Home » Archived » BIRT » max rows within crosstab
max rows within crosstab [message #257587] Mon, 08 October 2007 17:13 Go to next message
Originally posted by: mimi_huhu.hotmail.com
Is it just me or ... ?
I was create a crosstab w/ possible more than 50 rows; however, it seems
to me my rows been truncate to 50 rows only. (some data is miss).
I check from my data source, there data are there correctly.
is it possible a bug?
Re: max rows within crosstab [message #257603 is a reply to message #257587] Mon, 08 October 2007 21:53 Go to previous messageGo to next message
Hi Ray
Are you using the All-in-One build and preview in layout. There is a max
levels display setting in your eclipse's preference
Windows->Preference->Report Design->Preview->Data->Maximum member count of
each level to display=50
The default value is 50, you can modify it as you want and the limit only
works on the layout preview, if you want to display all the levels you can
preview in web viewer.
Regards!
Re: max rows within crosstab [message #257826 is a reply to message #257603] Wed, 10 October 2007 11:18 Go to previous message
I am using RCP Designer; however, the setting part is the same.
thanks so much. It works.
:D
You rock!
Previous Topic:Is cross tab field support expression?
Next Topic:Best Way to Hide and Disable a Chart/Table?
Current Time: Tue Nov 18 04:08:30 EST 2025
Powered by FUDForum. Page generated in 0.04196 seconds
