error while starting Eclipse as runtime-workbench [message #257241] |
Wed, 30 June 2004 16:21  |
Originally posted by: franz.hoyer.franzhoyer.de
When I try to launch Eclipse inside Eclipse for a debug session I get the
following error:
I try to run it on a windows xp machine.
!SESSION Jun 30, 2004
22:16:34.234 ---------------------------------------------
eclipse.buildId=unknown
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -application org.eclipse.ui.ide.workbench
!ENTRY org.eclipse.osgi Jun 30, 2004 22:16:34.250
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: no swt-carbon-3062 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.graphics.Device.init(Device.java:564)
at org.eclipse.swt.widgets.Display.init(Display.java:1780)
at org.eclipse.swt.graphics.Device.<init>(Device.java:100)
at org.eclipse.swt.widgets.Display.<init>(Display.java:355)
at org.eclipse.swt.widgets.Display.<init>(Display.java:351)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:278)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:153)
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java
:122)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:72)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Re: error while starting Eclipse as runtime-workbench [message #257265 is a reply to message #257261] |
Wed, 30 June 2004 17:59  |
just found a way to solve it, I am not sure if it is the best way to do it
but it works.
I copied the right swt.jar (the one for win32) into the org.eclipse.swt.bin
directory. It seems that puts the swt.jar in the classpath and now eclipse
uses at startup that library.
"Franz Hoyer" <franz.hoyer@franzhoyer.de> schrieb im Newsbeitrag
news:cbvceb$1ga$1@eclipse.org...
> well I have all different kinds of swt.jar for all different platforms.
How
> can i tell eclipse to use the one for win32 ? I thought the startup
> parameter points eclipse to the right swt ?
> I start with -os win32 -ws win32 -arch x86 -nl de_DE
> where or how can i tell eclipse to load the one for win32 and not the
carbon
> "Pascal Rapicault" <pascal@ibm.canada> schrieb im Newsbeitrag
> news:cbvarj$trq$1@eclipse.org...
> > It looks like you do not have the correct version of swt.jar since you
> > are on a XP platform, but the library being loaded is "carbon" (macos).
> > Make sure that you have the proper version of SWT.
> > PaScaL
> the
> > > following error:
> > > !STACK 1
java.library.path
> > > at
> > > at
> > > :122)
> > > at
> > > at
> > > java:335)
> > > at
> > > at
> > > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > > at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
> > > at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
> > > at java.lang.reflect.Method.invoke(Unknown Source)
FUDForum. Page generated in 0.04011 seconds
