Home » Newcomers » Newcomers » EXCEPTION_ACCESS_VIOLATION trying to import existing project into eclipse
EXCEPTION_ACCESS_VIOLATION trying to import existing project into eclipse [message #257024] Fri, 23 May 2008 12:52 Go to next message
Originally posted by: hlink7777.yahoo.com
Eclipse Europa version 3.3, Java 1.6
No problems using Eclipse on other projects
But trying to import an existing project into Eclipse.
File->Import->General->Existing Projects into Workspace
Import Projects box-> Select root directory-> browse to path
In Projects Box : Project appears with check in checkbox -> click Finish
Eclipse closes
A new file is created in eclipse directory titled hs_err_pid
Can't figure out error. What could be wrong? How can I fix the problem?
In hs_err_pid file :
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x083e7bfc, pid=4092,
tid=6076
# Java VM: Java HotSpot(TM) Client VM (1.6.0-b105 mixed mode)
# Problematic frame:
# C
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
T H R E A D
Current thread (0x05f63c00): JavaThread "ModalContext"
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x013ca070, EBX=0x00000000, ECX=0x00000000, EDX=0x00000000
ESP=0x08af8730, EBP=0x08af873c, ESI=0x0014ef10, EDI=0x00000000
EIP=0x083e7bfc, EFLAGS=0x00010246
Top of Stack: (sp=0x08af8730)
0x08af8730: 00000000 0014ef10 013ca070 08afa768
0x08af8740: 083d1f32 08afa764 013ca070 00000000
0x08af8750: 00000000 00000000 0014ef10 013ca070
0x08af8760: 00000000 013ca070 00000000 013ca070
0x08af8770: 013ca110 6eec84f1 013ca070 00000010
0x08af8780: 6ee40000 6eec11f2 013ca070 013ca110
0x08af8790: 6eec1210 6eec8610 013ca070 013ca0c0
0x08af87a0: 013ca070 013ca070 00000001 003a0043
Instructions: (pc=0x083e7bfc)
0x083e7bec: 89 55 10 53 8b 5d 14 56 57 85 db 75 03 8b 58 18
0x083e7bfc: 8b 03 bf 01 00 00 00 3b c7 0f 82 19 01 00 00 8b
Stack:
C
C
C
C
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j
org.tigris.subversion.javahl.SVNClient.status(Ljava/lang/Str ing;ZZZZZ)
0x05f65c00 JavaThread "Thread-6"
0x05f65800 JavaThread "Timer-2"
0x05f65000 JavaThread "Timer-1"
0x05f64400 JavaThread "Timer-0"
0x05f64000 JavaThread "Worker-7"
0x05f62800 JavaThread "Worker-3"
0x05f62400 JavaThread "Worker-2"
0x05db1c00 JavaThread "Java indexing" daemon
0x05e5fc00 JavaThread "Worker-1"
0x0453b400 JavaThread "Start Level Event Dispatcher" daemon
0x0453a800 JavaThread "Framework Event Dispatcher" daemon
0x0453a000 JavaThread "State Data Manager" daemon
0x017b5400 JavaThread "Low Memory Detector" daemon
0x017b4400 JavaThread "CompilerThread0" daemon
0x017b3c00 JavaThread "Attach Listener" daemon
0x017b3400 JavaThread "Signal Dispatcher" daemon
0x017a1400 JavaThread "Finalizer" daemon
0x01798800 JavaThread "Reference Handler" daemon
0x01898400 JavaThread "main"
Other Threads:
0x01795800 VMThread [id=328]
0x017d0800 WatcherThread [id=5936]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 2944K, used 296K [0x10020000, 0x10350000,
0x12780000)
eden space 2624K, 3% used [0x10020000, 0x10036378, 0x102b0000)
from space 320K, 64% used [0x10300000, 0x10333de8, 0x10350000)
to space 320K, 0% used [0x102b0000, 0x102b0000, 0x10300000)
tenured generation total 37824K, used 18827K [0x12780000, 0x14c70000,
0x30020000)
the space 37824K, 49% used [0x12780000, 0x139e2d70, 0x139e2e00, 0x14c70000)
compacting perm gen total 36352K, used 36332K [0x30020000, 0x323a0000,
0x38020000)
the space 36352K, 99% used [0x30020000, 0x3239b1d8, 0x3239b200, 0x323a0000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0040d000 C:\eclipse-3.3\eclipse.exe
0x775f0000 - 0x7770e000 C:\Windows\system32\ntdll.dll
0x76260000 - 0x76338000 C:\Windows\system32\kernel32.dll
0x77550000 - 0x775ee000 C:\Windows\system32\USER32.dll
0x777e0000 - 0x7782b000 C:\Windows\system32\GDI32.dll
0x761a0000 - 0x7625f000 C:\Windows\system32\ADVAPI32.dll
0x77710000 - 0x777d3000 C:\Windows\system32\RPCRT4.dll
0x73460000 - 0x734e6000
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595 b64144ccf1df_5.82.6000.16386_none_87e0cb09378714f1\COMCTL32. dll
0x774a0000 - 0x7754a000 C:\Windows\system32\MSVCRT.dll
0x711f0000 - 0x7120e000 C:\Windows\system32\ShimEng.dll
0x75c90000 - 0x75cbc000 C:\Windows\system32\apphelp.dll
0x70eb0000 - 0x70f37000 C:\Windows\AppPatch\AcLayers.dll
0x76370000 - 0x76e3e000 C:\Windows\system32\SHELL32.dll
0x75ff0000 - 0x76045000 C:\Windows\system32\SHLWAPI.dll
0x77350000 - 0x77494000 C:\Windows\system32\ole32.dll
0x76e40000 - 0x76ecc000 C:\Windows\system32\OLEAUT32.dll
0x75d60000 - 0x75d7e000 C:\Windows\system32\USERENV.dll
0x75d40000 - 0x75d54000 C:\Windows\system32\Secur32.dll
0x73000000 - 0x73041000 C:\Windows\system32\WINSPOOL.DRV
0x758e0000 - 0x758f4000 C:\Windows\system32\MPR.dll
0x6fd90000 - 0x6ffa0000 C:\Windows\AppPatch\AcGenral.DLL
0x74f50000 - 0x74f8f000 C:\Windows\system32\UxTheme.dll
0x749e0000 - 0x74a13000 C:\Windows\system32\WINMM.dll
0x749a0000 - 0x749d8000 C:\Windows\system32\OLEACC.dll
0x75b60000 - 0x75bca000 C:\Windows\system32\NETAPI32.dll
0x75ea0000 - 0x75ea7000 C:\Windows\system32\PSAPI.DLL
0x74520000 - 0x74535000 C:\Windows\system32\MSACM32.dll
0x75580000 - 0x75588000 C:\Windows\system32\VERSION.dll
0x732a0000 - 0x732a5000 C:\Windows\system32\sfc.dll
0x71df0000 - 0x71dfd000 C:\Windows\system32\sfc_os.DLL
0x77140000 - 0x772c9000 C:\Windows\system32\SETUPAPI.dll
0x73140000 - 0x7314c000 C:\Windows\system32\dwmapi.dll
0x76070000 - 0x76197000 C:\Windows\system32\urlmon.dll
0x76ee0000 - 0x76f25000 C:\Windows\system32\iertutil.dll
0x741e0000 - 0x741e5000 C:\Windows\system32\SHUNIMPL.dll
0x75eb0000 - 0x75ece000 C:\Windows\system32\IMM32.DLL
0x75f20000 - 0x75fe7000 C:\Windows\system32\MSCTF.dll
0x76ed0000 - 0x76ed9000 C:\Windows\system32\LPK.DLL
0x77030000 - 0x770ad000 C:\Windows\system32\USP10.dll
0x77000000 - 0x7702d000 C:\Windows\system32\WS2_32.dll
0x76060000 - 0x76066000 C:\Windows\system32\NSI.dll
0x75d10000 - 0x75d31000 C:\Windows\system32\NTMARTA.DLL
0x75ed0000 - 0x75f19000 C:\Windows\system32\WLDAP32.dll
0x75cf0000 - 0x75d01000 C:\Windows\system32\SAMLIB.dll
0x74c50000 - 0x74de4000
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595 b64144ccf1df_6.0.6000.16386_none_5d07289e07e1d100\comctl32.d ll
0x10000000 - 0x10011000
C:\eclipse-3.3\plugins\org.eclipse.equinox.launcher.win32.wi n32.x86_1.0.0.v20070523\eclipse_1017a.dll
0x003e0000 - 0x003e6000
C:\Users\ERIKHA~1.ALF\AppData\Local\Temp\IadHide5.dll
0x6d7c0000 - 0x6da07000 C:\jdk1.6.0\jre\bin\client\jvm.dll
0x7c340000 - 0x7c396000 C:\Windows\system32\MSVCR71.dll
0x6d310000 - 0x6d318000 C:\jdk1.6.0\jre\bin\hpi.dll
0x6d770000 - 0x6d77c000 C:\jdk1.6.0\jre\bin\verify.dll
0x6d3b0000 - 0x6d3cf000 C:\jdk1.6.0\jre\bin\java.dll
0x6d7b0000 - 0x6d7bf000 C:\jdk1.6.0\jre\bin\zip.dll
0x6d570000 - 0x6d583000 C:\jdk1.6.0\jre\bin\net.dll
0x75510000 - 0x7554b000 C:\Windows\system32\mswsock.dll
0x75570000 - 0x75576000 C:\Windows\System32\wship6.dll
0x6d590000 - 0x6d599000 C:\jdk1.6.0\jre\bin\nio.dll
0x00fa0000 - 0x00fef000
C:\eclipse-3.3\configuration\org.eclipse.osgi\bundles\405\1\ .cp\swt-win32-3346.dll
0x772d0000 - 0x77344000 C:\Windows\system32\comdlg32.dll
0x76f30000 - 0x77000000 C:\Windows\system32\WININET.dll
0x76050000 - 0x76053000 C:\Windows\system32\Normaliz.dll
0x052a0000 - 0x052b4000
C:\eclipse-3.3\configuration\org.eclipse.osgi\bundles\405\1\ .cp\swt-gdip-win32-3346.dll
0x74700000 - 0x748aa000
C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144cc f1df_1.0.6000.16386_none_9ea0ac9ec96e7127\gdiplus.dll
0x75270000 - 0x752a8000 C:\Windows\system32\rsaenh.dll
0x751f0000 - 0x751f5000 C:\Windows\system32\msimg32.dll
0x770b0000 - 0x77134000 C:\Windows\system32\CLBCatQ.DLL
0x6f290000 - 0x6f2c0000 C:\Windows\system32\mlang.dll
0x6eec0000 - 0x6eee1000
C:\eclipse-3.3\plugins\org.tigris.subversion.javahl.win32_1. 2.4\libapr.dll
0x6ee50000 - 0x6ee59000
C:\eclipse-3.3\plugins\org.tigris.subversion.javahl.win32_1. 2.4\libapriconv.dll
0x06e90000 - 0x06f98000
C:\eclipse-3.3\plugins\org.tigris.subversion.javahl.win32_1. 2.4\libeay32.dll
0x71de0000 - 0x71de7000 C:\Windows\system32\WSOCK32.dll
0x058b0000 - 0x05974000
C:\eclipse-3.3\plugins\org.tigris.subversion.javahl.win32_1. 2.4\libdb44.dll
0x70dd0000 - 0x70e36000 C:\Windows\system32\MSVCP60.dll
0x04d40000 - 0x04d71000
C:\eclipse-3.3\plugins\org.tigris.subversion.javahl.win32_1. 2.4\ssleay32.dll
0x6ee60000 - 0x6ee89000
C:\eclipse-3.3\plugins\org.tigris.subversion.javahl.win32_1. 2.4\libaprutil.dll
0x04d80000 - 0x04d92000
C:\eclipse-3.3\plugins\org.tigris.subversion.javahl.win32_1. 2.4\intl3_svn.dll
0x06fa0000 - 0x070a9000
C:\eclipse-3.3\plugins\org.tigris.subversion.javahl.win32_1. 2.4\libsvnjavahl-1.dll
0x71fe0000 - 0x71fe5000 C:\Windows\system32\SHFOLDER.dll
0x728b0000 - 0x729b7000 C:\Windows\system32\shdocvw.dll
0x73b80000 - 0x73c32000 C:\Windows\system32\WindowsCodecs.dll
0x72480000 - 0x72515000 C:\Windows\System32\cscui.dll
0x73ce0000 - 0x73d97000 C:\Windows\System32\PROPSYS.dll
0x72ac0000 - 0x72ac9000 C:\Windows\System32\CSCDLL.dll
0x72ab0000 - 0x72aba000 C:\Windows\System32\CSCAPI.dll
0x05350000 - 0x054d3000 C:\Program Files\TortoiseCVS\TortoiseShell.dll
0x723f0000 - 0x72477000
C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8. 0.50727.762_none_10b2f55f9bffb8f8\MSVCP80.dll
0x721b0000 - 0x7224b000
C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8. 0.50727.762_none_10b2f55f9bffb8f8\MSVCR80.dll
0x72760000 - 0x728a5000 C:\Windows\system32\browseui.dll
0x74f20000 - 0x74f50000 C:\Windows\system32\DUser.dll
0x6c240000 - 0x6c2a0000 C:\Program Files\Common Files\microsoft
shared\ink\tiptsf.dll
0x71f10000 - 0x71f22000 C:\Windows\System32\ntlanman.dll
0x71fd0000 - 0x71fd8000 C:\Windows\System32\drprov.dll
0x71fc0000 - 0x71fcf000 C:\Windows\System32\davclnt.dll
0x71ef0000 - 0x71f04000 C:\Windows\system32\LMIRfsClientNP.dll
0x6e540000 - 0x6e586000 C:\Windows\system32\PortableDeviceApi.dll
0x75050000 - 0x7507d000 C:\Windows\system32\WINTRUST.dll
0x757e0000 - 0x758d1000 C:\Windows\system32\CRYPT32.dll
0x75930000 - 0x75942000 C:\Windows\system32\MSASN1.dll
0x76340000 - 0x76369000 C:\Windows\system32\imagehlp.dll
0x71ae0000 - 0x71d03000 C:\Windows\system32\NetworkExplorer.dll
0x70e40000 - 0x70e8a000 C:\Windows\system32\ntshrui.dll
0x757a0000 - 0x757d9000 C:\Windows\system32\slc.dll
0x083b0000 - 0x083b8000
C:\eclipse-3.3\configuration\org.eclipse.osgi\bundles\85\1\. cp\os\win32\x86\localfile_1_0_0.dll
0x6ee40000 - 0x6ee45000 C:\Program Files\Subversion\iconv\_tbl_simple.so
0x083d0000 - 0x083d9000 C:\Program Files\Subversion\bin\libapriconv-1.dll
0x083e0000 - 0x08400000 C:\Program Files\Subversion\bin\libapr-1.dll
VM Arguments:
jvm_args: -Xms40m -Xmx512m -XX:MaxPermSize=128M
java_command: <unknown>
Launcher Type: generic
Environment Variables:
JAVA_HOME=C:\jdk1.6.0
CLASSPATH=c:\mysql-connector-java-5.1.6\mysql-connector-java -5.1.6-bin
PATH=C:\jdk1.6.0\bin\..\jre\bin\client;C:\jdk1.6.0\bin\..\jr e\bin;C:\jdk1.6.0\bin;C:\Programme\PHP\;c:\Program
Files\Sun\JavaES5\WebServer7\lib;c:\Program
Files\Sun\JavaES5\share\lib;c:\Program
Files\Sun\JavaES5\share\bin;C:\Java\JDK15~1.0_0\bin;c:\Progr am
Files\Sun\JavaES5\share\ant\bin;c:\Program
Files\Sun\JavaES5\share\cacao_2\bin;c:\Program
Files\Sun\JavaES5\appserver\lib;c:\Program
Files\Sun\JavaES5\appserver\bin;c:\program
files\imagemagick-6.2.8-q16;C:\Windows\system32;C:\Windows;C :\Windows\System32\Wbem;d:\Programme\alfa\oracle\BIN;C:\Prog ram
Files\Common Files\Adobe\AGL;c:\program files\OpenOffice.org
2.0\program\;YBASE\DLL;C:\Program
Files\QuickTime\QTSystem;d:\Programme\alfa\dll\de;C:\jdk1.6. 0\bin;c:\Program
Files\apache-ant-1.7.0\bin;$CATALINA_HOME/bin;c:\mysql-5.0.5 1a-win32\bin;C:\Program
Files\Subversion\bin;C:\Program Files\CVSNT\;C:\Program Files\IDM Computer
Solutions\UltraEdit\;C:\Program Files\IDM Computer
Solutions\UltraCompare;C:\Program Files\Common Files\Ahead\Lib\
USERNAME=doug.scovill
SHELL=d:\Programme\alfa\PageOneXT32\unixbin\sh.exe
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 6 Stepping 4, GenuineIntel
S Y S T E M
OS: Windows XP Build 2600 Service Pack 2
CPU:total 2 family 15, cmov, cx8, fxsr, mmx, sse, sse2, ht
Memory: 4k page, physical 1048575k(902316k free), swap 2097151k(1048575k
free)
vm_info: Java HotSpot(TM) Client VM (1.6.0-b105) for windows-x86, built on
Nov 29 2006 00:48:48 by "java_re" with unknown MS VC++:1310
Re: EXCEPTION_ACCESS_VIOLATION trying to import existing project into eclipse [message #257039 is a reply to message #257024] Sat, 24 May 2008 02:19 Go to previous messageGo to next message
> Eclipse closes
This looks like a problem in the Subversion plug-in. Please file a bug
report there. In the meantime you could try with another VM.
Dani
> tid=6076
> # C
> T H R E A D
> Registers:
> Stack:
> C
> C
> C
> C
> j
> Other Threads:
> Heap
> 0x12780000)
> 0x30020000)
> 0x14c70000)
> 0x38020000)
> 0x323a0000)
> Dynamic libraries:
> VM Arguments:
> Computer Solutions\UltraEdit\;C:\Program Files\IDM Computer
> OS=Windows_NT
> S Y S T E M
> 2097151k(1048575k free)
> built on Nov 29 2006 00:48:48 by "java_re" with unknown MS VC++:1310
Re: EXCEPTION_ACCESS_VIOLATION trying to import existing project into eclipse [message #257379 is a reply to message #257039] Thu, 29 May 2008 07:13 Go to previous messageGo to next message
Originally posted by: dev.ksoft.dk
Did you come up with a solution to this problem?
Re: EXCEPTION_ACCESS_VIOLATION trying to import existing project into eclipse [message #257633 is a reply to message #257039] Tue, 03 June 2008 22:59 Go to previous messageGo to next message
Originally posted by: timsmail.yahoo.com
I'm having the same issue. Anything I do with Subclipse causes Eclipse to
close and an ACCESS_EXCEPTION to be logged in an hs_errr... file in the
Eclipse directory. Anybody have a fix?
Tim
Re: EXCEPTION_ACCESS_VIOLATION trying to import existing project into eclipse [message #257643 is a reply to message #257633] Wed, 04 June 2008 06:54 Go to previous messageGo to next message
On Wed, 4 Jun 2008 02:59:15 +0000 (UTC), timsmail@yahoo.com (Tim)
>Thanks
>Tim
Similar problem: SVN commit crashed with an access violation. I got
rid of the problem by switching from "Java SVN" (not quite sure any
more) to "SVN Kit".
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Re: EXCEPTION_ACCESS_VIOLATION trying to import existing project into eclipse [message #257977 is a reply to message #257643] Tue, 10 June 2008 08:09 Go to previous message
It is described here with a solution:
http://subclipse.tigris.org/faq.html#win32-crash
Previous Topic:IncompatibleClassChangeError - on some machines
Next Topic:audio recording dialog, plugin
Current Time: Sun Jul 27 01:37:40 EDT 2025
Powered by FUDForum. Page generated in 0.09296 seconds
