| Converting from JReport to BIRT Reports [message #257035] |
Thu, 04 October 2007 07:50  |
Originally posted by: sureshchandra.sahu.applabs.com
I have some JReport files and I would like to convert those to BIRT
Reports, do we have any tool which can do conversion.
Thanks in Advance,
Suresh
| Re: Converting from JReport to BIRT Reports [message #257373 is a reply to message #257035] |
Fri, 05 October 2007 18:00  |
Suresh,
I have made a couple of forays into creating converters to build BIRT reports
from other formats. Most notably Jasper and a different propietary format.
What I have found is that the differences in the model between the various
products make this a bit of a losing battle.
In other words, it is a lot of work, and the output from the converter tends
to be a fairly poorly implemented report.
For example, does JReport use styles? Yes, but JReports styles are significantly
different from BIRT styles (I think, I don't have a lot of JReport experience,
I just had a quick look at the JReports Styles page).
All that said, if you are interested in working on a JReports converter,
I would be happy to discuss it further with you.
Scott Rosenbaum
> Thanks in Advance,
> Suresh
FUDForum. Page generated in 0.05899 seconds
