Please have a look at the error log file. [message #258805] |
Thu, 19 June 2008 06:52  |
Originally posted by: p.agarwal.lancaster.ac.uk
hello everyone,
I am very new to eclipse and Java programming, so my technical knowledge
is limited. while I try to run my eclipse application, I get a
configration error log file. I have updated the version and I have tried
everything that I could.
I am pasting the contents of the log file below. Please help
Piyush
LOG FILE STARTS
!SESSION 2008-06-19 11:46:29.875
eclipse.buildId=M20070921-1145
java.version=1.6.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data
C:\inofaceWorkspace/../runtime-EclipseApplication -dev
file:C:/inofaceWorkspace/.metadata/.plugins/org.eclipse.pde. core/Eclipse
Application/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.runtime 4 0 2008-06-19 11:46:31.000
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Another singleton version selected:
org.eclipse.core.runtime_3.3.100.v20070530
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
!ENTRY org.eclipse.osgi 4 0 2008-06-19 11:46:31.015
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.core.runtime_3.1.2.jar/ was not
resolved.
!ENTRY org.eclipse.osgi 2 0 2008-06-19 11:46:31.031
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-06-19 11:46:31.031
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.core.runtime_3.1.2.jar/ [280]
was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2008-06-19 11:46:31.031
!MESSAGE Another singleton version selected:
!MESSAGE Bundle update@plugins/org.eclipse.core.resources_3.1.2.jar [281]
was not resolved.
!SUBENTRY 2 org.eclipse.core.resources 2 0 2008-06-19 11:46:31.031
org.eclipse.core.resources_3.3.1.R33x_v20080205
!MESSAGE Bundle update@plugins/org.eclipse.swt_3.1.0.jar [286] was not
resolved.
!SUBENTRY 2 org.eclipse.swt 2 0 2008-06-19 11:46:31.031
!MESSAGE Another singleton version selected: org.eclipse.swt_3.3.2.v3349d
!MESSAGE Bundle update@plugins/org.eclipse.swt.win32.win32.x86_3.1.2.jar
[287] was not resolved.
!SUBENTRY 2 org.eclipse.swt.win32.win32.x86 2 0 2008-06-19 11:46:31.031
org.eclipse.swt.win32.win32.x86_3.3.3.v3349
!MESSAGE Bundle update@plugins/org.eclipse.ui.console_3.1.2.jar [288] was
not resolved.
!SUBENTRY 2 org.eclipse.ui.console 2 0 2008-06-19 11:46:31.031
org.eclipse.ui.console_3.2.2.v20071031_r332
!ENTRY org.eclipse.osgi 4 0 2008-06-19 11:46:31.031
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:72)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
!ENTRY org.eclipse.osgi 2 0 2008-06-19 11:46:31.046
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-06-19 11:46:31.046
!MESSAGE Bundle
was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2008-06-19 11:46:31.046
was not resolved.
!SUBENTRY 2 org.eclipse.core.resources 2 0 2008-06-19 11:46:31.046
resolved.
!SUBENTRY 2 org.eclipse.swt 2 0 2008-06-19 11:46:31.046
!SUBENTRY 2 org.eclipse.swt.win32.win32.x86 2 0 2008-06-19 11:46:31.046
not resolved.
!SUBENTRY 2 org.eclipse.ui.console 2 0 2008-06-19 11:46:31.046
Re: Please have a look at the error log file. [message #258854 is a reply to message #258822] |
Thu, 19 June 2008 08:50  |
Originally posted by: subs._nospam_consertum.com
Piyush Agarwal wrote:
> Thank you DEREK!!! it works now.... but I am now facing a new problem.
> i.e. someone who worked before me had created a perspective according to
> the companies demand but now the when i try to change the perspective it
> gives me the following error of "Problem opening desired perespective".
> Please think about it.
> Regards
> Piyush
I would guess that you need to port the plugin from 3.1 to whichever
version you are now using. In my experience I have found that a plugin
designed for use with one version of Eclipse will need porting to make
it work with later version. Normally this, is pretty simple to do.
Derek
FUDForum. Page generated in 0.10996 seconds
