Home » Newcomers » Newcomers » Problem Occured: Match Job
Problem Occured: Match Job [message #257329] Wed, 28 May 2008 10:32 Go to next message
Originally posted by: cmattmiller.gmail.com
I keep getting this error while building and deploying build.xml with Ant
in the Java EE perspective.
An internal error occurred during: "Match Job".
Any ideas as to what I am doing wrong or maybe have configured wrong?
Re: Problem Occured: Match Job [message #257335 is a reply to message #257329] Wed, 28 May 2008 10:48 Go to previous message
Originally posted by: codeslave.ca.ibm.com
A quick google for the error message yields some related issues:
http://jira.codehaus.org/browse/GROOVY-2189
http://osdir.com/ml/ide.eclipse.plugins.radrails/2006-09/msg 00218.html
which suggests to me that you're running an ant task for which there's a
missing attribute or subtask... or maybe you're trying to run a process
on an empty set (eg., zipping some files from a non-existent dir, moving
some files from a <fileset> that is empty, running a mapper on some
files which don't exist, etc.)
If that's not helpful, try posting this to the Apache Ant newsgroup /
mailing list.
> Ant in the Java EE perspective.
> java.lang.NullPointerException
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Previous Topic:Adding jar to system library
Next Topic:Loading a code style profile into the workspace config
Current Time: Mon Jul 21 23:58:12 EDT 2025
Powered by FUDForum. Page generated in 0.35781 seconds
