Home » Archived » BIRT » sum of the datasets
sum of the datasets [message #256521] Fri, 28 September 2007 10:14 Go to next message
Originally posted by: adnane.ben-youssef.ext.eurocontrol.int
from my question you can get conclude that I'm new in birt reporting :)
- I have a jdbc datasources.
- I have 2 Datasets D1, D2, having one column each
- I want to have C(D1) / C(D2)
Any idea?
A
Re: sum of the datasets [message #256536 is a reply to message #256521] Fri, 28 September 2007 10:45 Go to previous messageGo to next message
Hi Adnane,
Have you tried creating a third data set... of type Joint Data Set?
Virgil Dodson
http://www.birt-exchange.com
Adnane wrote:
> Hello,
> Any idea?
> A
Re: sum of the datasets [message #256544 is a reply to message #256536] Fri, 28 September 2007 11:11 Go to previous messageGo to next message
Hi Vigil,
thanks for your reply.
but, I do not need Joint data set since it require to chose between join
types...
well I want to know if it s possible in scripped data set to access to
the oda ones
I tried row._outer["mycolon1"] / row._outer["mycolon2"] and this do not
work!!
A
Virgil Dodson wrote:
> Hi Adnane,
> Virgil Dodson
> Adnane wrote:
>> Hello,
>> Any idea?
>> A
Re: sum of the datasets [message #256552 is a reply to message #256544] Fri, 28 September 2007 11:25 Go to previous messageGo to next message
Originally posted by: vdodson.kc.rr.com
I guess I don't really understand. Can you be a little more clear on
what is in dataset1, dataset2, and what output you expect?
Virgil Dodson
Adnane wrote:
> Hi Vigil,
> types...
> the oda ones
> work!!
> A
>> Hi Adnane,
>> Virgil Dodson
>> Adnane wrote:
>>> Hello,
>>> Any idea?
>>> A
Re: sum of the datasets [message #256559 is a reply to message #256544] Fri, 28 September 2007 11:27 Go to previous messageGo to next message
Adnane,
You need to do this at the table level. Take a look at this example.
It shows doing it 2 different ways. This first uses two separate table
and the onCreate script for the aggregation control. The second
approach uses nested tables using an outer inner table approach.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build &lt;2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="ds1" id="7">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails
where productcode like 'S18%'</property>
</oda-data-set>
<oda-data-set
name="ds2" id="8">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orderdetails
where productcode like 'S10%'</property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="width">100%</property>
<property name="dataSet">ds1</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
<structure>
<property name="name">Aggregation</property>
<expression
<property name="dataType">any</property>
<property name="aggregateFunction">sum</property>
</structure>
</list-property>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="10">
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr">true</expression>
</structure>
</list-property>
<cell id="11">
<label id="12">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="13">
<label id="14">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="15">
<label id="16">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="21">
<structure>
</structure>
</list-property>
<cell id="22">
<data id="23">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="24">
<data id="25">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="26">
<data id="27">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="28">
<data id="29">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="30">
<data id="31">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="32">
<cell id="33"/>
<cell id="34"/>
<cell id="35">
<data id="77">
<method name="onCreate"><![CDATA[ds1 =
this.getValue();]]></method>
<property
name="resultSetColumn">Aggregation</property>
</data>
</cell>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
<table id="43">
<property name="dataSet">ds2</property>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
</list-property>
<column id="72"/>
<column id="73"/>
<column id="74"/>
<column id="75"/>
<column id="76"/>
<header>
<row id="44">
<structure>
</structure>
</list-property>
<cell id="45">
<label id="46">
<text-property
</label>
</cell>
<cell id="47">
<label id="48">
<text-property
</label>
</cell>
<cell id="49">
<label id="50">
<text-property
</label>
</cell>
<cell id="51">
<label id="52">
<text-property
</label>
</cell>
<cell id="53">
<label id="54">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="55">
<structure>
</structure>
</list-property>
<cell id="56">
<data id="57">
<property
</data>
</cell>
<cell id="58">
<data id="59">
<property
</data>
</cell>
<cell id="60">
<data id="61">
<property
</data>
</cell>
<cell id="62">
<data id="63">
<property
</data>
</cell>
<cell id="64">
<data id="65">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="66">
<cell id="67"/>
<cell id="68"/>
<cell id="69">
<data id="78">
<method name="onCreate"><![CDATA[ds2 =
<property
</data>
</cell>
<cell id="70"/>
<cell id="71"/>
</row>
</footer>
</table>
<data id="80">
<structure>
<property name="name">ds1and2</property>
<expression name="expression">ds1/ds2</expression>
<property name="dataType">decimal</property>
</structure>
</list-property>
<property name="resultSetColumn">ds1and2</property>
</data>
<table name="outertable" id="81">
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
</list-property>
<column id="94"/>
<column id="95"/>
<column id="96"/>
<header>
<row id="82">
<structure>
</structure>
</list-property>
<cell id="83"/>
<cell id="84"/>
<cell id="85"/>
</row>
</header>
<detail>
<row id="86">
<structure>
</structure>
</list-property>
<cell id="87"/>
<cell id="88"/>
<cell id="89"/>
</row>
</detail>
<footer>
<row id="90">
<cell id="91"/>
<cell id="92">
<data id="114">
<property
</data>
</cell>
<cell id="93">
<table name="innertable" id="97">
<structure>
<property
<expression
<property
</structure>
<structure>
<property
<expression
<property
</structure>
<structure>
<property
<expression
<property
</structure>
<structure>
<property
<expression
<property
</structure>
<structure>
<property
<expression
<property
</structure>
<structure>
<property
<expression
<property
<property
</structure>
<structure>
<property name="name">Column
Binding</property>
<expression
name="expression">row._outer["Aggregation"]/row["Aggregation "]</expression>
<property
</structure>
</list-property>
<column id="110"/>
<column id="111"/>
<column id="112"/>
<header>
<row id="98">
<cell id="99"/>
<cell id="100"/>
<cell id="101"/>
</row>
</header>
<detail>
<row id="102">
<cell id="103"/>
<cell id="104"/>
<cell id="105"/>
</row>
</detail>
<footer>
<row id="106">
<cell id="107"/>
<cell id="108">
<data id="113">
<property
</data>
</cell>
<cell id="109">
<data id="117">
<property
name="resultSetColumn">Column Binding</property>
</data>
</cell>
</row>
</footer>
</table>
</cell>
</row>
</footer>
</table>
</body>
</report>
Adnane wrote:
> Hi Vigil,
> types...
> the oda ones
> work!!
> A
>> Hi Adnane,
>> Virgil Dodson
>> Adnane wrote:
>>> Hello,
>>> Any idea?
>>> A
Re: sum of the datasets [message #256567 is a reply to message #256521] Fri, 28 September 2007 11:25 Go to previous messageGo to next message
Why not do a select on the two columns when you write your query, so you
can have the two columns in the same dataset?
David
"Adnane" <adnane.ben-youssef.ext@eurocontrol.int> wrote in message
news:fdj28r$23m$1@build.eclipse.org...
> Hello,
> Any idea?
> A
Re: sum of the datasets [message #256574 is a reply to message #256552] Fri, 28 September 2007 11:38 Go to previous messageGo to next message
Well
I have a JDBC dataSource.
I have tow dataset. Each one get a count from a different table.
I need to have the percent of count 1 over count 2.
how to do it?!
A
> Virgil Dodson
> Adnane wrote:
>> Hi Vigil,
>> join types...
>> the oda ones
>> not work!!
>> A
>>> Hi Adnane,
>>> Virgil Dodson
>>> Adnane wrote:
>>>> Hello,
>>>> Any idea?
>>>> A
Re: sum of the datasets [message #256594 is a reply to message #256559] Fri, 28 September 2007 12:27 Go to previous messageGo to next message
Ok, I've got it.
In fact it's the onCreate event of my datasets where I've had to catch
the values!
Birt is nice!
Adnane.
Jason Weathersby wrote:
> Adnane,
> Jason
> id="1">
> <data-sources>
> <oda-data-source
> id="6">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> name="ds1" id="7">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> </oda-data-set>
> <oda-data-set
> name="ds2" id="8">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> <text-property name="content"><![CDATA[<value-of>new
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="38"/>
> <column id="39"/>
> <column id="40"/>
> <column id="41"/>
> <column id="42"/>
> <header>
> <row id="10">
> <structure>
> </structure>
> </list-property>
> <cell id="11">
> <label id="12">
> <text-property
> </label>
> </cell>
> <cell id="13">
> <label id="14">
> <text-property
> </label>
> </cell>
> <cell id="15">
> <label id="16">
> <text-property
> </label>
> </cell>
> <cell id="17">
> <label id="18">
> <text-property
> </label>
> </cell>
> <cell id="19">
> <label id="20">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="21">
> <structure>
> </structure>
> </list-property>
> <cell id="22">
> <data id="23">
> <property
> </data>
> </cell>
> <cell id="24">
> <data id="25">
> <property
> </data>
> </cell>
> <cell id="26">
> <data id="27">
> <property
> </data>
> </cell>
> <cell id="28">
> <data id="29">
> <property
> </data>
> </cell>
> <cell id="30">
> <data id="31">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="32">
> <cell id="33"/>
> <cell id="34"/>
> <cell id="35">
> <data id="77">
> <property
> </data>
> </cell>
> <cell id="36"/>
> <cell id="37"/>
> </row>
> </footer>
> </table>
> <table id="43">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="72"/>
> <column id="73"/>
> <column id="74"/>
> <column id="75"/>
> <column id="76"/>
> <header>
> <row id="44">
> <structure>
> </structure>
> </list-property>
> <cell id="45">
> <label id="46">
> <text-property
> </label>
> </cell>
> <cell id="47">
> <label id="48">
> <text-property
> </label>
> </cell>
> <cell id="49">
> <label id="50">
> <text-property
> </label>
> </cell>
> <cell id="51">
> <label id="52">
> <text-property
> </label>
> </cell>
> <cell id="53">
> <label id="54">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="55">
> <structure>
> </structure>
> </list-property>
> <cell id="56">
> <data id="57">
> <property
> </data>
> </cell>
> <cell id="58">
> <data id="59">
> <property
> </data>
> </cell>
> <cell id="60">
> <data id="61">
> <property
> </data>
> </cell>
> <cell id="62">
> <data id="63">
> <property
> </data>
> </cell>
> <cell id="64">
> <data id="65">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="66">
> <cell id="67"/>
> <cell id="68"/>
> <cell id="69">
> <data id="78">
> <property
> </data>
> </cell>
> <cell id="70"/>
> <cell id="71"/>
> </row>
> </footer>
> </table>
> <data id="80">
> <structure>
> </structure>
> </list-property>
> </data>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="94"/>
> <column id="95"/>
> <column id="96"/>
> <header>
> <row id="82">
> <structure>
> </structure>
> </list-property>
> <cell id="83"/>
> <cell id="84"/>
> <cell id="85"/>
> </row>
> </header>
> <detail>
> <row id="86">
> <structure>
> </structure>
> </list-property>
> <cell id="87"/>
> <cell id="88"/>
> <cell id="89"/>
> </row>
> </detail>
> <footer>
> <row id="90">
> <cell id="91"/>
> <cell id="92">
> <data id="114">
> <property
> </data>
> </cell>
> <cell id="93">
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> <property
> </structure>
> <structure>
> Binding</property>
> <expression
> <property
> </structure>
> </list-property>
> <column id="110"/>
> <column id="111"/>
> <column id="112"/>
> <header>
> <row id="98">
> <cell id="99"/>
> <cell id="100"/>
> <cell id="101"/>
> </row>
> </header>
> <detail>
> <row id="102">
> <cell id="103"/>
> <cell id="104"/>
> <cell id="105"/>
> </row>
> </detail>
> <footer>
> <row id="106">
> <cell id="107"/>
> <cell id="108">
> <data id="113">
> <property
> </data>
> </cell>
> <cell id="109">
> <data id="117">
> <property
> </data>
> </cell>
> </row>
> </footer>
> </table>
> </cell>
> </row>
> </footer>
> </table>
> </body>
> </report>
> Adnane wrote:
>> Hi Vigil,
>> join types...
>> the oda ones
>> not work!!
>> A
>>> Hi Adnane,
>>> Virgil Dodson
>>> Adnane wrote:
>>>> Hello,
>>>> Any idea?
>>>> A
Re: sum of the datasets [message #256643 is a reply to message #256559] Sun, 30 September 2007 07:23 Go to previous message
You can even do it without using 2 separate tables or using nested
tables. It can be done in one single table (if you don't mind that this
table isn't bound to specific Dataset) and 2 DataElement's, each bound
to its appropriate DataSet. This approach is useful if you have a lot of
data from a lot of datasets that you want to join in just one
table(without nesting, joined datasets, etc.) Here's an example:
http://e-prostor.com/birt/samples/2datasets.rptdesign
Alex
Jason Weathersby pravi:
> Adnane,
> Jason
> id="1">
> <data-sources>
> <oda-data-source
> id="6">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> name="ds1" id="7">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> </oda-data-set>
> <oda-data-set
> name="ds2" id="8">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="38"/>
> <column id="39"/>
> <column id="40"/>
> <column id="41"/>
> <column id="42"/>
> <header>
> <row id="10">
> <structure>
> </structure>
> </list-property>
> <cell id="11">
> <label id="12">
> <text-property
> </label>
> </cell>
> <cell id="13">
> <label id="14">
> <text-property
> </label>
> </cell>
> <cell id="15">
> <label id="16">
> <text-property
> </label>
> </cell>
> <cell id="17">
> <label id="18">
> <text-property
> </label>
> </cell>
> <cell id="19">
> <label id="20">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="21">
> <structure>
> </structure>
> </list-property>
> <cell id="22">
> <data id="23">
> <property
> </data>
> </cell>
> <cell id="24">
> <data id="25">
> <property
> </data>
> </cell>
> <cell id="26">
> <data id="27">
> <property
> </data>
> </cell>
> <cell id="28">
> <data id="29">
> <property
> </data>
> </cell>
> <cell id="30">
> <data id="31">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="32">
> <cell id="33"/>
> <cell id="34"/>
> <cell id="35">
> <data id="77">
> <property
> </data>
> </cell>
> <cell id="36"/>
> <cell id="37"/>
> </row>
> </footer>
> </table>
> <table id="43">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="72"/>
> <column id="73"/>
> <column id="74"/>
> <column id="75"/>
> <column id="76"/>
> <header>
> <row id="44">
> <structure>
> </structure>
> </list-property>
> <cell id="45">
> <label id="46">
> <text-property
> </label>
> </cell>
> <cell id="47">
> <label id="48">
> <text-property
> </label>
> </cell>
> <cell id="49">
> <label id="50">
> <text-property
> </label>
> </cell>
> <cell id="51">
> <label id="52">
> <text-property
> </label>
> </cell>
> <cell id="53">
> <label id="54">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="55">
> <structure>
> </structure>
> </list-property>
> <cell id="56">
> <data id="57">
> <property
> </data>
> </cell>
> <cell id="58">
> <data id="59">
> <property
> </data>
> </cell>
> <cell id="60">
> <data id="61">
> <property
> </data>
> </cell>
> <cell id="62">
> <data id="63">
> <property
> </data>
> </cell>
> <cell id="64">
> <data id="65">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="66">
> <cell id="67"/>
> <cell id="68"/>
> <cell id="69">
> <data id="78">
> <property
> </data>
> </cell>
> <cell id="70"/>
> <cell id="71"/>
> </row>
> </footer>
> </table>
> <data id="80">
> <structure>
> </structure>
> </list-property>
> </data>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="94"/>
> <column id="95"/>
> <column id="96"/>
> <header>
> <row id="82">
> <structure>
> </structure>
> </list-property>
> <cell id="83"/>
> <cell id="84"/>
> <cell id="85"/>
> </row>
> </header>
> <detail>
> <row id="86">
> <structure>
> </structure>
> </list-property>
> <cell id="87"/>
> <cell id="88"/>
> <cell id="89"/>
> </row>
> </detail>
> <footer>
> <row id="90">
> <cell id="91"/>
> <cell id="92">
> <data id="114">
> <property
> </data>
> </cell>
> <cell id="93">
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> <property
> </structure>
> <structure>
> Binding</property>
> <expression
> <property
> </structure>
> </list-property>
> <column id="110"/>
> <column id="111"/>
> <column id="112"/>
> <header>
> <row id="98">
> <cell id="99"/>
> <cell id="100"/>
> <cell id="101"/>
> </row>
> </header>
> <detail>
> <row id="102">
> <cell id="103"/>
> <cell id="104"/>
> <cell id="105"/>
> </row>
> </detail>
> <footer>
> <row id="106">
> <cell id="107"/>
> <cell id="108">
> <data id="113">
> <property
> </data>
> </cell>
> <cell id="109">
> <data id="117">
> <property
> </data>
> </cell>
> </row>
> </footer>
> </table>
> </cell>
> </row>
> </footer>
> </table>
> </body>
> </report>
> Adnane wrote:
>> Hi Vigil,
>> join types...
>> the oda ones
>> not work!!
>> A
>>> Hi Adnane,
>>> Virgil Dodson
>>> Adnane wrote:
>>>> Hello,
>>>> Any idea?
>>>> A
Previous Topic:How to append values to a linechart
Next Topic:Taglib starts and shuts down engine every time
Current Time: Sun Nov 16 09:09:17 EST 2025
Powered by FUDForum. Page generated in 0.30532 seconds
