Home » Newcomers » Newcomers » Eclipse crashes during tutorial
Eclipse crashes during tutorial [message #256717] Mon, 19 May 2008 13:59 Go to next message
I'm tryng to run the Java Development User Guide Basic Tutorial, and
when I get to the part
Creating your first Java project
Getting the Sample Code (JUnit)
and I click on the link to download the Junit source code, Eclipse
disappears, and an error message window appears.
Here's the error message:
VM terminated. Exit code=1
/usr/bin/java
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m
-jar
/home/rgeddes/eclipse/Europa/eclipse/plugins/org.eclipse.equ inox.launcher_1.0.1.R33x_v20080118.jar
-os linux
-ws gtk
-arch x86_64
-showsplash
-launcher /home/rgeddes/eclipse/Europa/eclipse/eclipse
-name Eclipse
--launcher.library
/home/rgeddes/eclipse/Europa/eclipse/plugins/org.eclipse.equ inox.launcher.gtk.linux.x86_64_1.0.3.R33x_v20080118/eclipse_ 1023.so
-startup
-exitdata 37000e
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx256m
-jar
I was using java version 1.6 and because of the
'requiredJavaVersion=1.5' messages, tried switching to 1.5 java, but I
get the same results.
Here are some of my system components:
eclipse.buildId=M20080221-1800
eclipse.commands=-os
linux
-ws
gtk
-arch
x86_64
Any hints as to why Eclipse crashes is appreciated
Richard
Re: Eclipse crashes during tutorial [message #256796 is a reply to message #256717] Tue, 20 May 2008 11:30 Go to previous messageGo to next message
Richard Geddes wrote:
Many problems running Eclipse on Linux are due to gcj being the system
default JVM. On your system, what is the result of running java -version
on the executable under /usr/bin/java ?
If you Google "eclipse gcj" you'll find lots of information on the
subject, including a link to this page that tell you how to make sure
Eclipse runs under the Sun JVM: http://wiki.eclipse.org/Eclipse.ini
Hope this helps,
Eric
> /usr/bin/java
> -Xms40m
> -Xmx256m
> -jar
> -os linux
> -ws gtk
> -arch x86_64
> -showsplash
> -name Eclipse
> --launcher.library
> -startup
> -exitdata 37000e
> -vm /usr/bin/java
> -vmargs
> -Xms40m
> -Xmx256m
> -jar
> linux
> -ws
> gtk
> -arch
> x86_64
> Richard
Re: Eclipse crashes during tutorial [message #256800 is a reply to message #256796] Tue, 20 May 2008 15:34 Go to previous messageGo to next message
I'm pretty sure I'm using sun 1.6
$0> java -version
java version "1.6.0_06"
Java(TM) SE Runtime Environment (build 1.6.0_06-b02)
Java HotSpot(TM) 64-Bit Server VM (build 10.0-b22, mixed mode)
R
> Hope this helps,
> Eric
>> /usr/bin/java
>> -Xms40m
>> -Xmx256m
>> -jar
>> -os linux
>> -ws gtk
>> -arch x86_64
>> -showsplash
>> -name Eclipse
>> --launcher.library
>> -startup
>> -exitdata 37000e
>> -vm /usr/bin/java
>> -vmargs
>> -Xms40m
>> -Xmx256m
>> -jar
>> linux
>> -ws
>> gtk
>> -arch
>> x86_64
>> Richard
Re: Eclipse crashes during tutorial [message #256804 is a reply to message #256800] Tue, 20 May 2008 15:58 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
Might be something in here that could help:
http://wiki.eclipse.org/IRC_FAQ
If not, try #eclipse on freenode, and someone in there might be able to
offer assistance.
Nick
> $0> java -version
> R
>>> Hi,
>> -version on the executable under /usr/bin/java ?
>> Hope this helps,
>> Eric
>>> /usr/bin/java
>>> -Xms40m
>>> -Xmx256m
>>> -jar
>>> -os linux
>>> -ws gtk
>>> -arch x86_64
>>> -showsplash
>>> -name Eclipse
>>> --launcher.library
>>> -startup
>>> -exitdata 37000e
>>> -vm /usr/bin/java
>>> -vmargs
>>> -Xms40m
>>> -Xmx256m
>>> -jar
>>> I get the same results.
>>> linux
>>> -ws
>>> gtk
>>> -arch
>>> x86_64
Re: Eclipse crashes during tutorial [message #256808 is a reply to message #256804] Tue, 20 May 2008 19:48 Go to previous message
Thanks for the input... Iĺl give the irc a try. In the meantime, I
discovered that it was the JVM that was being crashed by some native
code call libxul.so... here's a section of the JVM error log:
# SIGSEGV (0xb) at pc=0x00007fd5f6c698b1, pid=9638, tid=1096153424
# Java VM: Java HotSpot(TM) 64-Bit Server VM (10.0-b22 mixed mode
linux-amd64)
# Problematic frame:
# C [libxul.so+0xbd88b1]
Also, I found that the online docs have a different link than the link
in the docs I downloaded. The online docs seem to be ok... I guess the
libxul.so isn't involved... so I'll continue with the tutorial from the
online docs.
R
> offer assistance.
> Nick
>> $0> java -version
>> R
>>>> Hi,
>>> system default JVM. On your system, what is the result of running
>>> java -version on the executable under /usr/bin/java ?
>>> Hope this helps,
>>> Eric
>>>> /usr/bin/java
>>>> -Xms40m
>>>> -Xmx256m
>>>> -jar
>>>> -os linux
>>>> -ws gtk
>>>> -arch x86_64
>>>> -showsplash
>>>> -name Eclipse
>>>> --launcher.library
>>>> -startup
>>>> -exitdata 37000e
>>>> -vm /usr/bin/java
>>>> -vmargs
>>>> -Xms40m
>>>> -Xmx256m
>>>> -jar
>>>> linux
>>>> -ws
>>>> gtk
>>>> -arch
>>>> x86_64
Previous Topic:Local file system explorer in Eclipse Navigator
Next Topic:Accessing db2 from plugin project
Current Time: Sun Nov 23 08:14:55 EST 2025
Powered by FUDForum. Page generated in 0.10124 seconds
