| DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #25391] |
Thu, 11 January 2007 12:09  |
Originally posted by: last-name-first-init.yahoo.com
Using DTP 1.0, I create a connection profile to a Derby 10.1 embedded
database. Everything works as expected. But after I shut down Eclipse
and then restart it, there are no connection profiles in the Data Source
Explorer view (under Databases). Is this a known bug or am I doing
something wrong?
--Sugato
| Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #25870 is a reply to message #25694] |
Mon, 22 January 2007 17:29  |
Originally posted by: john.graham.sybase.com
Riccardo wrote:
> I had the same problem, in my Eclipse's shorcut the vm was
> IBM/Java/142/jre/bin/javaw.exe; then I changed it to: jdk1.5.0_01 and now
> DTO works fine.
> Regards
> Riccardo Cattania
This would be consistent with other reports (all have involved the IBM
VM), but no one had tested it by switching as you did to see if that
solves the problem. Thank you for this clue, and we'll be looking into it.
-- John Graham
Eclipse Data Tools Platform PMC Chair
| Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #583943 is a reply to message #25391] |
Thu, 11 January 2007 13:21  |
From the Eclipse error log (below), the problem appears to be
converting from byte to char when reading in the connection profile data.
!ENTRY org.eclipse.datatools.connectivity 4 10001 2007-01-11 12:02:21.267
!MESSAGE Error loading connection profile data.
!STACK 1
org.eclipse.core.runtime.CoreException: Error loading connection profile
data.
org.eclipse.datatools.connectivity.internal.ConnectionProfil eMgmt.loadCPs(ConnectionProfileMgmt.java:479)
org.eclipse.datatools.connectivity.internal.InternalProfileM anager.loadProfiles(InternalProfileManager.java:566)
org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getProfiles(InternalProfileManager.java:84)
!SUBENTRY 1 org.eclipse.datatools.connectivity 4 -1 2007-01-11 12:02:21.307
!STACK 0
sun.io.MalformedInputException
at sun.io.ByteToCharUTF8.convert(ByteToCharUTF8.java:262)
at sun.nio.cs.StreamDecoder$ConverterSD.convertInto(StreamDecod er.java:314)
at sun.nio.cs.StreamDecoder$ConverterSD.implRead(StreamDecoder. java:364)
at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:250)
at java.io.InputStreamReader.read(InputStreamReader.java:212)
at java.io.BufferedReader.fill(BufferedReader.java:157)
| Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #583969 is a reply to message #25428] |
Fri, 12 January 2007 14:16  |
Hi Sugato...
Can you provide some details about your environment? We've seen this kind of
issue before, but thought we had it solved.
--Brian Fitzpatrick
"Sugato Bagchi" <last-name-first-init@yahoo.com> wrote in message
news:eo5v6s$i18$1@utils.eclipse.org...
> From the Eclipse error log (below), the problem appears to be converting
> !STACK 1
> data.
> at
> at
> at
> 12:02:21.307
> !STACK 0
> at
| Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #584057 is a reply to message #25508] |
Sat, 20 January 2007 03:47  |
IBM\Java142\jre\bin\javaw.exe; then I changed it to: jdk1.5.0_01 and now
DTO works fine.
Riccardo Cattania
Brian Fitzpatrick ha scritto:
> Hi Sugato...
> --Brian Fitzpatrick
>> !STACK 1
>> data.
>> at
>> at
>> at
>> 12:02:21.307
>> !STACK 0
>> at
| Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #584136 is a reply to message #25694] |
Riccardo wrote:
> DTO works fine.
> Regards
> Riccardo Cattania
-- John Graham
FUDForum. Page generated in 0.05051 seconds
