| Designer: Derive Column Header Name Dynamically [message #258056] |
Fri, 12 October 2007 09:25  |
Originally posted by: rupeshkp.gmail.com
We need to build a BIRT report using report designer tool wherein the
dataset column names (i.e. associated layout column header names) are
determined based on user input
Ex:
1. Lets say there exists a table T with each row representing column names
C1, C2, C3 etc against a user id u1.
2. Column C1, C2, C3 are not fixed, the names may changes for user u2 to
say C3, C4, C5, C6
3. When this user u1 clicks on a report, it should generate an output with
following header: C1, C2, C3 and then each row representing values for
these columns
Queries
1. I think use of report engine API could be a possible approach for this.
I don't know if these API can also help in sticking to same look and feel
(css) used in report designer.
2. Can this be achieved using BIRT report designer tool and if so how do
we do this. I could not find any pointer.
Any help will be greatly appreciated.
| Re: Designer: Derive Column Header Name Dynamically [message #258202 is a reply to message #258056] |
Fri, 12 October 2007 15:49  |
Hi Rupesh,
There are a couple of example below that may help.
Dynamic Content Creation in BIRT - This example uses parameters with a
report design and lets you pass in the columns needed for the report
http://www.birt-exchange.com/modules/wfdownloads/singlefile. php?cid=2&lid=117
Create report dynamically - This example uses the DEAPI and does
everything in Java code.
http://www.birt-exchange.com/modules/wfdownloads/singlefile. php?cid=2&lid=156
Virgil
> Ex: 1. Lets say there exists a table T with each row representing column
> names C1, C2, C3 etc against a user id u1.
> say C3, C4, C5, C6
> with following header: C1, C2, C3 and then each row representing values
> for these columns
> Queries
> this. I don't know if these API can also help in sticking to same look
> and feel (css) used in report designer.
FUDForum. Page generated in 0.03960 seconds
