| error loading JDBC drivers on creating Data Source [message #257002] | Thu, 04 October 2007 02:55  |  |
| Eclipse User  |  |  |  |  | Originally posted by: matthew.kerle+birt.dha.gov.au
 Hi all,
 Windows XPSP2
 Eclipse version: 3.2.0 (Jre 1.6.0_02) (installed to D:\programs\eclipse\)
 BIRT : 2.1.1 & 2.1.2 (v20070205-1728)
 EMF 2.2.0.v200606271057
 GEF 3.2.0.v20060626
 We're having some troubles getting started with BIRT, we've installed the
 BIRT plugins into our existing eclipse IDE's, and run "eclipse -clean". we
 can open the report perspective and create a business report no worries,
 but we can't create any Data Sources.
 first we tried to create a datasource according to the online tutorial
 (link #1) using the embedded derby sampledb, but on clicking the 'Test
 Connection' button we get an error box that only has the name of the derby
 driver (see link #2)
 We tried using an oracle driver as well, and got a slightly more
 informative error (#3). It seems like for some reason our BIRT install
 can't load JDBC drivers, well, the embedded derby and an oracle one
 anyway...
 Just wondering if anyone has any idea's what could be causing this?
 thanks!
 matt.
 #1 - online tutorial we used.
 http://download.eclipse.org/birt/downloads/examples/reports/ 2.1/tutorial/tutorial.html
 #2 - this is trying to use the embedded BIRT derby driver:
 http://hotimg3.fotki.com/p/a/152_91/61_209/birt_error_msg.jp g
 #3 - this is trying to use Oracle 10G driver
 http://hotimg5.fotki.com/p/a/152_91/61_209/birt_error_msg2.j pg
| Re: error loading JDBC drivers on creating Data Source [message #258012 is a reply to message #257883] | Fri, 12 October 2007 03:14  |  |
| Eclipse User  |  |  |  |  | Hi,
 Have you tried  a clean workspace when you make your test under new
 birt-report-designer-all-in one?
 Thanks.
 Lin
 "matt" <matthew.kerle+birt@dha.gov.au> wrote in message
 news:b1fd04ffccb58cf18498c04ba7e39f8f$1@www.eclipse.org...
 > thanks for your reply Gary.
 > Ok, I downloaded the birt-report-designer-all-in-one-2_2_1, and changed my
 > PATH so that eclipse runs on JDK 1.5.0_11.
 > I still get the same exception (below). anything else we can try?
 > org.eclipse.birt.report.data.oda.jdbc.JDBCException:
 > org.apache.derby.jdbc.EmbeddedDriver
 > at
 >  org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.test Connection(JDBCDriverManager.java:522)
 > at
 >  org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.t estConnection(DriverLoader.java:108)
 > at
 >  org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper.testConnection(JDBCSelectionPageHelper.java:622 )
 > at
 >  org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper.access$7(JDBCSelectionPageHelper.java:606)
 > at
 >  org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper$6.widgetSelected(JDBCSelectionPageHelper.java:5 28)
 > at
 >  org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
 > (34 lines elided for clarity)
 > at  org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
 > at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
 > at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
 > java version:
 > *** Date: Thursday, 11 October 2007 10:15:05 AM Sydney (Australia)
 > *** Platform Details:
 > *** System properties:
 > awt.toolkit=sun.awt.windows.WToolkit
 > birt.viewer.working.path=C:\Documents and
 >  Settings\mkerle\workspace\.metadata\.plugins\org.eclipse.bir t.report.viewer
 > eclipse.buildId=M20070921-1145
 > eclipse.commands=-os
 > win32
 > -ws
 > win32
 > -arch
 > x86
 > -showsplash
 > C:\Program
 > -launcher
 > C:\Program Files\eclipse\eclipse.exe
 > -name
 > Eclipse
 > --launcher.library
 > C:\Program
 >  Files\eclipse\plugins\org.eclipse.equinox.launcher.win32.win 32.x86_1.0.1.R33x_v20070828\eclipse_1020.dll
 > -startup
 > C:\Program
 >  Files\eclipse\plugins\org.eclipse.equinox.launcher_1.0.1.R33 x_v20070828.jar
 > -vm
 > D:\programs\java\jdk1.5.0_11\bin\..\jre\bin\client\jvm.dll
 > eclipse.ee.install.verify=false
 > eclipse.product=org.eclipse.sdk.ide
 > eclipse.startTime=1192061507878
 >  eclipse.vm=D:\programs\java\jdk1.5.0_11\bin\..\jre\bin\clien t\jvm.dll
 > eclipse.vmargs=-Xms40m
 > -Xmx256m
 > -Djava.class.path=C:\Program
 > eof=eof
 > file.encoding=Cp1252
 > file.encoding.pkg=sun.io
 > file.separator=\
 > java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
 > java.awt.printerjob=sun.awt.windows.WPrinterJob
 > java.class.version=49.0
 >  java.endorsed.dirs=D:\programs\java\jdk1.5.0_11\jre\lib\endo rsed
 > java.ext.dirs=D:\programs\java\jdk1.5.0_11\jre\lib\ext
 > java.home=D:\programs\java\jdk1.5.0_11\jre
 > java.io.tmpdir=C:\DOCUME~1\mkerle\Local Settings\Temp\
 > java.library.path=C:\Program
 >  Files\eclipse;.;C:\WINDOWS\system32;C:\WINDOWS;D:\programs\j ava\jdk1.5.0_11\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOW S\System32\Wbem;C:\Program
 > Files\Common
 >  Files\GTK\2.0\bin;d:\programs\bea\weblogic700\server\bin;D:\ programs\svn-win32-1.4.3\bin;D:\oracle\ora92\bin;d:\Programs \ATI
 > Technologies\ATI.ACE\Core-Static
 > java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
 > java.runtime.version=1.5.0_11-b03
 > java.specification.name=Java Platform API Specification
 > java.specification.vendor=Sun Microsystems Inc.
 > java.specification.version=1.5
 > java.vendor=Sun Microsystems Inc.
 > java.vendor.url=http://java.sun.com/
 > java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
 > java.version=1.5.0_11
 > java.vm.info=mixed mode
 > java.vm.name=Java HotSpot(TM) Client VM
 > java.vm.specification.name=Java Virtual Machine Specification
 > java.vm.specification.vendor=Sun Microsystems Inc.
 > java.vm.specification.version=1.0
 > java.vm.vendor=Sun Microsystems Inc.
 > java.vm.version=1.5.0_11-b03
 > line.separator=
FUDForum. Page generated in 0.05451 seconds
