 March 2009 00:03  |
awesome! It all works.
Thanks!
"Nikola Mihajlovic" <alamothe@ptt.yu> 写入消息
news:gq68d8$egp$1@build.eclipse.org...
> corresponding declaration in the AST using
>> <code>
>> if
>> { typeDecl = td;
>> break;
>> break;
>> if (isDirty) {
>> </code>
>> think.
Current Time: Sun Aug 31 07:59:56 EDT 2025
Powered by FUDForum. Page generated in 0.03724 seconds
