Home » Eclipse Projects » Eclipse Platform » Rich Client Tutorial Part 3 code failed on Eclipse 3.0
Rich Client Tutorial Part 3 code failed on Eclipse 3.0 [message #257273] Wed, 30 June 2004 18:42 Go to next message
Originally posted by: id.net.com
The RCP workbench failed to start with error
Unhandled event loop exception
Reason:
If I comment out the
configurer.setShowCoolBar(false);
from the RcpWorkbenchAdvisor.java, the workbench starts fine.
Something has changed between M9 and 3.0 that caused this exception. Any
help would appreciate.
-Beth
Re: Rich Client Tutorial Part 3 code failed on Eclipse 3.0 [message #257280 is a reply to message #257273] Wed, 30 June 2004 19:13 Go to previous messageGo to next message
It works for me. Is it possible you have an old copy of the tutorial source
code? The code underwent changes as the Eclipse APIs changed underneath it.
You can check out the latest copy that was tested with 3.0 production from:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ui.tuto rials.rcp.part3/
using CVS as described in http://dev.eclipse.org/cvshowto.html . (change
part3 to part2 or part1 for the other parts).
Ed Burnette, co-author, Eclipse in Action
www.eclipsepowered.org
"Beth" <id@net.com> wrote in message news:cbvfkm$6co$1@eclipse.org...
> Reason:
> java.lang.NullPointerException
Re: Rich Client Tutorial Part 3 code failed on Eclipse 3.0 [message #257303 is a reply to message #257280] Wed, 30 June 2004 20:45 Go to previous messageGo to next message
Thanks for your quick response. I found out that I have add
configurer.setShowPerspectiveBar(true);
to the Part 3 code. After the configurer.setShowCoolBar(false);
It seems the workbench only starts when I commented out one of these two
calls. Any idea why?
-Beth
"Ed Burnette" <ed.burnette@sas.com> wrote in message
news:cbvhcq$8p7$1@eclipse.org...
source
it.
> > Reason:
Re: Rich Client Tutorial Part 3 code failed on Eclipse 3.0 [message #257630 is a reply to message #257303] Thu, 01 July 2004 16:03 Go to previous messageGo to next message
Oh I see. You have something like this:
public void preWindowOpen(IWorkbenchWindowConfigurer configurer) {
super.preWindowOpen(configurer);
configurer.setInitialSize(new Point(400, 300));
configurer.setShowPerspectiveBar(true); // <== Line you added
configurer.setShowStatusLine(false);
configurer.setTitle(Messages.getString("Hello_RCP")); //$NON-NLS-1$
It's failing because, by default, the perspective bar is up top on the same
line as the cool bar and it's calculating its height in terms of the
(non-existant) cool bar. Please enter a bugzilla against platform-ui
including the entire traceback from the log and steps to reproduce.
The workaround is to leave the cool bar on, or the perspective bar off, or
maybe to move the perspective bar somewhere else with a preference setting.
See the RCP Browser sample for an example of setting a preference with the
org.eclipse.ui.runtime.products extension's preferenceCustomization
property. It's also documented in the online help.
Ed
"Beth" wrote in message news:cbvmr3$g37$1@eclipse.org...
> -Beth
Re: Rich Client Tutorial Part 3 code failed on Eclipse 3.0 [message #257661 is a reply to message #257630] Thu, 01 July 2004 17:55 Go to previous messageGo to next message
Yes, that's the line I added. It was working on M9 and broken when we move
to Eclipse 3.0.
I will try your workaround to move the perspective bar to the right. We
don't want to show
the cool bar.
Thank you very help for your help.
-Beth
news:cc1qlq$7ha$1@eclipse.org...
same
setting.
> Ed
> > -Beth
Re: Rich Client Tutorial Part 3 code failed on Eclipse 3.0 [message #259290 is a reply to message #257661] Wed, 07 July 2004 13:19 Go to previous message
Originally posted by: nick_edgar._no.spam.please_.ca.ibm.com
Unfortunately this is a bug that was introduced late in the game, and not
detected before we shipped 3.0.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=68774
It has been fixed in the HEAD stream, and the fix is also tagged for
inclusion in 3.0.1.
Nick
"Beth" <id@net.com> wrote in message news:cc218j$hfe$1@eclipse.org...
> to Eclipse 3.0.
> don't want to show
> the cool bar.
> -Beth
> same
or
> setting.
the
> > Ed
two
> > > -Beth
Previous Topic:RCP and user roles (or how to make non-ui plugin to provide a selection?)
Next Topic:Exporting Plugin Projects
Current Time: Sat Nov 08 03:54:53 EST 2025
Powered by FUDForum. Page generated in 0.04024 seconds
