Home » Language IDEs » Java Development Tools (JDT) » Writing to console
Writing to console [message #257421] Mon, 17 November 2008 15:43 Go to next message
Originally posted by: gdind2003.gmail.com
I am able to write to console as shown in this article :
http://wiki.eclipse.org/FAQ_How_do_I_write_to_the_console_fr om_a_plug-in_%3F.
How do I now put colors and different fonts, and hyper links?
Thanks in advance,
--Gautam
Re: Writing to console [message #257505 is a reply to message #257421] Wed, 19 November 2008 18:45 Go to previous messageGo to next message
Hello G Dev,
You could create MessageConsoleStreams as the inherited IOConsole class
provides. This lets you set color and font for each message stream.
Hyperlinks are supported by the MessageConsole itself. Please see the code
example below for further details.
MessageConsole myConsole = findConsole("Foo");
MessageConsoleStream purpleStream = myConsole.newMessageStream();
MessageConsoleStream blueStream = myConsole.newMessageStream();
Color purple = new Color(Display.getCurrent(), 160, 32, 140);
Color blue = new Color(Display.getCurrent(), 0, 0, 255);
purpleStream.setColor(purple);
blueStream.setColor(blue);
try {
myConsole.getDocument().set("Save the eels.\r\n");
purpleStream.write("The Purple Fox \r\n");
blueStream.write("Jumped over the blue bear");
myConsole.addHyperlink(new MyHyperLink(), 9, 4);
} catch (IOException e) {
e.printStackTrace();
} catch (BadLocationException e) {
} finally {
purpleStream.close();
blueStream.close();
BR David.
Purple Scout / www.purplescout.com
"G Dev" <gdind2003@gmail.com> wrote in message
news:gfsl1q$edi$1@build.eclipse.org...
> Thanks in advance,
> --Gautam
Re: Writing to console [message #257588 is a reply to message #257505] Mon, 24 November 2008 00:41 Go to previous message
Originally posted by: fastcodejava.gmail.com
Hi David,
The color portion of your code worked fine. But the link is not working.
I did something like :
messageConsole.addHyperlink(new FileLink(file,
"org.eclipse.jdt.ui.CompilationUnitEditor", 0, 1, 0), 0, 10).
Code compiles, but no hyper link effect is showing. I am not how to put
the offset and length for the addHyperlink method.
--Gautam
http://fast-code.sourceforge.net/
David Virdefors wrote:
> Hello G Dev,
> try {
> } finally {
> blueStream.close();
> BR David.
>> Thanks in advance,
>> --Gautam
Previous Topic:Build error of jar file : Resource is out of sync with the file system
Next Topic:Custom Developed Editor only contains "ERROR" if used to open external file
Current Time: Fri Jul 18 00:24:40 EDT 2025
Powered by FUDForum. Page generated in 0.07990 seconds
