Home » Newcomers » Newcomers » JLabel reference
JLabel reference [message #256531] Fri, 16 May 2008 15:32 Go to next message
Originally posted by: web02.comcast.net
I am a newby to VEP. I got it loaded finally and to play, I added a
jButton and a jLabel to the default pane then created a button click event.
The code and some of the auto generated mouse clicked code looks like:
// Globals
private JPanel jContentPane = null;
private JButton jButton = null;
private JLabel jLabel = null;
// Buried in method private "JButton getJButton()"
public void mouseClicked(java.awt.event.MouseEvent e) {
System.out.println("mouseClicked()"); // TODO Auto-generated Event stub
mouseClicked()
jLabel.text="XXX"; // <-- MY CODE
If I try to reference jLabel.text in this method I get an error stating
"jLabel.texr is not visible".
Can someone explain what is happening here. I do not see a scope problem,
but obviously something is happening that I don't understand.
Thanx,
Bill
Re: JLabel reference [message #256535 is a reply to message #256531] Fri, 16 May 2008 16:43 Go to previous messageGo to next message
The "text" field is private. You can't access it outside of the class
itself.
Use the getText() and setText(String) methods instead.
HTH,
Wayne
> // Globals
> mouseClicked()
> Thanx,
> Bill
Re: JLabel reference [message #256539 is a reply to message #256535] Fri, 16 May 2008 16:53 Go to previous messageGo to next message
Thanks, I tried it and that error went away. Now, I am getting:
jLabel.setText cannot be resolved or is not a field.
The variable is the correct name. It appears to be in scope.
Re: JLabel reference [message #256547 is a reply to message #256539] Fri, 16 May 2008 16:58 Go to previous messageGo to next message
Thanks for your help. I got it.
For some reason. if I enter "jlabel.", I don't get the available method
list.
Re: JLabel reference [message #256551 is a reply to message #256547] Fri, 16 May 2008 17:14 Go to previous messageGo to next message
jlabel isn't defined. I think you mean jLabel. Java is case-sensitive.
After you type "jlabel", hit ctrl-space. Content assist will correct it
for you.
Wayne
> list.
Re: JLabel reference [message #256561 is a reply to message #256539] Fri, 16 May 2008 17:59 Go to previous message
setText is not a field. it's a method. You need the parens. It's a Java
thing.
jLabel.setText("Hello there");
HTH,
Wayne
Previous Topic:Using command line options for Eclipse methods
Next Topic:Trigonometry
Current Time: Wed Nov 12 08:49:26 EST 2025
Powered by FUDForum. Page generated in 0.09245 seconds
