Home » Newcomers » Newcomers » How to check for a pre-installed software?
How to check for a pre-installed software? [message #259096] Tue, 24 June 2008 06:12 Go to next message
Originally posted by: p.agarwal.lancaster.ac.uk
Hello Everyone,
I am developing a Eclipse based software but for running these software
there has to be certain software that needs to be pre-installed in the PC.
So I wanted to put a condition such that my software checks for the
pre-installed software and if it finds out the required software are
present, then it moves ahead with the installation else it ells the user
to install the softwares required in order to run my software. The
pre-installed software needed are MATLAB and XILINX. Someone told me to
extract paths from the window registry but I could not find the way to do
that. Please help as soon as possible.
Piyush
Re: How to check for a pre-installed software? [message #259108 is a reply to message #259096] Tue, 24 June 2008 10:48 Go to previous messageGo to next message
Wouldn't this be a function of the installer? Or are you building the
installer using Eclipse as well?
Wayne
On Tue, 2008-06-24 at 10:12 +0000, Piyush Agarwal wrote:
> Hello Everyone,
> Regards
> Piyush
Re: How to check for a pre-installed software? [message #259112 is a reply to message #259108] Tue, 24 June 2008 11:12 Go to previous messageGo to next message
Yes I am using eclipse to build the installer. Tell me If i have to write
some codes for it.
Re: How to check for a pre-installed software? [message #259115 is a reply to message #259112] Tue, 24 June 2008 11:37 Go to previous message
A quick look at what Google has to offer ("eclipse check windows
registry") came up with a couple of hits, but nothing helpful.
However, if you change "eclipse" to "java" ("java check windows
registry") [1], there's a lot more. Maybe one of those links will lead
you in the right direction.
Good luck,
Wayne
[1]http://www.google.ca/search?q=java+check+windows+registry
> some codes for it.
Previous Topic:Keeping the state of the Tree Viewer
Next Topic:Dependency Error
Current Time: Sun Nov 16 08:30:14 EST 2025
Powered by FUDForum. Page generated in 0.08789 seconds
