Home » Archived » BIRT » Column Binding error
Column Binding error [message #256957] Wed, 03 October 2007 15:33 Go to next message
Originally posted by: tom.oc.com
I generated a simple Birt report that does a simple query with a join to
get the count of rows in a table and the sum of values in another table
that works fine in the Birt Viewer during design time but gets the
following error when I deploy to tomcat environment with Birt 2.2.0
runtime.
SEVERE: Column binding "count(*)" has referred to a data set column
"count(*)" w
hich is not exist.
I also get the same error for sum as well . Anyone have any ideas why it
would work in the Design Tool but not work in runtime environment.
Re: Column Binding error [message #257057 is a reply to message #256957] Thu, 04 October 2007 10:47 Go to previous messageGo to next message
Tom,
can you post the report?
Jason
> runtime.
> "count(*)" w
> hich is not exist.
Re: Column Binding error [message #257100 is a reply to message #257057] Thu, 04 October 2007 13:24 Go to previous messageGo to next message
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version 1.0.1 Build
&lt;20051130-1157></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company Name
here>></property>
<html-property name="description">Creates a listing report with fields
from the data source.</html-property>
<text-property name="displayName">Simple Listing</text-property>
<property name="iconFile">/templates/simple_listing.gif</property>
<property
name="cheatSheet"> org.eclipse.birt.report.designer.ui.cheatsheet.simplelisting </property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="26">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">com.mysql.jdbc.Driver</property>
<property
name="odaURL">jdbc:mysql://chimera:3306/cmpe_2007</property>
<property name="odaUser">report</property>
<encrypted-property
name="odaPassword">T0NT</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set 1" id="27">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">count(*)</property>
<property name="dataType">decimal</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">count(*)</property>
<property name="nativeDataType">-5</property>
</structure>
</list-property>
<property name="queryText">select count(*)
from captured_session</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>count(*)</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>-5</design:nativeDataTypeCode>
<design:precision>21</design:precision>
<design:scale>0</design:scale>
<design:nullability>NotNullable</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>count(*)</design:label>
<design:formattingHints>
<design:displaySize>21</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
<oda-data-set
name="Data Set 2" id="30">
<structure>
<property
name="name">sum(captured_session.csDestinationPort)</property >
</structure>
</list-property>
</structure>
<structure>
<property
<property
name="nativeName">sum(captured_session.csDestinationPort)</property >
<property name="nativeDataType">3</property>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:name>sum(captured_session.csDestinationPort)</design:name >
<design:nativeDataTypeCode>3</design:nativeDataTypeCode>
<design:precision>32</design:precision>
<design:nullability>Nullable</design:nullability>
<design:usageHints>
<design:label>sum(captured_session.csDestinationPort)</design:label >
<design:displaySize>33</design:displaySize>
]]></xml-property>
</oda-data-set>
<oda-data-set
name="Data Set 3" id="32">
<structure>
<property name="name">prid</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">peUserTime</property>
</structure>
</list-property>
</structure>
<property name="rowFetchLimit">15</property>
<structure>
<property name="nativeName">prid</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">peUserTime</property>
</structure>
</list-property>
<property name="queryText">SELECT p.prid,p.peUserTime FROM
process_event p left join cmpe_2007.process q on q.prID=p.prID;
</property>
<model:DesignValues
<design:attributes>
<design:name>prid</design:name>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:usageHints>
<design:label>prid</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>peUserTime</design:name>
<design:position>2</design:position>
<design:precision>20</design:precision>
<design:usageHints>
<design:label>peUserTime</design:label>
<design:displaySize>20</design:displaySize>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="24">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="25">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<data id="31">
<property name="dataSet">Data Set 2</property>
<list-property name="boundDataColumns">
<structure>
<property
<expression
name="expression">dataSetRow["sum(captured_session.csDestinationPort) "]</expression>
</structure>
</list-property>
<property
name="resultSetColumn">sum(captured_session.csDestinationPort) </property>
</data>
<table id="4">
<property name="width">100%</property>
<property name="dataSet">Data Set 1</property>
<structure>
<expression
name="expression">dataSetRow["count(*)"]</expression>
</structure>
</list-property>
<column id="20"/>
<column id="21"/>
<column id="22"/>
<column id="23"/>
<header>
<row id="5">
<cell id="6"/>
<cell id="7">
<label id="28">
<text-property
name="text">count(*)</text-property>
</label>
</cell>
<cell id="8"/>
<cell id="9"/>
</row>
</header>
<detail>
<row id="10">
<cell id="11"/>
<cell id="12">
<data id="29">
<property
name="resultSetColumn">count(*)</property>
</data>
</cell>
<cell id="13"/>
<cell id="14"/>
</row>
</detail>
<footer>
<row id="15">
<cell id="16"/>
<cell id="17"/>
<cell id="18"/>
<cell id="19"/>
</row>
</footer>
</table>
<data id="33">
<property name="dataSet">Data Set 3</property>
<structure>
<expression
name="expression">dataSetRow["prid"]</expression>
</structure>
</list-property>
<property name="resultSetColumn">prid</property>
</data>
<list id="35">
<structure>
<expression
</structure>
<structure>
<expression
name="expression">dataSetRow["peUserTime"]</expression>
</structure>
</list-property>
<detail>
<data id="34">
<structure>
<expression
</structure>
</list-property>
<property name="resultSetColumn">peUserTime</property>
</data>
</detail>
</list>
</body>
</report>
Re: Column Binding error [message #257108 is a reply to message #257057] Thu, 04 October 2007 13:47 Go to previous messageGo to next message
Attached are the column binding error messages from birt runtime when
running the report that I posted earlier.
Oct 4, 2007 11:23:02 AM
org.eclipse.birt.report.engine.data.dte.DataGenerationEn
gine doExecuteQuery
SEVERE: Column binding "sum(captured_session.csDestinationPort)" has
referred to
a data set column "sum(captured_session.csDestinationPort)" which does
not exis
t.
gine doExecuteQuery
"count(*)" w
hich does not exist.
gine doExecuteQuery
SEVERE: Column binding "prid" has referred to a data set column "prid"
which doe
s not exist.
gine doExecuteQuery
which doe
s not exist.
org.eclipse.birt.report.engine.data.dte.DataPresentation
Engine doExecuteQuery
SEVERE: Can't load the report query
Re: Column Binding error [message #257126 is a reply to message #257108] Thu, 04 October 2007 15:27 Go to previous messageGo to next message
Tom,
On the binding tab for the element that contains
can you try to name it something else? Leave the expression as is.
Jason
> gine doExecuteQuery
> referred to
> not exis
> t.
> gine doExecuteQuery
> "count(*)" w
> gine doExecuteQuery
> which doe
> s not exist.
> gine doExecuteQuery
> which doe
> s not exist.
Re: Column Binding error [message #257192 is a reply to message #257126] Thu, 04 October 2007 16:32 Go to previous messageGo to next message
Here is post of the change the name of sum(.....) to fred, but I still get
the error that says fred refers to sum(....) that does not exist and fails.
id="1">
here>></property>
<property
<data-sources>
<oda-data-source
id="26">
<property
<property
<encrypted-property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:usageHints>
]]></xml-property>
</oda-data-set>
<oda-data-set
<structure>
<property name="name">fred</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">fred</property>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:usageHints>
]]></xml-property>
</oda-data-set>
<oda-data-set
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</property>
<model:DesignValues
<design:attributes>
<design:usageHints>
<design:attributes>
<design:usageHints>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
</text>
</page-footer>
</page-setup>
<body>
<data id="31">
<structure>
<expression
</structure>
</list-property>
<property name="resultSetColumn">fred</property>
</data>
<table id="4">
<structure>
<expression
</structure>
</list-property>
<column id="20"/>
<column id="21"/>
<column id="22"/>
<column id="23"/>
<header>
<row id="5">
<cell id="6"/>
<cell id="7">
<label id="28">
<text-property
</label>
</cell>
<cell id="8"/>
<cell id="9"/>
</row>
</header>
<detail>
<row id="10">
<cell id="11"/>
<cell id="12">
<data id="29">
<property
</data>
</cell>
<cell id="13"/>
<cell id="14"/>
</row>
</detail>
<footer>
<row id="15">
<cell id="16"/>
<cell id="17"/>
<cell id="18"/>
<cell id="19"/>
</row>
</footer>
</table>
<data id="33">
<structure>
<expression
</structure>
</list-property>
</data>
<list id="35">
<structure>
<expression
</structure>
<structure>
<expression
</structure>
</list-property>
<detail>
<data id="34">
<structure>
<expression
</structure>
</list-property>
</data>
</detail>
</list>
</body>
</report>
Re: Column Binding error [message #257215 is a reply to message #257192] Thu, 04 October 2007 18:16 Go to previous message
Tom,
This may be a compatibility issue. Can you try removing the field and
using the new aggregation element?
Jason
> get the error that says fred refers to sum(....) that does not exist and
> fails.
> id="1">
> Name here>></property>
> fields from the data source.</html-property>
> <property
> <data-sources>
> <oda-data-source
> id="26">
> <property name="odaDriverClass">com.mysql.jdbc.Driver</property>
> <property
> <encrypted-property name="odaPassword">T0NT</encrypted-property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <property name="queryText">select count(*) from
> <model:DesignValues
> <design:attributes>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <model:DesignValues
> <design:attributes>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </property>
> <model:DesignValues
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <data id="31">
> <structure>
> <expression
> </structure>
> </list-property>
> </data>
> <table id="4">
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="20"/>
> <column id="21"/>
> <column id="22"/>
> <column id="23"/>
> <header>
> <row id="5">
> <cell id="6"/>
> <cell id="7">
> <label id="28">
> <text-property
> </label>
> </cell>
> <cell id="8"/>
> <cell id="9"/>
> </row>
> </header>
> <detail>
> <row id="10">
> <cell id="11"/>
> <cell id="12">
> <data id="29">
> <property
> </data>
> </cell>
> <cell id="13"/>
> <cell id="14"/>
> </row>
> </detail>
> <footer>
> <row id="15">
> <cell id="16"/>
> <cell id="17"/>
> <cell id="18"/>
> <cell id="19"/>
> </row>
> </footer>
> </table>
> <data id="33">
> <structure>
> <expression
> </structure>
> </list-property>
> </data>
> <list id="35">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <detail>
> <data id="34">
> <structure>
> <expression
> </structure>
> </list-property>
> </data>
> </detail>
> </list>
> </body>
> </report>
Previous Topic:Birt with tomcat 5.0
Next Topic:CHARTING API:How to get the Series/Data Point Count
Current Time: Mon May 12 19:11:12 EDT 2025
Powered by FUDForum. Page generated in 0.04848 seconds
