Home » Newcomers » Newcomers » Using command line options for Eclipse methods
Using command line options for Eclipse methods [message #256555] Fri, 16 May 2008 17:22 Go to next message
Originally posted by: tscott.phoeintl.com
Can anyone out there give me pointers on how to execute Eclipse actions
via the command line? I'm working on migrating some automation tools that
currently rely on the Altium/Tasking EDE, over to Eclipse. These tools
simply need to add files to a project, delete files from a project, and
initiate a build. Is this possible without using the Eclipse GUI directly?
Tasking has already implemented the plug-in support for their compiler
toolchain in Eclipse. I just need to know how I can get to portions of it
outside of requiring a user bringing up the Eclipse GUI itself.
Any and all help will be appreciated.
--tim
Re: Using command line options for Eclipse methods [message #256558 is a reply to message #256555] Fri, 16 May 2008 17:34 Go to previous message
Tim,
You'll probably want to find some documentation about running a headless
Eclipse application. Searching the site will likely find it.
> actions via the command line? I'm working on migrating some
> automation tools that currently rely on the Altium/Tasking EDE, over
> to Eclipse. These tools simply need to add files to a project, delete
> files from a project, and initiate a build. Is this possible without
> of it outside of requiring a user bringing up the Eclipse GUI itself.
> --tim
Previous Topic:Generate an application with ALL necessary files
Next Topic:JLabel reference
Current Time: Tue Nov 18 21:31:41 EST 2025
Powered by FUDForum. Page generated in 0.07836 seconds
