| Regarding Actuate BIRT connector [message #257015] |
Thu, 04 October 2007 03:52  |
Originally posted by: abhijeet_barve.persistent.co.in
Hi All,
I have just joined this forum and wanted help from gurus here. Following is
the area where I am looking for the help:
Problem definition: I was going through the open source reporting tool from
Actuate and Eclipse' BIRT. I downloaded it from the web portal and was going
through the report designer tool called "BIRt report designer professional".
So far so good.. Now in the data connection menu I can see SAP, Actuate,
flat file etc connection options. My area of concern is how can I connect my
BIRT reporting tool to the OLAP server I am running on. I am using Hyperion
Analytic Services (Essbase) and I wanted to build reports on the cubes and
data present in my Essbase.
Is there any way for me to either connect to Essbase or write a custom data
connector in my BIRT reporting tool for the Hyperion Essbase. I am ready to
build a connector but then is there any API toolkit available where I can
put Essbase as an option in the designer and even can put a module which
will read my data for putting it into the report? Such API toolkit exist? If
so how can I download it and how should I start on this (API docs available
or not) ?
Guys could you please help me in this? I need to start on this ASAP. Should
I write a custom connector for Essbase in the BIRT and how can I deploy it
to my client side. I appreciate all your help and support.
Abhijeet
| Re: Regarding Actuate BIRT connector [message #257449 is a reply to message #257433] |
Mon, 08 October 2007 07:01   |
Hi Scott,
I registered on the Magazine site and got the articles from there. I
will go through them soon. Thanks a ton for your valuable help.
I have following query:
Is
1. DTP
2. ODA Runtime/Designer Driver Plug-in Project wizard"
are same??
If not, which is the better_fast way to write the reporting connector for
Hyperion Essbase?
Abhijeet
"Abhijeet" <abhijeet_barve@persistent.co.in> wrote in message
news:fed11k$inj$1@build.eclipse.org...
> Hi Scott,
> Thanks a lot for the help.Could you please let me know where should I
> login to get your articles and which login ID I should use? That would be
> a great help for me.
> Thanks
> Abhijeet
> "Scott Rosenbaum" <scottr@innoventsolutions.com> wrote in message
> news:ad733d6a8dc8c9d58a77f2e2f8@news.eclipse.org...
>> Abhijeet,
>> The answer is yes there is a good way to create a custom type of BIRT
>> data source that will talk to Hyperion. BIRT uses the Data Tools
>> Platform (DTP). DTP has a number of extension points that allow you to
>> build a custom data source as well as a custom UI to work with that Data
>> Source.
>> Jason Weathersby and I have done a series of articles on Eclipse Magazine
>> that explain the process. You have to login to get the articles, but if
>> you look in the March 2007, April 2007 you can get part One and Two of
>> the ODA articles.
>> Scott Rosenbaum
>>> Hi All,
>>> Following is the area where I am looking for the help:
>>> from
>>> going
>>> professional".
>>> Actuate,
>>> connect my
>>> Hyperion
>>> and
>>> data
>>> ready to
>>> can
>>> which
>>> exist? If
>>> available
>>> or not) ?
>>> Should I write a custom connector for Essbase in the BIRT and how can
>>> I deploy it to my client side. I appreciate all your help and support.
>>> Thanks
>>> Abhijeet
| Re: Regarding Actuate BIRT connector [message #257534 is a reply to message #257449] |
Mon, 08 October 2007 12:08   |
Abhijeet,
DTP is ODA. So if you use the wizard to create your Runtime and DesignTime
project as a starting point, it is probably a good idea.
Scott
> Hi Scott,
> I will go through them soon. Thanks a ton for your valuable help.
> Is
> 1. DTP
> are same??
> for Hyperion Essbase?
> Thanks
> Abhijeet
>> Hi Scott,
>> would be a great help for me.
>> Thanks
>> Abhijeet
>>> Abhijeet,
>>> BIRT
>>> to
>>> Data
>>> Source.
>>> Magazine
>>> but if
>>> of
>>> the ODA articles.
>>> Scott Rosenbaum
>>>> Hi All,
>>>> tool
>>>> from
>>>> was
>>>> going
>>>> professional".
>>>> Actuate,
>>>> connect my
>>>> Hyperion
>>>> cubes
>>>> and
>>>> custom
>>>> data
>>>> ready to
>>>> I
>>>> can
>>>> which
>>>> exist? If
>>>> available
>>>> or not) ?
>>>> ASAP.
>>>> can
>>>> support.
>>>> Thanks
>>>> Abhijeet
| Re: Regarding Actuate BIRT connector [message #257620 is a reply to message #257534] |
Tue, 09 October 2007 02:54  |
Thanks a ton Scott. I have downloaded the articles you have writen. I will
go through it and will try to implement the functionality I am looking for.
Abhijeet
news:ad733d6a9798c9d7b2ae8057a4@news.eclipse.org...
> Abhijeet,
> DesignTime project as a starting point, it is probably a good idea.
> Scott
>> Hi Scott,
>> Is
>> 1. DTP
>> are same??
>> Thanks
>> Abhijeet
>>> Hi Scott,
>>> Thanks
>>> Abhijeet
>>>> Abhijeet,
>>>> BIRT
>>>> to
>>>> Data
>>>> Source.
>>>> Magazine
>>>> but if
>>>> of
>>>> the ODA articles.
>>>> Scott Rosenbaum
>>>>> Hi All,
>>>>> tool
>>>>> from
>>>>> was
>>>>> going
>>>>> professional".
>>>>> Actuate,
>>>>> connect my
>>>>> Hyperion
>>>>> cubes
>>>>> and
>>>>> custom
>>>>> data
>>>>> ready to
>>>>> I
>>>>> can
>>>>> which
>>>>> exist? If
>>>>> available
>>>>> or not) ?
>>>>> ASAP.
>>>>> can
>>>>> support.
>>>>> Thanks
>>>>> Abhijeet
FUDForum. Page generated in 0.05321 seconds
