| emf for birt [message #258274] |
Sun, 14 October 2007 11:58  |
Originally posted by: Salvatore.Contu.gmail.com
Hi all,
I'm using run-time birt in my application. I have created chart birt
reports using birt eclipse plugin, all right, but when i try to see these
reports in my application i have this error:
Error happened while running the report.
java.lang.NoClassDefFoundError: org/eclipse/emf/ecore/EObject
so to solve this problem i should deploy emf. Does anybody know how i must
do ?
Salvatore
| Re: emf for birt [message #258313 is a reply to message #258278] |
Mon, 15 October 2007 07:59   |
--------------090206000700060503020800
Salvatore,
If the org.eclipse.emf.ecore plugin is needed, there will also be a need
for the org.eclipse.emf.common plugin jar.
Robert Lario wrote:
> EObject is in org.eclipse.emf.ecore jar file and this file is located in
> eclipse/plugin. For example, my version is called
> org.eclipse.emf.ecore_2.3.1.v200709252135.jar and is physically located in
> c:/eclipse/plugin.
> You need to make sure this file is in you classpath. From within eclipse
> "Build Path>Configure Build Path>Libraries>Add External JARs" to add this
> jar file to your path.
> Hope that helps.
> "Salvatore Contu" <Salvatore.Contu@gmail.com> wrote in message
> news:feteb8$bh3$1@build.eclipse.org...
>> Hi all,
>> do ?
>> Thanks
>> Salvatore
<html>
<head>
</head>
Salvatore,<br>
<br>
need for the org.eclipse.emf.common plugin jar.<br>
<br>
<br>
Robert Lario wrote:
<blockquote cite="mid:feu10d$hfp$1@build.eclipse.org" type="cite">
<pre wrap="">EObject is in org.eclipse.emf.ecore jar file and this file is located in
c:/eclipse/plugin.
Hope that helps.
"Salvatore Contu" <a class="moz-txt-link-rfc2396E" href="mailto:Salvatore.Contu@gmail.com"><Salvatore.Contu@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:feteb8$bh3$1@build.eclipse.org">news:feteb8$bh3$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi all,
do ?
Salvatore
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------090206000700060503020800--
| Re: emf for birt [message #258363 is a reply to message #258274] |
Mon, 15 October 2007 11:40  |
Salvatore,
The easiest answer is to download the BIRT-ALL-IN-ONE which includes the
emf modules. Short of that, you can follow the directions on the download
page and make sure you have:
Java 1.5 JDK/JRE;
Eclipse SDK 3.3
GEF 3.3
EMF 2.3
DTP 1.5
WTP 2.0
Scott Rosenbaum
> Hi all,
> these reports in my application i have this error:
> must do ?
> Thanks
> Salvatore
FUDForum. Page generated in 0.24703 seconds
