Home » Archived » BIRT » Linked CSS styles and relative path
Linked CSS styles and relative path [message #256480] Thu, 27 September 2007 14:40 Go to next message
I'm using linked CSS as described in the Styles Revisited post on BIRT
World. Works great in the report designer. When I try to run my report,
though, my styles disappear.
I gather from this thread:
< http://dev.eclipse.org/newslists/news.eclipse.birt/msg20240. html> that
I need to set the resource path for the engine config. The sample code
provided from Jason uses an absolute path, though, and my CSS file and
report are embedded in an Eclipse plugin.
Can I use a relative path here? (And relative to what?) Or a platform
URL or some-such? I'm having trouble finding where to put a breakpoint
to figure out how the path is evaluated.
Jeff
Re: Linked CSS styles and relative path [message #256571 is a reply to message #256480] Fri, 28 September 2007 11:35 Go to previous messageGo to next message
Jeff,
Are you using the WebViewer or the engine API?
If you are using the Web Viewer look at the web.xml there is a setting
for resource path, which can be set relative to the context. If you are
using the engine API you should be able to set to wherever you want.
Jason
> Jeff
Re: Linked CSS styles and relative path [message #256578 is a reply to message #256571] Fri, 28 September 2007 11:46 Go to previous messageGo to next message
Jason,
I'm using the engine API. Since my styles don't show up but neither do I
get any exceptions I'm wondering where the path gets resolved and how I
determine why it didn't work. For instance, if I use a relative path how
do I tell what it's resolved against?
Jeff
Jason Weathersby wrote:
> Jeff,
> Jason
>> report, though, my styles disappear.
>> that I need to set the resource path for the engine config. The sample
>> code provided from Jason uses an absolute path, though, and my CSS
>> file and report are embedded in an Eclipse plugin.
>> Jeff
Re: Linked CSS styles and relative path [message #256602 is a reply to message #256578] Fri, 28 September 2007 12:59 Go to previous messageGo to next message
Jeff,
If your resources are in a plugin, can you use something like:
Bundle bundle =
org.eclipse.core.runtime.Platform.getBundle("my.resource.plugin ");
config.setResourcePath(config.bundle.getEntry("pathinplugin "));
Jason
> Jason,
> Jeff
>> Jeff,
>> are using the engine API you should be able to set to wherever you want.
>> Jason
>>> BIRT World. Works great in the report designer. When I try to run my
>>> sample code provided from Jason uses an absolute path, though, and my
>>> CSS file and report are embedded in an Eclipse plugin.
>>> breakpoint to figure out how the path is evaluated.
>>> Jeff
Re: Linked CSS styles and relative path [message #256606 is a reply to message #256602] Fri, 28 September 2007 13:27 Go to previous message
Huh. I was pretty certain I'd tried that, unsuccessfully. Tried again,
though and worked perfectly! (Minor correction--you get a URL from
getEntry and have to do toExternalForm()...)
Thanks!
-Jeff
> Jeff,
> Bundle bundle =
> Jason
>> Jason,
>> I get any exceptions I'm wondering where the path gets resolved and
>> how I determine why it didn't work. For instance, if I use a relative
>> path how do I tell what it's resolved against?
>> Jeff
Previous Topic:Websphere Memory utilization is HIGH (URGENT)
Next Topic:QT4 and Birt
Current Time: Sun Nov 09 03:56:10 EST 2025
Powered by FUDForum. Page generated in 0.05279 seconds
