Home » Eclipse Projects » Eclipse Platform » way to copy "debug/run as" from 2.1 to 3.0?
way to copy "debug/run as" from 2.1 to 3.0? [message #256817] Tue, 29 June 2004 15:02 Go to next message
Originally posted by: none.none.com
i exported my prefs from 2.1 and imported into 3.0. i also imported my 2.1
project into 3.0. i think i noticed is my debug and run as...
configuration aren't showing up. is there a way to do this?
Re: way to copy "debug/run as" from 2.1 to 3.0? [message #257638 is a reply to message #256817] Thu, 01 July 2004 16:18 Go to previous message
You can do two things:
1. set your configs to be shared (see the Common tab for any launch
configuration).
Once the configs are shared they are stored within the workspace are
will "move" with the workspace or can be managed via your favortie
repository.
2. Copy the files to your new workspace. All of your launch files can be
found at:
....pathToYourWorkspace\.metadata\.plugins\org.eclipse.debug .core\.launches\
simple copy these files and place them in the correct directory of your new
workspace.
HTH
Darins
"Mike" <none@none.com> wrote in message news:cbsect$6i7$1@eclipse.org...
Previous Topic:using ANT to RUN a java App
Next Topic:How to set the codebase for testing an applet?
Current Time: Sat Nov 08 12:12:10 EST 2025
Powered by FUDForum. Page generated in 0.03178 seconds
