| Re: Cursor keys stopped working in 3.2.2 [message #258681 is a reply to message #258668] |
Mon, 16 June 2008 10:19  |
Originally posted by: codeslave.ca.ibm.com
What other plugins are you using? Do you see any errors/warnings about
keybinding conflicts in the .log?
You can try starting Eclipse with these flags for more debugging options
and logged output:
-consolelog -clean -debug -console -noexit
João Noronha wrote:
> There is an open bug regarding this issue:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=110916
> I stopped having the problem and today restarted having it. :-(
> Downloading a new version (3.3.2) and using a blank project also has the
> same problem: cursor keys and backspace do not work - altough
> Ctrl+cursor or Alt+Shift+cursor DOES WORK and the latter selects
> paragraph, so it not really a key issue.
> Doing a trace, a simple cursor key gets prompted in the trace window,
> but there is not an action for the event...
FUDForum. Page generated in 0.29912 seconds
