| javac compiles, eclipse doesn't [message #258404] |
Mon, 02 February 2009 08:09  |
Originally posted by: arend.reinersdorff.de
I stumbled upon a piece of code that compiles with Sun's javac, but not
with the Eclipse Batch Compiler:
import java.lang.reflect.Constructor;
import java.beans.ConstructorProperties;
public class Test{
void test() {
//remove comments around <?>
//and this compiles fine with the eclipse batch compiler
for (Constructor/*<?>*/ constr : Object.class.getConstructors()) {
constr.getAnnotation(ConstructorProperties.class).value();
- Is it intended that the two compilers have different behavior in some
cases?
- If it's not intended, which compiler is right? Should this code compile
or not?
Thanks.
FUDForum. Page generated in 0.37802 seconds
