Linked CSS styles and relative path [message #256480] |
Thu, 27 September 2007 14:40  |
I'm using linked CSS as described in the Styles Revisited post on BIRT
World. Works great in the report designer. When I try to run my report,
though, my styles disappear.
I gather from this thread:
< http://dev.eclipse.org/newslists/news.eclipse.birt/msg20240. html> that
I need to set the resource path for the engine config. The sample code
provided from Jason uses an absolute path, though, and my CSS file and
report are embedded in an Eclipse plugin.
Can I use a relative path here? (And relative to what?) Or a platform
URL or some-such? I'm having trouble finding where to put a breakpoint
to figure out how the path is evaluated.
Jeff
Re: Linked CSS styles and relative path [message #256602 is a reply to message #256578] |
Fri, 28 September 2007 12:59   |
Jeff,
If your resources are in a plugin, can you use something like:
Bundle bundle =
org.eclipse.core.runtime.Platform.getBundle("my.resource.plugin ");
config.setResourcePath(config.bundle.getEntry("pathinplugin "));
Jason
Jeff Ramsdale wrote:
> Jason,
> I'm using the engine API. Since my styles don't show up but neither do I
> get any exceptions I'm wondering where the path gets resolved and how I
> determine why it didn't work. For instance, if I use a relative path how
> do I tell what it's resolved against?
> Jeff
> Jason Weathersby wrote:
>> Jeff,
>> Are you using the WebViewer or the engine API?
>> If you are using the Web Viewer look at the web.xml there is a setting
>> for resource path, which can be set relative to the context. If you
>> are using the engine API you should be able to set to wherever you want.
>> Jason
>>> BIRT World. Works great in the report designer. When I try to run my
>>> report, though, my styles disappear.
>>> that I need to set the resource path for the engine config. The
>>> sample code provided from Jason uses an absolute path, though, and my
>>> CSS file and report are embedded in an Eclipse plugin.
>>> breakpoint to figure out how the path is evaluated.
>>> Jeff
Re: Linked CSS styles and relative path [message #256606 is a reply to message #256602] |
Fri, 28 September 2007 13:27  |
Huh. I was pretty certain I'd tried that, unsuccessfully. Tried again,
though and worked perfectly! (Minor correction--you get a URL from
getEntry and have to do toExternalForm()...)
Thanks!
-Jeff
> Jeff,
> Bundle bundle =
> Jason
>> Jason,
>> I get any exceptions I'm wondering where the path gets resolved and
>> how I determine why it didn't work. For instance, if I use a relative
>> path how do I tell what it's resolved against?
>> Jeff
FUDForum. Page generated in 0.04557 seconds
