Home » Newcomers » Newcomers » Instantiate object in an other plugin
Instantiate object in an other plugin [message #257775] Sat, 07 June 2008 12:36 Go to next message
Originally posted by: zsolt.zszs.hu
I run into another problem with my GenericPlugin strategy:
In GenericPlugin I've a CommandFactory
public class CommandFactory {
public static GenericCommand createCommand(
Class<? extends GenericCommand> commandClass ) {
//instantiate command with reflection
This factory works fine with commands defined in GenericPlugin but throws
ClassNotFoundException if the command is defined in SpecificPlugin which
depends on the GenericPlugin. In SpecificPlugin's manifest.mf I added:
Export-Package:
hu.itkodex.specifiplugin.commands
but it doesn't helped.
Generally I'm confused what are the visiblity constrants between plugins.
One plugin can see only classes from it's dependents plugins?
What about extension point? If I define a ICommandFactory extension point
in Generic plugin than I can request extenders to instantiate commands
defined in their plugin. This seems to be ugly.
What is your suggestion?
Thanks in advance,
Zsolt
Re: Instantiate object in an other plugin [message #257797 is a reply to message #257775] Sat, 07 June 2008 13:20 Go to previous messageGo to next message
Zsolt,
Generally a plugin can't see classes in downstream plugins (that depend
on it) but rather only in upstream ones.
> public static GenericCommand createCommand( Class<? extends
> throws ClassNotFoundException if the command is defined in
> SpecificPlugin which depends on the
But you already have a class instance so what class isn't found?
> Export-Package: hu.itkodex.specifiplugin.commands
> plugins. One plugin can see only classes from it's dependents plugins?
> point in Generic plugin than I can request extenders to instantiate
> commands defined in their plugin. This seems to be ugly.
Extensions support creating an instance and that instance is created by
the extending plugin...
I'm confused by what class isn't found...
> Thanks in advance,
> Zsolt
Re: Instantiate object in an other plugin [message #257824 is a reply to message #257797] Sat, 07 June 2008 16:37 Go to previous message
Ed,
you are right. I did not read the stack trace thoroughly. It wasn't the
problem of instantiating the class given by the parameter, it was the
problem that SpecificPlgin doesn't saw the Logger class from Log4J
library, which is refered in the constructor of the class in question.
My conclusion is that the visibility of classes between different plguins
depends only the Export-Package declaration in manifest.mf file.
Thanks for your help,
Zsolt
Previous Topic:Re: How to adjust Section size?
Next Topic:Is it possible to add a List to a Section?
Current Time: Sun Nov 09 01:36:03 EST 2025
Powered by FUDForum. Page generated in 0.09728 seconds
