| Export as HTML in birt viewer ? [message #256586] |
Fri, 28 September 2007 12:00  |
--------------080202080403070807040701
Hi all,
When using web viewer, how can i save the produced HTML ?
i can export in PDF,DOC, but no HTML ?
St
| Re: Export as HTML in birt viewer ? [message #256655 is a reply to message #256651] |
Mon, 01 October 2007 10:25   |
Stephane,
You can use the Engine API to do this, but without a code change to the
Viewer I do not see an easy way to export the report as html and save it.
Jason
Stéphane Bouchet wrote:
> thanks, so i understand that there is actually no way to have HTML
> export option in the viewer.
> Jason Weathersby a écrit :
>> Stephane,
>> BIRT 2.2
>> If you use /preview instead of /frameset you should get the produced
>> html, and then you can just save the page.
>> Jason
>>> Hi all,
>>> Thanks,
>>> Stéphane
| Re: Export as HTML in birt viewer ? [message #256715 is a reply to message #256655] |
Tue, 02 October 2007 07:51  |
--------------090703040408010508090004
thanks, i will do like you suggest.
St
FUDForum. Page generated in 0.03788 seconds
