| Problems with inclusion patterns [message #258348] |
Mon, 05 July 2004 05:54  |
Originally posted by: abc.mymail.com
In Properties->Java Build Path->Source, you can set inclusion patterns for
each source directory. But I can't get this feature to work and I suspect
a big bug here...
For example, in a source directory, I want to include only a single Java
file. I set this file/directory in the inclusion patterns list and when I
validate the changes, the Package Explorer do not show this package/file
anymore!
Here is a simple example:
Let's take package a.b1 and a.b2 each one containing a Main.java. I want
to include only a.b1 package but when I set it in the inclusion pattern
list, I see that a.b2 is not in the source path (since they are shown as a
simple directory and "disabled" Java file) but I don't see a.b1 package
anymore...
| Re: Problems with inclusion patterns [message #258408 is a reply to message #258371] |
Mon, 05 July 2004 09:11  |
This is a known limitation in 3.0. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=65240.
Jerome
"Master Exquisitus" <abc@mymail.com> wrote in message
news:ccbc26$9k6$1@eclipse.org...
> Indeed, actually, it works when you put the Layout option to Flat in the
> Package Explorer but set it to Hierarchical and you won't see the included
> package/file anymore...
> Jerome Lanneluc wrote:
> > This works for me in Eclipse 3.0. What is the inclusion pattern that you
use
> > Jerome
> > news:ccb8h1$2tv$1@eclipse.org...
> > > Hello,
for
suspect
> > > a big bug here...
Java
when I
package/file
> > > anymore!
want
pattern
as a
package
> > > anymore...
FUDForum. Page generated in 0.03628 seconds
