Home » Newcomers » Newcomers » Using Swing's Frame with SWT-Project included
Using Swing's Frame with SWT-Project included [message #257055] Sat, 24 May 2008 14:46
Originally posted by: alexhofi.gmx.net
Hi all,
I'm currently developing a small Java-Application with Eclipse on Mac OS
X Leopard, and plan to support different GUIs based on SWT or Swing/AWT.
But when I reference the SWT-Project (or simply reference any swt.jar as
a library), GUIs based on AWT/Swing will not work any more - even if I
don't actually use any SWT-Classes but just reference the SWT-Project.
The Window of my application will show up, but I can't focus it.
I'm not actually combining SWT and AWT code (nor using SWT_AWT or
similar), the classes using SWT or AWT get loaded on startup with a
little help of java.lang.reflect using the appropriate classname from a
static String field.
Is there any change to have the SWT libraries included and still being
able to construct a GUI based on AWT/Swing?
Thanks in advance,
Alexander Hofmann.
Previous Topic:setDoctype for outFormat does not work
Next Topic:Build dir not recognized
Current Time: Thu Nov 06 23:50:53 EST 2025
Powered by FUDForum. Page generated in 0.48590 seconds
