| RSE + SU [message #25517] |
Mon, 04 August 2008 12:26  |
Originally posted by: atong.simetra.com
I need to use SU to gain access to certain files on a remote server,
however, I do not have permissions to get in. I tried using the shell,
but that did not work. I do not have access to "root". I do have the SU
password.
| Re: RSE + SU [message #25723 is a reply to message #25517] |
Wed, 06 August 2008 13:45  |
Hi Allen,
I think that when you have the su password, you should be
able to su root on the remote machine and launch an RSE
DStore Server there. That way, your RSE Server should
run with root permissions.
1. su -
2. perl server.pl 12345
3. In RSE client, create a dstore connection for your host
Set DStore launcher to "Running"
4. In the created connection, select the "Files" subsystem
Right-click > Properties and specify the Port as 12345
See also http://dsdp.eclipse.org/help/latest/index.jsp
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> SU password.
| Re: RSE + SU [message #576570 is a reply to message #25517] |
Hi Allen,
1. su -
> SU password.
FUDForum. Page generated in 0.02993 seconds
