Home » Eclipse Projects » Eclipse Platform » eclipse close lifttime
eclipse close lifttime [message #257381] Thu, 01 July 2004 04:25 Go to next message
Originally posted by: naficbm.1net.gr
hello,I have a plugin which does some work
in a long running background
thread.
This plugin include two ViewPart, The two
ViewPart shared this background thread.
When the user closes the workbench (by clicking X, not the
QuitAtion),I want to stop this thread, before
workbench close.
who may give me some hint.
thanks in advance.
Re: eclipse close lifttime [message #257422 is a reply to message #257381] Thu, 01 July 2004 07:14 Go to previous messageGo to next message
Originally posted by: gerhard.kainz.knowing.at
eclipse calls
* @see org.eclipse.ui.IViewPart#saveState(org.eclipse.ui.IMemento)
public void saveState (IMemento memento)
in your view before exiting, there you can place clean up code , atr least
this worked for me.
gerhard
"mastiff_cm" <naficbm@1net.gr> schrieb im Newsbeitrag
news:cc0ho5$ra0$1@eclipse.org...
> thread.
> workbench close.
> thanks in advance.
Re: eclipse close lifttime [message #257430 is a reply to message #257381] Thu, 01 July 2004 07:57 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
If you are in eclipse 3.0, look at the job API provided in runtime.
PaScaL
> thread.
> workbench close.
> thanks in advance.
Re: eclipse close lifttime [message #259882 is a reply to message #257381] Thu, 08 July 2004 17:43 Go to previous message
Originally posted by: john.eclipsefaq.org
I think your best bet is to maintain a counter of the number of open
workbench windows. You can update the counter by adding an
IWindowListener to IWorkbench. When the counts reaches zero, all windows
are closed, and the application is about to exit. You can then cancel or
join the background thread.
The only other approach I can think of is a workspace ISaveParticipant.
Save participants get a chance to run before the workbench exits. Look
up ISaveParticipant in the help system for more details. This will not
be available in an RCP application.
> thread.
> workbench close.
> thanks in advance.
Previous Topic:How to jump into function implementation
Next Topic:dependent Java projects and classpath problems...
Current Time: Tue Oct 21 06:09:58 EDT 2025
Powered by FUDForum. Page generated in 0.04289 seconds
