Home » Modeling » M2T (model-to-text transformation) » Re: Spaces in URLs
| Re: Spaces in URLs [message #25489] |
Mon, 09 July 2007 16:24  |
--------------090409070101020602070709
Scott,
I'm not sure where the URI
"file:C:/projects/regatta-workbench/workspace/RW FinishLynx/plugin.xml"
is being created, but it should be of the form
"file:/C:/projects/regatta-workbench/workspace/RW FinishLynx/plugin.xml"
(note the / after the file:) to be a proper hierarchical URI. Perhaps
this worked in the past because createURLInputStream was invoked where
really createFileInputStream is what should be kicking in but now, with
2.3, createEFSInputStream is used instead. I'm confused though why this
code wouldn't be using "platform:/resource/RW FinishLynx/plugin.xml"
instead, because that would seem the proper way to access something in
the workspace; using a file: URI for that will bypass the workspace and
access the underlying file system directly instead...
I'll add the M2T newsgroup to the reply since this appears to be a JET2
problem in this code:
private void updateProject(IProject project)
if(DEBUG)
System.out.println("PluginProjectMonitor.updateProject(" + project +
")"); //$NON-NLS-1$ //$NON-NLS-2$
try
final URL projectURL = new URL("file", "",
project.getLocation() + "/"); //$NON-NLS-1$ //$NON-NLS-2$ //$NON-NLS-3$
final BundleManifest manifest =
JETBundleManager.loadManifest(projectURL);
Object pluginDocumentRoot = null;
if(hasPluginManifest(project)) {
if(DEBUG)System.out.println(" has plugin.xml"); //$NON-NLS-1$
URL extensionsURL = new URL(projectURL, "plugin.xml");
//$NON-NLS-1$
JETActivatorWrapper.INSTANCE.getLoaderManager().getLoader(ex tensionsURL.toExternalForm(),
null, "xml").load(extensionsURL); //$NON-NLS-1$
Scott Dybiec wrote:
> I installed Eclipse 3.3 and pointed it to my Eclipse 3.2 workspace.
> Now my .log file is filling up with many, many messages like the one
> below --- one for each project in my workspace. They are generated
> during my workspace automatic incremental builds. These builds now
> take a very long time - much longer than under 3.2.
> One thing I've noticed: It seem to be happening with projects that
> have names with spaces in them, such as the one below:
> "C:/projects/regatta-workbench/workspace/RW FinishLynx/plugin.xml"
> Perhaps it's similar in some way to this:
> http://dev.eclipse.org/newslists/news.eclipse.modeling.m2t/m sg00163.html
> Is this an EMF issue? If not, can you point me in the right direction?
> Sincerely,
> Lost In Spaces
> !ENTRY org.eclipse.jet 2 0 2007-07-09 15:27:20.687
> !MESSAGE Illegal character in opaque part at index 47:
> !STACK 0
> org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Illegal
> at
> org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createE FSInputStream(URIConverterImpl.java:671)
> at
> org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:542)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1152)
> at
> org.eclipse.jet.internal.runtime.model.EMFXMLModelLoader.loa d(EMFXMLModelLoader.java:151)
> at
> org.eclipse.jet.internal.runtime.model.EMFXMLModelLoader.loa d(EMFXMLModelLoader.java:131)
> at
> org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.updateProject(PluginProjectMonitor.java:208)
> at
> org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.access$0(PluginProjectMonitor.java:196)
> at
> org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r$1.visit(PluginProjectMonitor.java:129)
> at
> org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:67)
> at
> org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:76)
> at
> org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:48)
> at
> org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.handleWorkspaceChange(PluginProjectMonitor.java:112)
> at
> org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.resourceChanged(PluginProjectMonitor.java:103)
> at
> org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:282)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at
> org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:276)
> at
> org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:148)
> at
> org.eclipse.core.internal.resources.Workspace.broadcastPostC hange(Workspace.java:311)
> at
> org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:1018)
> at
> org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1806)
> at
> org.eclipse.core.internal.events.NotificationManager$NotifyJ ob.run(NotificationManager.java:39)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by: java.net.URISyntaxException: Illegal character in opaque
> part at index 47: file:C:/projects/regatta-workbench/workspace/RW
> at java.net.URI$Parser.fail(Unknown Source)
> at java.net.URI$Parser.checkChars(Unknown Source)
> at java.net.URI$Parser.parse(Unknown Source)
> at java.net.URI.<init>(Unknown Source)
> at
> org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createE FSInputStream(URIConverterImpl.java:663)
> ... 21 more
<html>
<head>
</head>
Scott,<br>
<br>
I'm not sure where the URI <tt><a moz-do-not-send="true"
class="moz-txt-link-freetext"
href="file:C:/projects/regatta-workbench/workspace/RW">"file:C:/projects/regatta-workbench/workspace/RW </a>
FinishLynx/plugin.xml</tt>" is being created, but it should be of the
form <tt><a moz-do-not-send="true" class="moz-txt-link-freetext"
href="file:C:/projects/regatta-workbench/workspace/RW">"file:/C:/projects/regatta-workbench/workspace/RW </a>
FinishLynx/plugin.xml</tt>" (note the / after the file:) to be a proper
hierarchical URI. Perhaps this worked in the past because
createURLInputStream was invoked where really createFileInputStream is
what should be kicking in but now, with 2.3, createEFSInputStream is
used instead. I'm confused though why this code wouldn't be using
"platform:/resource/<tt>RW FinishLynx/plugin.xml"</tt> instead, because
that would seem the proper way to access something in the workspace;
using a file: URI for that will bypass the workspace and access the
underlying file system directly instead...<br>
<br>
problem in this code:<br>
<blockquote><small> private void updateProject(IProject project)</small><br>
<small> {</small><br>
<small> if(DEBUG)
")"); //$NON-NLS-1$ //$NON-NLS-2$</small><br>
<small> try</small><br>
<small> </small><br>
<small> final URL projectURL = new URL("file", "",
project.getLocation() + "/"); //$NON-NLS-1$ //$NON-NLS-2$ //$NON-NLS-3$</small><br>
<small> final BundleManifest manifest =
JETBundleManager.loadManifest(projectURL);</small><br>
<small> Object pluginDocumentRoot = null;</small><br>
<small> if(hasPluginManifest(project)) {</small><br>
<small> if(DEBUG)System.out.println(" has plugin.xml");
//$NON-NLS-1$</small><br>
<small> URL extensionsURL = new URL(projectURL, "plugin.xml");
<small> pluginDocumentRoot =
null, "xml").load(extensionsURL); //$NON-NLS-1$</small><br>
<small> }</small><br>
</blockquote>
<br>
Scott Dybiec wrote:
<blockquote cite="mid:f6u3jd$2h0$1@build.eclipse.org" type="cite">I
installed Eclipse 3.3 and pointed it to my Eclipse 3.2 workspace. Now
my .log file is filling up with many, many messages like the one below
--- one for each project in my workspace. They are generated during my
workspace automatic incremental builds. These builds now take a very
long time - much longer than under 3.2.<br>
<br>
One thing I've noticed: It seem to be happening with projects that have
names with spaces in them, such as the one below: <br>
<br>
"<tt>C:/projects/regatta-workbench/workspace/RW FinishLynx/plugin.xml"<br>
<br>
</tt>Perhaps it's similar in some way to this:
href=" http://dev.eclipse.org/newslists/news.eclipse.modeling.m2t/m sg00163.html"> http://dev.eclipse.org/newslists/news.eclipse.modeling.m2t/m sg00163.html</a><tt><br>
<br>
</tt>Is this an EMF issue? If not, can you point me in the right
direction?<br>
<br>
Sincerely,<br>
<br>
Lost In Spaces<br>
<br>
<hr size="2" width="100%"><br>
<tt>!ENTRY org.eclipse.jet 2 0 2007-07-09 15:27:20.687<br>
href="file:C:/projects/regatta-workbench/workspace/RW">file:C:/projects/regatta-workbench/workspace/RW </a>
FinishLynx/plugin.xml<br>
!STACK 0<br>
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createE FSInputStream(URIConverterImpl.java:671) <br>
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:542) <br>
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1152) <br>
org.eclipse.jet.internal.runtime.model.EMFXMLModelLoader.loa d(EMFXMLModelLoader.java:151) <br>
org.eclipse.jet.internal.runtime.model.EMFXMLModelLoader.loa d(EMFXMLModelLoader.java:131) <br>
org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.updateProject(PluginProjectMonitor.java:208) <br>
org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.access$0(PluginProjectMonitor.java:196) <br>
org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r$1.visit(PluginProjectMonitor.java:129) <br>
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:67) <br>
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:76) <br>
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:48) <br>
org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.handleWorkspaceChange(PluginProjectMonitor.java:112) <br>
org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.resourceChanged(PluginProjectMonitor.java:103) <br>
org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:282) <br>
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)<br >
org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:276) <br>
org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:148) <br>
org.eclipse.core.internal.resources.Workspace.broadcastPostC hange(Workspace.java:311) <br>
org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:1018) <br>
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1806) <br>
org.eclipse.core.internal.events.NotificationManager$NotifyJ ob.run(NotificationManager.java:39) <br>
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)<br >
part at index 47: <a moz-do-not-send="true"
at java.net.URI$Parser.fail(Unknown Source)<br>
at java.net.URI$Parser.checkChars(Unknown Source)<br>
at java.net.URI$Parser.parse(Unknown Source)<br>
at java.net.URI.<init>(Unknown Source)<br>
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createE FSInputStream(URIConverterImpl.java:663) <br>
... 21 more</tt><br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------090409070101020602070709--
| Re: Spaces in URLs [message #25528 is a reply to message #25489] |
Mon, 09 July 2007 16:47   |
------=_NextPart_000_0020_01C7C248.E3CE9930
charset="iso-8859-1"
Scott:
This is definitely a JET bug. Can you submit a bugzilla. The following =
link setup of most of the fields:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=3DM2T&am p;version=3Dunspe=
cified&component=3DJet&rep_platform=3DPC&op_sys= 3DWindows%20XP&priority=3D=
P3&bug_severity=3Dnormal&bug_status=3DNEW&bug_fi le_loc=3Dhttp%3A%2F%2F&sh=
ort_desc=3D&comment=3D&commentprivacy=3D0&keywor ds=3D&dependson=3D&blocke=
d=3D&maketemplate=3DRemember%20values%20as%20bookmarkabl e%20template&form=
_name=3Denter_bug&assigned_to=3Dm2t.jet-inbox%40eclipse. org
Thx,
Paul
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:f6u5ia$6v0$1@build.eclipse.org...
Scott,
I'm not sure where the URI =
"file:C:/projects/regatta-workbench/workspace/RW FinishLynx/plugin.xml" =
is being created, but it should be of the form =
"file:/C:/projects/regatta-workbench/workspace/RW FinishLynx/plugin.xml" =
(note the / after the file:) to be a proper hierarchical URI. Perhaps =
this worked in the past because createURLInputStream was invoked where =
really createFileInputStream is what should be kicking in but now, with =
2.3, createEFSInputStream is used instead. I'm confused though why this =
code wouldn't be using "platform:/resource/RW FinishLynx/plugin.xml" =
instead, because that would seem the proper way to access something in =
the workspace; using a file: URI for that will bypass the workspace and =
I'll add the M2T newsgroup to the reply since this appears to be a =
JET2 problem in this code:
if(DEBUG) =
System.out.println("PluginProjectMonitor.updateProject(" + project + =
try
=20
final URL projectURL =3D new URL("file", "", =
final BundleManifest manifest =3D =
Object pluginDocumentRoot =3D null;
if(DEBUG)System.out.println(" has plugin.xml"); =
//$NON-NLS-1$
URL extensionsURL =3D new URL(projectURL, "plugin.xml"); =
//$NON-NLS-1$
pluginDocumentRoot =3D =
JETActivatorWrapper.INSTANCE.getLoaderManager().getLoader(ex tensionsURL.t=
oExternalForm(), null, "xml").load(extensionsURL); //$NON-NLS-1$
Scott Dybiec wrote:=20
I installed Eclipse 3.3 and pointed it to my Eclipse 3.2 workspace. =
Now my .log file is filling up with many, many messages like the one =
below --- one for each project in my workspace. They are generated =
during my workspace automatic incremental builds. These builds now take =
One thing I've noticed: It seem to be happening with projects that =
have names with spaces in them, such as the one below:=20
Perhaps it's similar in some way to this: =
Is this an EMF issue? If not, can you point me in the right =
direction?
Sincerely,
Lost In Spaces
!MESSAGE Illegal character in opaque part at index 47: =
!STACK 0
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Illegal =
at =
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createE FSInputStream=
at =
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(UR=
at =
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1=
152)
at =
org.eclipse.jet.internal.runtime.model.EMFXMLModelLoader.loa d(EMFXMLModel=
Loader.java:151)
at =
Loader.java:131)
at =
org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.updateProje=
at =
org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.access$0(Pl=
at =
org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r$1.visit(Plu=
at =
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:=
67)
at =
76)
at =
48)
at =
org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.handleWorks=
at =
org.eclipse.jet.internal.extensionpoints.PluginProjectMonito r.resourceCha=
at =
org.eclipse.core.internal.events.NotificationManager$2.run(N otificationMa=
nager.java:282)
at =
org.eclipse.core.internal.events.NotificationManager.notify( NotificationM=
anager.java:276)
at =
org.eclipse.core.internal.events.NotificationManager.broadca stChanges(Not=
at =
org.eclipse.core.internal.resources.Workspace.broadcastPostC hange(Workspa=
ce.java:311)
at =
org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java=
:1018)
at =
at =
org.eclipse.core.internal.events.NotificationManager$NotifyJ ob.run(Notifi=
Caused by: java.net.URISyntaxException: Illegal character in opaque =
part at index 47: file:C:/projects/regatta-workbench/workspace/RW =
at =
... 21 more
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3132" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Scott:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>This is definitely a JET bug. Can you =
submit a=20
bugzilla. The following link setup of most of the fields:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><A=20
href=3D" https://bugs.eclipse.org/bugs/enter_bug.cgi?product=3DM2T&am p;amp;ver=
sion=3Dunspecified&component=3DJet&rep_platf orm=3DPC&op_sys=3D=
Windows%20XP&priority=3DP3&bug_severity=3Dno rmal&bug_status=3D=
NEW&bug_file_loc=3Dhttp%3A%2F%2F&short_desc= 3D&comment=3D&=
;commentprivacy=3D0&keywords=3D&dependson=3D &blocked=3D&m=
aketemplate=3DRemember%20values%20as%20bookmarkable%20templa te&form_n=
ame=3Denter_bug&assigned_to=3Dm2t.jet-inbox%40eclips e.org ">https://bu=
gs.eclipse.org/bugs/enter_bug.cgi?product=3DM2T&vers ion=3Dunspecified=
&component=3DJet&rep_platform=3DPC&o p_sys=3DWindows%20XP&=
priority=3DP3&bug_severity=3Dnormal&bug_stat us=3DNEW&bug_file=
_loc=3Dhttp%3A%2F%2F&short_desc=3D&comment=3 D&commentprivacy=3D=
0&keywords=3D&dependson=3D&blocked=3 D&maketemplate=3DReme=
mber%20values%20as%20bookmarkable%20template&form_na me=3Denter_bug&am=
p;assigned_to=3Dm2t.jet-inbox%40eclipse.org</A></FONT></DIV >
<DIV><FONT face=3DArial size=3D2>Thx,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Paul</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:f6u5ia$6v0$1@build.eclipse.org">news:f6u5ia$6v0$1@build.ecli=
pse.org</A>...</DIV>Scott,<BR><BR>I'm=20
not sure where the URI <TT><A class=3Dmoz-txt-link-freetext=20
href=3D"file:C:/projects/regatta-workbench/workspace/RW"=20
moz-do-not-send=3D"true">"file:C:/projects/regatta-workbench/workspace/RW=
</A>=20
FinishLynx/plugin.xml</TT>" is being created, but it should be of the =
form=20
moz-do-not-send=3D"true">"file:/C:/projects/regatta-workbench/workspace/R=
W</A>=20
FinishLynx/plugin.xml</TT>" (note the / after the file:) to be a =
proper=20
hierarchical URI. Perhaps this worked in the past because=20
createURLInputStream was invoked where really createFileInputStream is =
what=20
should be kicking in but now, with 2.3, createEFSInputStream is used=20
instead. I'm confused though why this code wouldn't be using=20
"platform:/resource/<TT>RW FinishLynx/plugin.xml"</TT> instead, =
because that=20
would seem the proper way to access something in the workspace; using =
a file:=20
URI for that will bypass the workspace and access the underlying file =
system=20
directly instead...<BR><BR>I'll add the M2T newsgroup to the reply =
since this=20
appears to be a JET2 problem in this code:<BR>
<BLOCKQUOTE><SMALL> private void updateProject(IProject=20
project)</SMALL><BR><SMALL> =
{</SMALL><BR><SMALL> =20
if(DEBUG) System.out.println("PluginProjectMonitor.updateProject(" + =
project=20
+ ")"); //$NON-NLS-1$ =
//$NON-NLS-2$</SMALL><BR><SMALL> =20
try</SMALL><BR><SMALL> =20
</SMALL><BR><SMALL> final URL =
projectURL =3D new=20
URL("file", "", project.getLocation() + "/"); //$NON-NLS-1$ =
//$NON-NLS-2$=20
//$NON-NLS-3$</SMALL><BR><SMALL> final =
BundleManifest manifest =3D=20
JETBundleManager.loadManifest(projectURL);</SMALL><BR><SMALL > =
=20
Object pluginDocumentRoot =3D=20
null;</SMALL><BR><SMALL> =20
if(hasPluginManifest(project))=20
if(DEBUG)System.out.println(" has plugin.xml");=20
//$NON-NLS-1$</SMALL><BR><SMALL>  =
;=20
URL extensionsURL =3D new URL(projectURL, "plugin.xml");=20
;=20
oExternalForm(),=20
null, "xml").load(extensionsURL);=20
//$NON-NLS-1$</SMALL><BR><SMALL> =20
}</SMALL><BR></BLOCKQUOTE><BR>Scott Dybiec wrote:=20
<BLOCKQUOTE cite=3Dmid:f6u3jd$2h0$1@build.eclipse.org type=3D"cite">I =
installed=20
Eclipse 3.3 and pointed it to my Eclipse 3.2 workspace. Now my .log =
file is=20
filling up with many, many messages like the one below --- one for =
each=20
project in my workspace. They are generated during my workspace =
automatic=20
incremental builds. These builds now take a very long time - much =
longer=20
than under 3.2.<BR><BR>One thing I've noticed: It seem to be =
happening with=20
projects that have names with spaces in them, such as the one below: =
<BR><BR>"<TT>C:/projects/regatta-workbench/workspace/RW=20
FinishLynx/plugin.xml"<BR><BR></TT>Perhaps it's similar in some way =
to this:=20
href=3D" http://dev.eclipse.org/newslists/news.eclipse.modeling.m2t/m sg001=
63.html"=20
moz-do-not-send=3D"true">http://dev.eclipse.org/newslists/news.eclipse.mo=
deling.m2t/msg00163.html</A><TT><BR><BR></TT>Is=20
this an EMF issue? If not, can you point me in the right=20
direction?<BR><BR>Sincerely,<BR><BR>Lost In Spaces<BR><BR>
<HR width=3D"100%" SIZE=3D2>
<BR><TT>!ENTRY org.eclipse.jet 2 0 2007-07-09 =
15:27:20.687<BR>!MESSAGE=20
Illegal character in opaque part at index 47: <A =
moz-do-not-send=3D"true">file:C:/projects/regatta-workbench/workspace/RW <=
/A>=20
FinishLynx/plugin.xml<BR>!STACK=20
0<BR>org.eclipse.emf.ecore.resource.Resource$IOWrappedException: =
Illegal=20
/A>=20
FinishLynx/plugin.xml<BR> at=20
(URIConverterImpl.java:671)<BR> =20
at=20
IConverterImpl.java:542)<BR> =20
at=20
152)<BR> =20
at=20
Loader.java:151)<BR> =20
at=20
Loader.java:131)<BR> =20
at=20
ct(PluginProjectMonitor.java:208)<BR> =20
at=20
uginProjectMonitor.java:196)<BR> =20
at=20
ginProjectMonitor.java:129)<BR> =20
at=20
67)<BR> =20
at=20
76)<BR> =20
at=20
48)<BR> =20
at=20
paceChange(PluginProjectMonitor.java:112)<BR> =20
at=20
nged(PluginProjectMonitor.java:103)<BR> =20
at=20
nager.java:282)<BR> =20
at=20
org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)<BR > &nbs=
p; =20
at=20
anager.java:276)<BR> =20
at=20
ificationManager.java:148)<BR> =20
at=20
ce.java:311)<BR> =20
at=20
:1018)<BR> =20
at=20
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1806) <BR=
> =20
at=20
cationManager.java:39)<BR> =20
at =
org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)<BR >Caused by:=20
java.net.URISyntaxException: Illegal character in opaque part at =
index 47:=20
/A>=20
java.net.URI$Parser.fail(Unknown Source)<BR> at=20
java.net.URI$Parser.checkChars(Unknown Source)<BR> =
at=20
java.net.URI$Parser.parse(Unknown Source)<BR> at=20
java.net.URI.<init>(Unknown Source)<BR> at=20
(URIConverterImpl.java:663)<BR> =20
... 21 =
more</TT><BR><BR><BR></BLOCKQUOTE><BR></BLOCKQUOTE></BODY ></HTML>
------=_NextPart_000_0020_01C7C248.E3CE9930--
| Re: Spaces in URLs [message #25570 is a reply to message #25528] |
Mon, 09 July 2007 23:00   |
<html>
<head>
</head>
Bugzilla has been submitted.<br>
<br>
Thanks for all your great work on EMF and JET.<br>
<br>
$cott<br>
<br>
Paul Elder wrote:
<blockquote cite="mid:f6u6uu$a7f$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.3132" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Scott:</font></div>
<div> </div>
<div><font face="Arial" size="2">This is definitely a JET bug. Can
you submit a bugzilla. The following link setup of most of the fields:</font></div>
<div> </div>
<div><font face="Arial" size="2"><a moz-do-not-send="true"
href=" https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& amp ;version=unspecified&component=Jet&rep_platf orm=PC&op_sys=Windows%20XP&priority=P3&a mp;bug_severity=normal&bug_status=NEW&bug_fi le_loc=http%3A%2F%2F&short_desc=&comment=&am p;amp;commentprivacy=0&keywords=&dependson=& amp;amp;blocked=&maketemplate=Remember%20values%20as %20bookmarkable%20template&form_name=enter_bug&a mp;assigned_to=m2t.jet-inbox%40eclipse.org "> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& amp ;version=unspecified&component=Jet&rep_platf orm=PC&op_sys=Windows%20XP&priority=P3&a mp;bug_severity=normal&bug_status=NEW&bug_fi le_loc=http%3A%2F%2F&short_desc=&comment=&am p;amp;commentprivacy=0&keywords=&dependson=& amp;amp;blocked=&maketemplate=Remember%20values%20as %20bookmarkable%20template&form_name=enter_bug&a mp;assigned_to=m2t.jet-inbox%40eclipse.org </a></font></div>
<div> </div>
<div><font face="Arial" size="2">Thx,</font></div>
<div> </div>
<div><font face="Arial" size="2">Paul</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a moz-do-not-send="true"
href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>> wrote in
message <a moz-do-not-send="true"
href="news:f6u5ia$6v0$1@build.eclipse.org">news:f6u5ia$6v0$1@build.eclipse.org</a>...</div>
Scott,<br>
<br>
I'm not sure where the URI <tt><a class="moz-txt-link-freetext"
moz-do-not-send="true">"file:C:/projects/regatta-workbench/workspace/RW </a>
form <tt><a class="moz-txt-link-freetext"
moz-do-not-send="true">"file:/C:/projects/regatta-workbench/workspace/RW </a>
<br>
<small> if(DEBUG)
"plugin.xml"); //$NON-NLS-1$</small><br>
</blockquote>
<br>
<br>
<br>
<br>
</tt>Perhaps it's similar in some way to this: <a
moz-do-not-send="true"> http://dev.eclipse.org/newslists/news.eclipse.modeling.m2t/m sg00163.html</a><tt><br>
<br>
direction?<br>
<br>
Sincerely,<br>
<br>
Lost In Spaces<br>
<br>
<hr size="2" width="100%"> <br>
!MESSAGE Illegal character in opaque part at index 47: <a
moz-do-not-send="true">file:C:/projects/regatta-workbench/workspace/RW </a>
!STACK 0<br>
character in opaque part at index 47: <a class="moz-txt-link-freetext"
<br>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
| Re: Spaces in URLs [message #25609 is a reply to message #25570] |
Mon, 09 July 2007 23:05   |
<html>
<head>
</head>
For reference, here's the URL:
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=195924">https://bugs.eclipse.org/bugs/show_bug.cgi?id=195924</a><br>
<br>
Scott Dybiec wrote:
<blockquote cite="mid:f6usnc$o6k$1@build.eclipse.org" type="cite">
<br>
<br>
$cott<br>
<br>
<meta http-equiv="Content-Type" content="text/html;">
<style></style>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<blockquote
Scott,<br>
<br>
<br>
<small> if(DEBUG)
</blockquote>
<br>
<br>
<br>
<br>
<br>
right
direction?<br>
<br>
Sincerely,<br>
<br>
Lost In Spaces<br>
<br>
!STACK 0<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
| Re: Spaces in URLs [message #25714 is a reply to message #25528] |
Tue, 10 July 2007 18:13   |
<html>
<head>
</head>
<br>
Is there a workaround for this bug? My Eclipse 3.3 is unusably slow
right now --- e.g. saving any file leads to a 5-8 minute update/build
process that throws lots of errors into the .log file<br>
<br>
Can I go back to the old JET somehow?<br>
<br>
$cott<br>
<br>
<style></style>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<blockquote
Scott,<br>
<br>
<br>
<small> if(DEBUG)
</blockquote>
<br>
<br>
<br>
<br>
<br>
direction?<br>
<br>
Sincerely,<br>
<br>
Lost In Spaces<br>
<br>
!STACK 0<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
| Re: Spaces in URLs [message #25736 is a reply to message #25714] |
Tue, 10 July 2007 20:24   |
--------------040407020405050501020909
Scott,
Although it's definitely technically a JET problem caused by using
poorly formed file: URLs (where the file: is not immediately followed by
a "/" as would be expected for a well-formed hierarchical URI as defined
in the URI RFC) rather than using more appropriate platform:/resource
URLs (more appropriate because access actually goes through the Eclipse
resource APIs rather than going to the underlying file system directly),
it's only surfaced as a visible problem because of late breaking
changes in EMF's URIConverterImpls' support for Eclipse File System
APIs. (That's a long way of saying that it's "kind of" EMF's fault that
you're having a problem and even going back to old JET2 will not avoid
it.) The best way to avoid this would be not to have a space in your
project name. I hope it doesn't sound rude, but what compelled you to
use a space in your project name anyway? Doing so is really an
invitation for problems in the first place. Could you change things to
get rid of that nasty space? It's just generally not a good idea to use
characters like "%" or " " in a resource name. Any character that has
special meaning in other contexts is best avoided in a resource name, so
perhaps it's best to make changes to avoid this problem now and forever...
> $cott
> Paul Elder wrote:
>> Scott:
>> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& version=unspecified&component=Jet&rep_platform=PC&am p;op_sys=Windows%20XP&priority=P3&bug_severity=norma l&bug_status=NEW&bug_file_loc=http%3A%2F%2F&shor t_desc=&comment=&commentprivacy=0&keywords=& dependson=&blocked=&maketemplate=Remember%20values%2 0as%20bookmarkable%20template&form_name=enter_bug&as signed_to=m2t.jet-inbox%40eclipse.org
>> < https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& version=unspecified&component=Jet&rep_platform=PC&am p;op_sys=Windows%20XP&priority=P3&bug_severity=norma l&bug_status=NEW&bug_file_loc=http%3A%2F%2F&shor t_desc=&comment=&commentprivacy=0&keywords=& dependson=&blocked=&maketemplate=Remember%20values%2 0as%20bookmarkable%20template&form_name=enter_bug&as signed_to=m2t.jet-inbox%40eclipse.org>
>> Thx,
>> Paul
>> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
>> message news:f6u5ia$6v0$1@build.eclipse.org...
>> Scott,
>> FinishLynx/plugin.xml" is being created, but it should be of the
>> form "file:/C:/projects/regatta-workbench/workspace/RW
>> FinishLynx/plugin.xml" (note the / after the file:) to be a
>> proper hierarchical URI. Perhaps this worked in the past because
>> why this code wouldn't be using "platform:/resource/RW
>> FinishLynx/plugin.xml" instead, because that would seem the
>> proper way to access something in the workspace; using a file:
>> if(DEBUG)
>> project + ")"); //$NON-NLS-1$ //$NON-NLS-2$
>> try
>> //$NON-NLS-3$
>> //$NON-NLS-1$
>>> workspace. Now my .log file is filling up with many, many
>>> messages like the one below --- one for each project in my
>>> workspace. They are generated during my workspace automatic
>>> direction?
>>> Sincerely,
>>> Lost In Spaces
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 21 more
<html>
<head>
</head>
Scott,<br>
<br>
by a "/" as would be expected for a well-formed hierarchical URI as
defined in the URI RFC) rather than using more appropriate
platform:/resource URLs (more appropriate because access actually goes
through the Eclipse resource APIs rather than going to the underlying
file system directly), it's only surfaced as a visible problem because
of late breaking changes in EMF's URIConverterImpls' support for
Eclipse File System APIs. (That's a long way of saying that it's "kind
of" EMF's fault that you're having a problem and even going back to old
JET2 will not avoid it.) The best way to avoid this would be not to
have a space in your project name. I hope it doesn't sound rude, but
what compelled you to use a space in your project name anyway? Doing so
is really an invitation for problems in the first place. Could you
change things to get rid of that nasty space? It's just generally not
a good idea to use characters like "%" or " " in a resource name. Any
character that has special meaning in other contexts is best avoided in
a resource name, so perhaps it's best to make changes to avoid this
problem now and forever...<br>
<br>
<br>
Scott Dybiec wrote:
<blockquote cite="mid:f710ag$ovs$1@build.eclipse.org" type="cite">
<br>
<br>
<br>
$cott<br>
<br>
<style></style>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<blockquote
Scott,<br>
<br>
<br>
<small> if(DEBUG)
</blockquote>
<br>
<br>
<br>
<br>
<br>
right
direction?<br>
<br>
Sincerely,<br>
<br>
Lost In Spaces<br>
<br>
!STACK 0<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
--------------040407020405050501020909--
| Re: Spaces in URLs [message #25860 is a reply to message #25736] |
Wed, 11 July 2007 07:25   |
<html>
<head>
</head>
Thanks for that clear and complete response. I understand the bug
better now.<br>
<br>
My comments are interspersed below.<br>
<br>
$cott<br>
<br>
Ed Merks wrote:
<blockquote cite="mid:f717vi$i8v$1@build.eclipse.org" type="cite">
Scott,<br>
<br>
have a space in your project name.</blockquote>
If I understand you, then this means that a poorly formed file: URL
by a "/" ) without spaces will resolve properly, but one with spaces
will not. Right?
<blockquote cite="mid:f717vi$i8v$1@build.eclipse.org" type="cite"> I
what compelled you to use a space in your project name anyway?</blockquote>
Names with spaces seemed more readable, especially with so many
projects in my Package Explorer tree. At the time I created most of
these these 100 or so projects, I had no clue that some plugins would
break due to spaces in project names. <br>
Doing so
change things to get rid of that nasty space?</blockquote>
It's a little daunting to imagine the amount of time it would take to
individually refactor/rename each project individually, given that my
workspace is running painfully slow right now, due to the bug. I'll
look into my options -- something like a mass project rename script.<br>
</blockquote>
Got it. If spaces are considered bad/risky practice for
use in Project Names, then perhaps the New Project Wizard should have a
warning or error for this. My workspace has had projects with spaces
since the
Eclipse 2.1 days. Sound like a bug I should submit to the Eclipse
Platform project?<br>
<br>
$cott<br>
<blockquote cite="mid:f717vi$i8v$1@build.eclipse.org" type="cite"><br>
<br>
<br>
<br>
<br>
$cott<br>
<br>
<style></style>
<div> </div>
Can
<div> </div>
<div> </div>
<div> </div>
<blockquote
Scott,<br>
<br>
<br>
<small> if(DEBUG)
plugin.xml");
</blockquote>
<br>
type="cite">I
<br>
<br>
<br>
<br>
right
direction?<br>
<br>
Sincerely,<br>
<br>
Lost In Spaces<br>
<br>
!STACK 0<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
| Re: Spaces in URLs [message #25905 is a reply to message #25860] |
Wed, 11 July 2007 08:01   |
--------------000801000203060505060205
Scott,
Comments below.
> better now.
> $cott
> Ed Merks wrote:
>> Scott,
>> goes through the Eclipse resource APIs rather than going to the
>> underlying file system directly), it's only surfaced as a visible
>> problem because of late breaking changes in EMF's URIConverterImpls'
>> support for Eclipse File System APIs. (That's a long way of saying
>> that it's "kind of" EMF's fault that you're having a problem and even
>> going back to old JET2 will not avoid it.) The best way to avoid
>> this would be not to have a space in your project name.
> (where the file: is not immediately followed by a "/" ) without spaces
> will resolve properly, but one with spaces will not. Right?
EMF's URI class tests isFile like this:
public boolean isFile()
return isHierarchical() &&
((isRelative() && !hasQuery()) ||
SCHEME_FILE.equalsIgnoreCase(scheme));
A URI is hierarchical only if there is a "/" immediately after the colon
following the scheme. If the isFile tests fails, then the URI converter
will not treat it as a file URI. In that past, this would mean it would
be treated as just a URL, but in EMF 2.3, we first test if the scheme of
the URI is one that EFS supports and if so, we delegate to EFS to access
the data. At that point we need to construct a java.net.URI and it's
java.net.URI that refuses to accept a space. If the space had been
properly encoded as %20 that wold have worked fine. (It's kind of a sad
thing that a URL can't always be converted to a URI.)
>> I hope it doesn't sound rude, but what compelled you to use a space
A project whose name matches the plugin ID would seem better. Dot
qualified names are pretty easy to read...
>> Doing so is really an invitation for problems in the first place.
>> Could you change things to get rid of that nasty space?
Perhaps you can turn off auto build while doing the refactoring?
>> It's just generally not a good idea to use characters like "%" or "
>> " in a resource name. Any character that has special meaning in
>> other contexts is best avoided in a resource name, so perhaps it's
> Got it. If spaces are considered bad/risky practice for use in Project
> Names, then perhaps the New Project Wizard should have a warning or
> error for this. My workspace has had projects with spaces since the
> Platform project?
I doubt they will take such a problem very seriously, since downstream
code should not break as a result (although it often does). Even
Eclipse 3.3 shipped a version of ANT for which on Linux a space in the
install location causes ANT to malfunction. :-( But it's perhaps worth
a try. Sorry for the hassle...
> $cott
>>> update/build process that throws lots of errors into the .log file
>>> $cott
>>> Paul Elder wrote:
>>>> Scott:
>>>> Thx,
>>>> Paul
>>>> in message news:f6u5ia$6v0$1@build.eclipse.org...
>>>> Scott,
>>>> the form "file:/C:/projects/regatta-workbench/workspace/RW
>>>> because createURLInputStream was invoked where really
>>>> with 2.3, createEFSInputStream is used instead. I'm confused
>>>> though why this code wouldn't be using "platform:/resource/RW
>>>> if(DEBUG)
>>>> try
>>>> //$NON-NLS-3$
>>>> //$NON-NLS-1$
>>>>> direction?
>>>>> Sincerely,
>>>>> Lost In Spaces
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 21 more
<html>
<head>
<title></title>
</head>
Scott,<br>
<br>
Comments below.<br>
<br>
<br>
Scott Dybiec wrote:
<blockquote cite="mid:f72emu$j54$1@build.eclipse.org" type="cite">
better now.<br>
<br>
<br>
$cott<br>
<br>
Scott,<br>
<br>
will not. Right?</blockquote>
EMF's URI class tests isFile like this:<br>
<blockquote><small> public boolean isFile()</small><br>
<small> return isHierarchical() &&</small><br>
<small> ((isRelative() && !hasQuery()) ||
SCHEME_FILE.equalsIgnoreCase(scheme));</small><br>
</blockquote>
colon following the scheme. If the isFile tests fails, then the URI
converter will not treat it as a file URI. In that past, this would
mean it would be treated as just a URL, but in EMF 2.3, we first test
if the scheme of the URI is one that EFS supports and if so, we
delegate to EFS to access the data. At that point we need to construct
a java.net.URI and it's java.net.URI that refuses to accept a space. If
the space had been properly encoded as %20 that wold have worked fine.
(It's kind of a sad thing that a URL can't always be converted to a
URI.)<br>
<br>
</blockquote>
qualified names are pretty easy to read...<br>
<blockquote cite="mid:f717vi$i8v$1@build.eclipse.org" type="cite">Doing
so
</blockquote>
Perhaps you can turn off auto build while doing the refactoring?<br>
</blockquote>
since the
</blockquote>
a try. Sorry for the hassle...<br>
<blockquote cite="mid:f72emu$j54$1@build.eclipse.org" type="cite"><br>
$cott<br>
<br>
<br>
<br>
<br>
$cott<br>
<br>
<style></style>
<div> </div>
Can
<div> </div>
<div> </div>
<div> </div>
<blockquote
Scott,<br>
<br>
<br>
<small> if(DEBUG)
plugin.xml");
</blockquote>
<br>
type="cite">I
<br>
<br>
<br>
<br>
right
direction?<br>
<br>
Sincerely,<br>
<br>
Lost In Spaces<br>
<br>
!STACK 0<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
--------------000801000203060505060205--
| Re: Spaces in URLs [message #26030 is a reply to message #25714] |
Wed, 11 July 2007 11:46  |
------=_NextPart_000_001D_01C7C3B1.23702BD0
Scott:
I do not have any workaround (other than removing spaces from your =
workspace path/project name), but I am working on a fix.
I'll post here once an integration build is available to fix.
Paul
"Scott Dybiec" <scott@humanfactor.com> wrote in message =
news:f710ag$ovs$1@build.eclipse.org...
Is there a workaround for this bug? My Eclipse 3.3 is unusably slow =
right now --- e.g. saving any file leads to a 5-8 minute update/build =
$cott
Paul Elder wrote:=20
Scott:
This is definitely a JET bug. Can you submit a bugzilla. The =
Thx,
Paul
Scott,
if(DEBUG) =
try
=20
//$NON-NLS-1$
//$NON-NLS-1$
I installed Eclipse 3.3 and pointed it to my Eclipse 3.2 =
workspace. Now my .log file is filling up with many, many messages like =
the one below --- one for each project in my workspace. They are =
generated during my workspace automatic incremental builds. These builds =
now take a very long time - much longer than under 3.2.
One thing I've noticed: It seem to be happening with projects =
that have names with spaces in them, such as the one below:=20
"C:/projects/regatta-workbench/workspace/RW =
direction?
Sincerely,
Lost In Spaces
!STACK 0
at =
at =
at =
152)
at =
Loader.java:151)
at =
Loader.java:131)
at =
at =
at =
at =
67)
at =
76)
at =
48)
at =
at =
at =
nager.java:282)
at =
at =
anager.java:276)
at =
at =
ce.java:311)
at =
:1018)
at =
at =
Caused by: java.net.URISyntaxException: Illegal character in =
opaque part at index 47: file:C:/projects/regatta-workbench/workspace/RW =
at =
... 21 more
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3132" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>I do not have any workaround (other =
than removing=20
spaces from your workspace path/project name), but I am working on a=20
fix.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I'll post here once an integration =
build is=20
available to fix.</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Scott Dybiec" <<A=20
href=3D"mailto:scott@humanfactor.com">scott@humanfactor.com</A>> =
wrote in=20
message <A=20
href=3D"news:f710ag$ovs$1@build.eclipse.org">news:f710ag$ovs$1@build.ecli=
pse.org</A>...</DIV><BR>Is=20
right=20
process that=20
throws lots of errors into the .log file<BR><BR>Can I go back to the =
old JET=20
somehow?<BR><BR>$cott<BR><BR>Paul Elder wrote:=20
<BLOCKQUOTE cite=3Dmid:f6u6uu$a7f$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>This is definitely a JET bug. Can =
you submit a=20
bugzilla. The following link setup of most of the =
<DIV> </DIV>
ame=3Denter_bug&assigned_to=3Dm2t.jet-inbox%40eclips e.org "=20
moz-do-not-send=3D"true">https://bugs.eclipse.org/bugs/enter_bug.cgi?prod=
uct=3DM2T&version=3Dunspecified&component=3D Jet&rep_platform=3D=
PC&op_sys=3DWindows%20XP&priority=3DP3&a mp;bug_severity=3Dnormal&=
amp;bug_status=3DNEW&bug_file_loc=3Dhttp%3A%2F%2F&am p;amp;short_desc=3D&a=
mp;comment=3D&commentprivacy=3D0&keywords=3D &dependson=3D&=
;blocked=3D&maketemplate=3DRemember%20values%20as%20 bookmarkable%20te=
mplate&form_name=3Denter_bug&assigned_to=3Dm 2t.jet-inbox%40eclips=
e.org</A></FONT></DIV>
<DIV> </DIV>
<DIV> </DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A href=3D"mailto:merks@ca.ibm.com"=20
moz-do-not-send=3D"true">merks@ca.ibm.com</A>> wrote in message =
<A=20
href=3D"news:f6u5ia$6v0$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:f6u5ia$6v0$1@build.eclipse.org</A>...</DIV>=
</A>=20
FinishLynx/plugin.xml</TT>" is being created, but it should be of =
the form=20
W</A>=20
proper=20
createURLInputStream was invoked where really =
createFileInputStream is=20
what should be kicking in but now, with 2.3, createEFSInputStream =
is used=20
instead. I'm confused though why this code wouldn't be using =
because=20
that would seem the proper way to access something in the =
workspace; using=20
a file: URI for that will bypass the workspace and access the =
underlying=20
file system directly instead...<BR><BR>I'll add the M2T newsgroup =
to the=20
reply since this appears to be a JET2 problem in this code:<BR>
if(DEBUG) =
System.out.println("PluginProjectMonitor.updateProject(" +=20
project + ")"); //$NON-NLS-1$=20
projectURL =3D=20
new URL("file", "", project.getLocation() + "/"); //$NON-NLS-1$=20
//$NON-NLS-2$=20
//$NON-NLS-3$</SMALL><BR><SMALL> =
final=20
=20
;=20
;=20
oExternalForm(),=20
<BLOCKQUOTE cite=3Dmid:f6u3jd$2h0$1@build.eclipse.org =
type=3D"cite">I=20
workspace. Now my=20
below ---=20
one for each project in my workspace. They are generated during =
my=20
workspace automatic incremental builds. These builds now take a =
very=20
long time - much longer than under 3.2.<BR><BR>One thing I've =
noticed:=20
It seem to be happening with projects that have names with =
spaces in=20
FinishLynx/plugin.xml"<BR><BR></TT>Perhaps it's similar in some =
way to=20
this: <A class=3Dmoz-txt-link-freetext=20
63.html"=20
Illegal character in opaque part at index 47: <A=20
/A>=20
Illegal=20
/A>=20
at=20
at=20
152)<BR> =20
at=20
at=20
at=20
at=20
at=20
at=20
67)<BR> =20
at=20
76)<BR> =20
at=20
48)<BR> =20
at=20
at=20
at=20
at=20
p; =20
at=20
at=20
at=20
at=20
:1018)<BR> =20
at=20
> =20
at=20
at =
org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)<BR >Caused=20
part at=20
index 47: <A class=3Dmoz-txt-link-freetext=20
/A>=20
java.net.URI$Parser.fail(Unknown Source)<BR> =
at=20
java.net.URI$Parser.checkChars(Unknown =
Source)<BR> at=20
java.net.URI$Parser.parse(Unknown Source)<BR> =
at=20
java.net.URI.<init>(Unknown Source)<BR> =
at=20
... 21=20
more</TT><BR><BR><BR></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE ><BR></BLO=
CKQUOTE></BODY></HTML>
------=_NextPart_000_001D_01C7C3B1.23702BD0--
Current Time: Fri Nov 07 05:17:44 EST 2025
Powered by FUDForum. Page generated in 0.27488 seconds
