Home » Newcomers » Newcomers » eclipse 3.3.2 on Winows XP crash
eclipse 3.3.2 on Winows XP crash [message #256856] Wed, 21 May 2008 09:35 Go to next message
Originally posted by: psimonovsk.hotmail.com
Eclipse Platform
Version: 3.3.2
Build id: M20080221-1800
Yoxos distribution
Eclipse starts normally... When I try to "open file" - I get window of file
browsing... But - when I try to double click any directory to enter it -
eclipse crashe... it's window - just disappear...
Java - Sun java 1.5.0_06
Re: eclipse 3.3.2 on Winows XP crash [message #256881 is a reply to message #256856] Wed, 21 May 2008 10:11 Go to previous messageGo to next message
Simonovsky Pavel wrote:
> Eclipse Platform
> Version: 3.3.2
> Yoxos distribution
Please try downloading one of the packages directly from eclipse.org
(instead of the Yoxos distro) and see if the same things happens.
http://www.eclipse.org/downloads/
If that does not have the same problem, you'll have to report the issue
to Yoxos. Start by looking in the <workspace>/.metadata/.log to see if
there is any error reported there.
Hope this helps,
Eric
Re: eclipse 3.3.2 on Winows XP crash [message #257071 is a reply to message #256881] Sun, 25 May 2008 08:26 Go to previous messageGo to next message
I have installed "Eclipse Classic 3.3.2 (WindowsT)"... Same result...
There is no <workspace>/.metadata/.log ...
Here is result of "dir"
____________________________________________________________ __________
Directory of c:\workspace\.metadata
05/25/2008 03:17 PM <DIR> .
05/25/2008 03:17 PM <DIR> ..
05/25/2008 03:17 PM 0 .lock
05/25/2008 03:23 PM 26 version.ini
05/25/2008 03:17 PM <DIR> .plugins
2 File(s) 26 bytes
3 Dir(s) 1,014,132,736 bytes free
Do some one have any idea - what can I do against it???
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:g11ag0$dkk$3@build.eclipse.org...
>> Eclipse Platform
>> Version: 3.3.2
>> Yoxos distribution
>> file browsing... But - when I try to double click any directory to enter
>> it - eclipse crashe... it's window - just disappear...
> If that does not have the same problem, you'll have to report the issue to
> Yoxos. Start by looking in the <workspace>/.metadata/.log to see if there
> Hope this helps,
> Eric
Re: eclipse 3.3.2 on Winows XP crash [message #257212 is a reply to message #257071] Tue, 27 May 2008 10:02 Go to previous messageGo to next message
1) In Eclipse, open the About dialog and click configuration Details -
please post the values of the java.version and java.vendor properties.
2) Try upgrading your JVM - perhaps it is a bug or incompatibility with
that particular JRE.
Hope this helps,
Eric
>>> Eclipse Platform
>>> Version: 3.3.2
>>> Yoxos distribution
>> Hope this helps,
>> Eric
Re: eclipse 3.3.2 on Winows XP crash [message #257225 is a reply to message #257212] Tue, 27 May 2008 10:23 Go to previous message
I actually had some version of java 1.6 ... It was same problem... I have
read in eclipse site - that current version was not fully tested with java 6
, and downgraded to java 5...
Here is data from "about" diolog
____________________________________________________________ _________________________
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20080221-1800
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
c:\eclipse\\plugins\org.eclipse.platform_3.3.3.r33x_r2008012 9\splash.bmp
-launcher
c:\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
c:\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32. x86_1.0.3.R33x_v20080118\eclipse_1023.dll
-startup
c:\eclipse\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v 20080118.jar
-vm
D:\Program Files\Java\jre1.5.0_06\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1211897942469
eclipse.vm=D:\Program Files\Java\jre1.5.0_06\bin\client\jvm.dll
eclipse.vmargs=-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=c:\eclipse\plugins\org.eclipse.equinox.lau ncher_1.0.1.R33x_v20080118.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=c:\eclipse\plugins\org.eclipse.equinox.launc her_1.0.1.R33x_v20080118.jar
java.class.version=49.0
java.endorsed.dirs=D:\Program Files\Java\jre1.5.0_06\lib\endorsed
java.ext.dirs=D:\Program Files\Java\jre1.5.0_06\lib\ext
java.home=D:\Program Files\Java\jre1.5.0_06
java.io.tmpdir=D:\DOCUME~1\psimonov\LOCALS~1\Temp\
java.library.path=c:\eclipse;.;D:\WINDOWS\system32;D:\WINDOW S;D:\Perl\bin;D:\PROGRA~1\MKSTOO~1\bin;D:\PROGRA~1\MKSTOO~1\ bin\X11;D:\PROGRA~1\MKSTOO~1\mksnt;D:\sybase\DataAccess\ADON ET\dll;D:\sybase\DataAccess\OLEDB\dll;D:\sybase\DataAccess\O DBC\dll;D:\sybase\Shared\Sybase
Central
4.3;D:\sybase\OCS-15_0\lib3p;D:\sybase\OCS-15_0\dll;D:\sybas e\OCS-15_0\bin;D:\WINDOWS\system32;D:\WINDOWS;D:\WINDOWS\Sys tem32\Wbem;D:\Program
Files\Vantive32;D:\Program Files\Telelogic\CM Synergy 6.3\bin;D:\Program
Files\Telelogic\CM Synergy 6.3\bin\util;D:\Program
Files\Hummingbird\Connectivity\10.00\Accessories\;D:\Program Files\Microsoft
SQL Server\80\Tools\Binn\;D:\Program Files\Microsoft SQL
Server\90\Tools\binn\;D:\Program Files\Microsoft SQL
Server\90\DTS\Binn\;D:\Program Files\Microsoft SQL
Server\90\Tools\Binn\VSShell\Common7\IDE\;D:\Program Files\SizeExplorer Pro
3.8.6
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.eclipse.equinox.launcher.splash.location=c:\eclipse\\plu gins\org.eclipse.platform_3.3.3.r33x_r20080129\splash.bmp
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.c ss,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3 c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,o rg.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\eclipse\configuration\org.eclipse.osgi\b undles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/eclipse/configuration/
osgi.framework=file:/c:/eclipse/plugins/org.eclipse.osgi_3.3 .2.R33x_v20080105.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.2.R33x_v20080105
osgi.install.area=file:/C:/eclipse/
osgi.instance.area=file:/C:/workspace/
osgi.instance.area.default=file:/D:/Documents and
Settings/psimonov/workspace/
osgi.logfile=C:\workspace\.metadata\.log
osgi.manifest.cache=C:\eclipse\configuration\org.eclipse.osg i\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\eclipse\\plugins\org.eclipse.platform _3.3.3.r33x_r20080129\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=D:\Program Files\Java\jre1.5.0_06\lib\rt.jar;D:\Program
Files\Java\jre1.5.0_06\lib\i18n.jar;D:\Program
Files\Java\jre1.5.0_06\lib\sunrsasign.jar;D:\Program
Files\Java\jre1.5.0_06\lib\jsse.jar;D:\Program
Files\Java\jre1.5.0_06\lib\jce.jar;D:\Program
Files\Java\jre1.5.0_06\lib\charsets.jar;D:\Program
Files\Java\jre1.5.0_06\classes
sun.boot.library.path=D:\Program Files\Java\jre1.5.0_06\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1255
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=c:\eclipse
user.home=D:\Documents and Settings\psimonov
user.language=en
user.name=psimonov
user.timezone=Asia/Jerusalem
user.variant=
news:g1h482$9ci$2@build.eclipse.org...
> Hope this helps,
> Eric
>>>> Eclipse Platform
>>>> Version: 3.3.2
>>>> Yoxos distribution
>>>> enter it - eclipse crashe... it's window - just disappear...
>>> Hope this helps,
>>> Eric
Previous Topic:Continue - eclipse 3.3.2 on Winows XP crash
Next Topic:Drag and drop from palette and view
Current Time: Mon Nov 17 14:29:24 EST 2025
Powered by FUDForum. Page generated in 0.11521 seconds
