Home » Newcomers » Newcomers » Vista - Eclipse cannot import projects!
Vista - Eclipse cannot import projects! [message #257969] Tue, 10 June 2008 07:06 Go to next message
Originally posted by: tomoldfield.gmail.com
Hi there i have been using Eclipse for a while now and im still learning
java. I recently moved all my programs and files etc over to Vista
Ultimate 64. When i try to go into any eclipse version and click File ->
Import -> try to click on general, it just doesnt work. I try to click
general, the box scrolls down and stops to work. I cant click anything
else inside the box so i cant select anything. I can type in the search
box 'type filter text here' and it displays the revelant items in the box
fine but i cant click on any of them!
Any help?
Re: Vista - Eclipse cannot import projects! [message #257992 is a reply to message #257969] Tue, 10 June 2008 11:42 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
Are you using the 32-bit or 64-bit version of Eclipse? Are you using a
1.5 or 1.6 JVM? If you start up eclipse with these options, do you get
any useful output?
eclipse.exe -vm c:\path\to\bin\java -data c:\path\to\workspace
-consolelog -clean -debug -console -noexit -vmargs -Xms128M -Xmx256M
-XX:PermSize=128M -XX:MaxPermSize=256M
> box fine but i cant click on any of them!
> Any help?
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: Vista - Eclipse cannot import projects! [message #257999 is a reply to message #257992] Tue, 10 June 2008 11:50 Go to previous messageGo to next message
'Vista Ultimate 64'. JVM 1.6.
When i try to run that a box comes up saying JRE or JDK must be aviable in
order to run Eclipse. No java VM was found after searching
c:\path\to\bin\java
Re: Vista - Eclipse cannot import projects! [message #258006 is a reply to message #257999] Tue, 10 June 2008 12:45 Go to previous message
/me smacks forehead
Try replacing that fake path with your actual path.
> in order to run Eclipse. No java VM was found after searching
> c:\path\to\bin\java
Previous Topic:audio recording dialog, plugin
Next Topic:Unable to include my plugin functionality into eclipse
Current Time: Wed Oct 29 18:07:26 EDT 2025
Powered by FUDForum. Page generated in 0.08239 seconds
