2 questions concerning crosstabs in BIRT 2.2.0 [message #258974] |
Mon, 22 October 2007 08:35  |
Originally posted by: brell.oio.de
i have a 2 questions concerning the new crosstabs-feature. I m not sure what
they mean and how to work with them.
1) When building a cube, i have the possibility to Link Groups. Does this
mean that i can join different datasets? But in the ER-Model Diagram only
the primary dataset gets shown, so that i am unable to join different
dataSets
2) By adding a new group level i have the possiblity to choose between
Dynamic and Static. What does static mean and what can i do with the static
group level option? I can further specify attributes using expression
builder, but what are attributes and what can i do with it?
Thanks in advance
Re: 2 questions concerning crosstabs in BIRT 2.2.0 [message #259013 is a reply to message #258974] |
Mon, 22 October 2007 10:29  |
Christian,
1 - attached is an example that uses multiple data sets.
2 -
Dimensions are defined as a set of data fields arranged in hierarchies
and levels. Country, State, City and Year, Quarter, Month are examples
of how a dimension may be structured. BIRT currently supports level
based dimensions, where each level can be defined as static or dynamic.
Static dimension levels are defined by the cube developer, using the
expression builder. These are usually created using a dataset field
within the expression. For example, a dimension level may be created,
that uses the QTYORDERED field to determine large and small orders,
which creates two possible members at the defined level in the
dimension. Dynamic dimension levels are defined by the dataset used to
construct the level. Defining a dynamic level within a dimension as the
COUNTRY data field would then generate a level member for each country
in the dataset.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build <2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<list-property name="userProperties">
<structure>
<property name="name">Customer Cube.Data Set.x</property>
<property name="type">integer</property>
<property name="isVisible">false</property>
</structure>
<structure>
<property name="name">Customer Cube.Data Set.y</property>
</structure>
<structure>
<property name="name">salesbydate.dsOrders.x</property>
</structure>
<structure>
<property name="name">salesbydate.dsOrders.y</property>
</structure>
<structure>
<property
name="name">salesbydate.Group.NewTabularHierarchy.x</property >
</structure>
<structure>
<property
name="name">salesbydate.Group.NewTabularHierarchy.y</property >
</structure>
<structure>
<property name="name">salesbydate.dsOrders.width</property>
</structure>
<structure>
<property name="name">salesbydate.dsOrders.height</property>
</structure>
<structure>
<property
name="name">salesbydate.Group.NewTabularHierarchy.width</property >
</structure>
<structure>
<property
name="name">salesbydate.Group.NewTabularHierarchy.height</property >
</structure>
<structure>
<property
name="name">salesbydate.Group2.NewTabularHierarchy2.x</property >
</structure>
<structure>
<property
name="name">salesbydate.Group2.NewTabularHierarchy2.y</property >
</structure>
<structure>
<property
name="name">salesbydate.Group2.NewTabularHierarchy2.width</property >
</structure>
<structure>
<property
name="name">salesbydate.Group2.NewTabularHierarchy2.height </property>
</structure>
</list-property>
<property name="Customer Cube.Data Set.x">135</property>
<property name="Customer Cube.Data Set.y">80</property>
<property name="salesbydate.dsOrders.x">224</property>
<property name="salesbydate.dsOrders.y">68</property>
<property name="salesbydate.Group.NewTabularHierarchy.x">31</property >
<property name="salesbydate.Group.NewTabularHierarchy.y">58</property >
<property name="salesbydate.dsOrders.width">150</property>
<property name="salesbydate.dsOrders.height">200</property>
<property
name="salesbydate.Group.NewTabularHierarchy.width">150</property >
<property
name="salesbydate.Group.NewTabularHierarchy.height">200</property >
<property
name="salesbydate.Group2.NewTabularHierarchy2.x">429</property >
<property
name="salesbydate.Group2.NewTabularHierarchy2.y">59</property >
<property
name="salesbydate.Group2.NewTabularHierarchy2.width">150</property >
<property
name="salesbydate.Group2.NewTabularHierarchy2.height">200</property >
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="dsOrders" id="349">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ORDERNUMBER_6</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">STATUS</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
</list-property>
<property name="queryText">select *
from CLASSICMODELS.ORDERDETAILS, CLASSICMODELS.ORDERS
where CLASSICMODELS.ORDERS.ORDERNUMBER =
CLASSICMODELS.ORDERDETAILS.ORDERNUMBER
and
CLASSICMODELS.ORDERS.STATUS = 'Shipped'</property>
</oda-data-set>
<oda-data-set
name="products" id="350">
<structure>
</structure>
<structure>
<property name="name">PRODUCTNAME</property>
</structure>
<structure>
<property name="name">PRODUCTLINE</property>
</structure>
<structure>
<property name="name">PRODUCTSCALE</property>
</structure>
<structure>
<property name="name">PRODUCTVENDOR</property>
</structure>
<structure>
<property name="name">PRODUCTDESCRIPTION</property>
</structure>
<structure>
<property name="name">QUANTITYINSTOCK</property>
</structure>
<structure>
<property name="name">BUYPRICE</property>
</structure>
<structure>
<property name="name">MSRP</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTNAME</property>
</structure>
<structure>
<property name="nativeName">PRODUCTLINE</property>
</structure>
<structure>
<property name="nativeName">PRODUCTSCALE</property>
</structure>
<structure>
<property name="nativeName">PRODUCTVENDOR</property>
</structure>
<structure>
<property
name="nativeName">PRODUCTDESCRIPTION</property>
</structure>
<structure>
<property name="nativeName">QUANTITYINSTOCK</property>
</structure>
<structure>
<property name="nativeName">BUYPRICE</property>
</structure>
<structure>
<property name="nativeName">MSRP</property>
</structure>
</list-property>
from CLASSICMODELS.PRODUCTS</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:formattingHints>
<design:displaySize>15</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTNAME</design:name>
<design:position>2</design:position>
<design:precision>70</design:precision>
<design:usageHints>
<design:label>PRODUCTNAME</design:label>
<design:displaySize>70</design:displaySize>
<design:attributes>
<design:name>PRODUCTLINE</design:name>
<design:position>3</design:position>
<design:precision>50</design:precision>
<design:usageHints>
<design:label>PRODUCTLINE</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>PRODUCTSCALE</design:name>
<design:position>4</design:position>
<design:precision>10</design:precision>
<design:usageHints>
<design:label>PRODUCTSCALE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>PRODUCTVENDOR</design:name>
<design:position>5</design:position>
<design:usageHints>
<design:label>PRODUCTVENDOR</design:label>
<design:attributes>
<design:name>PRODUCTDESCRIPTION</design:name>
<design:position>6</design:position>
<design:precision>32700</design:precision>
<design:usageHints>
<design:label>PRODUCTDESCRIPTION</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:name>QUANTITYINSTOCK</design:name>
<design:position>7</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:usageHints>
<design:label>QUANTITYINSTOCK</design:label>
<design:displaySize>11</design:displaySize>
<design:attributes>
<design:name>BUYPRICE</design:name>
<design:position>8</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:usageHints>
<design:label>BUYPRICE</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>MSRP</design:name>
<design:position>9</design:position>
<design:usageHints>
<design:label>MSRP</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
name="customers" id="351">
<structure>
</structure>
<structure>
<property name="name">CUSTOMERNAME</property>
</structure>
<structure>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="name">CITY</property>
</structure>
<structure>
<property name="name">STATE</property>
</structure>
<structure>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property
name="name">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">CREDITLIMIT</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
<structure>
<property name="nativeName">POSTALCODE</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
<structure>
<property name="name">SALESREPEMPLOYEENUMBER</property>
<property
name="nativeName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="nativeName">CREDITLIMIT</property>
</structure>
</list-property>
from customers</property>
<model:DesignValues
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>CITY</design:name>
<design:usageHints>
<design:label>CITY</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>10</design:position>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>11</design:position>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>SALESREPEMPLOYEENUMB
FUDForum. Page generated in 0.04640 seconds
