| Build dir not recognized [message #257059] |
Sun, 25 May 2008 02:13  |
Originally posted by: loandbt.bigpond.com
Hello, I have a project working OK in Eclipse with Ant and am able to
build the jar file OK.
However Eclipse seems to ignore my build.xml configuration and puts all
the classes in a bin folder even though build.xml stipulates classes
folder. I can manually delete the bin folder and contents and when I run
the project Eclipse generates a new bin folder with all the classes. The
classes folder is generated by Ant but remains empty.
Can some kind person see an error in the script?
<?xml version="1.0" encoding = "UTF-8"?>
<project name="RadOnColS" default="jarfile" basedir=".">
<target name="init">
<property name ="name" value="RadOnColS"/>
<property name="src.dir" value="src"/>
<property name="build.dir" value="build"/>
<property name="classes.dir" value="${build.dir}/classes"/>
<property name="etc.dir" value="etc"/>
</target>
<target name="clean" depends="init">
<deldir dir="${build.dir}"/>
</target>
<target name="prepare" depends="init">
<mkdir dir="${classes.dir}"/>
<mkdir dir="${src.dir}"/>
</target>
<target name="compile" depends="prepare">
<javac srcdir="${src.dir}"
destdir="${classes.dir}"
debug="true"
deprecation="true"
optimize="false"/>
</target>
<target name="jarfile" depends="compile">
<jar destfile="${build.dir}/${name}.jar"
basedir="${classes.dir}"
manifest="${etc.dir}/MANIFEST.MF"/>
</target>
</project>
FUDForum. Page generated in 0.08860 seconds
