Home » Language IDEs » Java Development Tools (JDT) » Skip section when formatting source code
Skip section when formatting source code [message #258823] Sat, 21 February 2009 05:24 Go to next message
I have a class for writing XML documents that is best read when the method
calls are indented as they'd be in the formatted XML document.
Is it possible to have the Java formatter skip certain sections of the
code so as to keep the code editor's format? I mean something like
<pre></pre> sections in the source code.
I believe that while my example is specific this could be useful in other
situations as well.
Eduardo
Re: Skip section when formatting source code [message #258853 is a reply to message #258823] Mon, 23 February 2009 11:00 Go to previous message
Eduardo Francos wrote:
> method calls are indented as they'd be in the formatted XML document.
> other situations as well.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=128630
Dani
> Thanks
> Eduardo
Previous Topic:Joint Compillation Java / Groovy at the Groovy Eclipse Plug-in
Next Topic:Preferences vs. IPreferenceStore
Current Time: Fri Jul 18 05:52:26 EDT 2025
Powered by FUDForum. Page generated in 0.06974 seconds
