| LPG question: how to add a method to generated code [message #25498] |
Sat, 15 November 2008 05:36  |
Originally posted by: jonathan910.freemail.br
Hi, not sure if this is the forum for LPG questions but
here goes:
I would like to add a getType metod to all the generated AST nod
objects. The method should return a constant representing
the AST node (this to avoid all the instanceof constructs).
What is the best way to do this?
BTW: Is it possible to define that all the AST node inherits from
a class that I declare?
Thanks in advance
Jonathan
| Re: LPG question: how to add a method to generated code [message #25617 is a reply to message #25498] |
Wed, 19 November 2008 16:25  |
Jonathan,
Additional information on defining (or customizing) your own parent AST
class:
1) rename the Root node with the option ast_type=my_no_name...
(You can see this option near the top of the generated .g template.)
2) add additional class member declarations to it in the %Ast
section. For example, to add an additional int field, one
would specify:
%Ast
int additionalField;
void setAdditionalField(int x) { additionalField = x; }
int getNewField() { return additionalField; }
%End
(You would need to add the %Ast section to your .g file.)
Hope this helps!
Stan
> here goes:
> Thanks in advance
> Jonathan
| Re: LPG question: how to add a method to generated code [message #574281 is a reply to message #25498] |
Wed, 19 November 2008 15:49  |
Hi Jonathan,
> here goes:
This is not primarily an LPG forum, but since we provide LPG with IMP we
try to offer some support.
In the LPG grammar specification file (the .g file) it is possible to
associate some Java code with each production. This Java code gets
generated into the classes that LPG creates for the various node types.
I believe that you should be able to add a method to each node type of
interest by defining it in this way. (You can see examples in the
leg.g file that gets generated if you run the IMP wizard to generate a
new LPG grammar file.)
I don't think it's possible to do that specifically. LPG does generate
a type, ASTNode, that is the parent type for the various specific AST
node types. I don't know that there is a way to automatically add code
to that (as you can with the individual rules as described above).
I'll check with local experts and see if I can dig up any further ideas.
> Thanks in advance
> Jonathan
Good luck!
Stan
| Re: LPG question: how to add a method to generated code [message #574305 is a reply to message #25498] |
Jonathan,
class:
would specify:
%Ast
%End
Hope this helps!
Stan
> here goes:
> Thanks in advance
> Jonathan
FUDForum. Page generated in 1.04346 seconds
