why IdataExtractionTask.getResultSetList( ); rerurns ONLY ONE ResultSet? [message #257713] |
Tue, 09 October 2007 17:16  |
Originally posted by: titaniumcity.yahoo.com
Hi All,
I am working on converting an existing birt reports ( developed by some
other engineer) in to CSV format. These reports have multiple data sources
fecting data from MYSQL DB from diffrent tables and reports have lots of
nested grids/ nested tables with their own Data Sources. With this, if
I try to extract the data using IdataExtractionTask.getResultSetList( );
it returns me only one result set item associated to the most outer table
on the birt report. The following code would print ONLY ONE
ResultSetName ====> G2SpeedDS!!!! All other nested table Data sources
will not be printed here at all.
So,ArrayList resultSetList = (ArrayList)dataTask.getResultSetList( );
would have just one element in it.
The question is how can I get hold of /extract all the data sources or
data on the report?
I appreciate your help.
Thank You
Bob
======= Code snippet =====================
static void extractData(IReportEngine engine, IReportDocument document,
Locale locale ) throws Exception
IDataExtractionTask dataTask = null;
IExtractionResults result = null;
IDataIterator iData = null;
try
dataTask = engine.createDataExtractionTask( document );
int q =0 ;
IResultSetItem resultItem = null;
Iterator it = resultSetList.iterator();
while (it.hasNext()) {
resultItem = (IResultSetItem)it.next();
System.out.println("ResultSetName ====> " +
resultItem.getResultSetName( ));
dataTask.selectResultSet(resultItem.getResultSetName( ));
dataTask.selectColumns( columnNames );
dataTask.setLocale( locale );
======= Code snippet ends =====================
Re: why IdataExtractionTask.getResultSetList( ); rerurns ONLY ONE ResultSet? [message #258412 is a reply to message #257713] |
Mon, 15 October 2007 14:05  |
Bob,
It looks like you are using the DataExtraction interface, which works on
only one dataset at a time. I believe that what you want to do is use the
Report Emitter interface which works across the entire report. In order
use the ReportEmitter to generate a CSV file you will need to create your
own CSV Emitter using the Emitter API.
There is an example of this in the book Integrating and Extending BIRT, Vol.
2.
Scott Rosenbaum
> data on the report? I appreciate your help.
FUDForum. Page generated in 0.48042 seconds
