Use of Pie chart [message #257114] |
Thu, 04 October 2007 14:13  |
Hi everyone,
I am stuck trying to produce a pie chart from the following sample data.
week product1 product2 product3
1 4000 2000 3399
2 5000 2330 2100
I want to generate a pie chart displaying the 3 products as slices
depending on the week.
So I built a data set with a parameterized query and the week as input
parameter. So for week 1 I would get 4000 for product 1, 2000 for
product 2, and 3399 for product 3. Now I want to display those numbers
as slices in the diagram, but I dont know what to put in for slize size
definition and category. Usually I can drag in the columns, however in
this case the categories definition is not contained in a column but is
the column names. Am I missing sth.
I know if I reorganize my table so that week1 and week2 is a column and
the products act as key, I can simple drag in the key column as category
and the week column as slice definition. However I need the table this
way as products are fixed and weeks grow ...
Any help is appreciated.
Thx
Philipp
Re: Use of Pie chart [message #257307 is a reply to message #257302] |
Fri, 05 October 2007 05:11   |
Thx David,
I will try that approach.
Does that mean that for pie charts I have to have my data in the format of
lets say "key - value" columns, where the value column name cant be used
as category ? So is it generally not possible to show a pie chart of
something like my example without remodelling the query ?
Philipp
David Michonneau wrote:
> You could try a union query
> select product1
> from table1
> where week=1
> union
> select product2
> from table1
> where week=1
> union
> select product3
> from table1
> where week=1;
> This will give you only one column with all your product values for week 1.
> Otherwise you can try with the SQL transform keyword on your db if it
> supports it.
> David
> "Philipp Tiedt" <philipp.tiedt@web.de> wrote in message
> news:fe3agf$toq$1@build.eclipse.org...
>> Hi everyone,
>> 1 4000 2000 3399
>> 2 5000 2330 2100
>> parameter. So for week 1 I would get 4000 for product 1, 2000 for product
>> 2, and 3399 for product 3. Now I want to display those numbers as slices
>> in the diagram, but I dont know what to put in for slize size definition
>> and category. Usually I can drag in the columns, however in this case the
>> categories definition is not contained in a column but is the column
>> and the week column as slice definition. However I need the table this way
>> Thx
>> Philipp
Re: Use of Pie chart [message #257408 is a reply to message #257307] |
Sat, 06 October 2007 03:42  |
Correct. See this enhancements in the works for the next release:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162528
David
news:184df95c249322c88895d6594b7a46c1$1@www.eclipse.org...
> Thx David,
> Philipp
>> select product1
>> from table1
>> where week=1
>> union
>> select product2
>> from table1
>> where week=1
>> union
>> select product3
>> from table1
>> where week=1;
>> 1. Otherwise you can try with the SQL transform keyword on your db if it
>> supports it.
>> Thanks,
>> David
>>> Hi everyone,
>>> 1 4000 2000 3399
>>> 2 5000 2330 2100
>>> Thx
>>> Philipp
FUDForum. Page generated in 0.04083 seconds
