| suddenly all java files get IncompatibleClassChangeError [message #256476] |
Wed, 17 September 2008 08:45  |
Originally posted by: ekkehard.gentz-software.de
suddenly I'm getting for all java files in workspace
if I try to open the file in java editor or click on a java file in
PackageExplorer
restarted eclipse with -clean
rebooted
nothing helps
hopefully someone has an idea
thx
ekke
Ganymede, OSX 10.5.5, JDK 1.5
java.lang.IncompatibleClassChangeError
org.eclipse.jdt.internal.ui.JavaElementAdapterFactory.getRes ource(JavaElementAdapterFactory.java:124)
org.eclipse.jdt.internal.ui.JavaElementAdapterFactory.getAda pter(JavaElementAdapterFactory.java:89)
org.eclipse.core.internal.adapter.AdapterFactoryProxy.getAda pter(AdapterFactoryProxy.java:80)
org.eclipse.core.internal.runtime.AdapterManager.getAdapter( AdapterManager.java:291)
org.eclipse.core.runtime.PlatformObject.getAdapter(PlatformO bject.java:66)
at org.eclipse.team.internal.ui.Utils.getResource(Utils.java:87 5)
org.eclipse.team.internal.ccvs.ui.CVSLightweightDecorator.ge tResource(CVSLightweightDecorator.java:180)
org.eclipse.team.internal.ccvs.ui.CVSLightweightDecorator.de corate(CVSLightweightDecorator.java:139)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:263)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 72)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:356)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:338)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:374)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:334)
at org.eclipse.ui.ide.ResourceUtil.getAdapter(ResourceUtil.java :257)
at org.eclipse.ui.ide.ResourceUtil.getResource(ResourceUtil.jav a:132)
org.eclipse.ui.internal.ide.actions.BuildUtilities.extractPr ojects(BuildUtilities.java:52)
org.eclipse.ui.internal.ide.actions.BuildUtilities.findSelec tedProjects(BuildUtilities.java:81)
at org.eclipse.ui.actions.BuildAction.isEnabled(BuildAction.jav a:231)
org.eclipse.jface.commands.ActionHandler.isEnabled(ActionHan dler.java:141)
at org.eclipse.core.commands.Command.isEnabled(Command.java:833 )
at org.eclipse.core.commands.Command.setHandler(Command.java:96 5)
org.eclipse.ui.internal.handlers.HandlerAuthority.updateComm and(HandlerAuthority.java:459)
org.eclipse.ui.internal.handlers.HandlerAuthority.processCha ngedCommands(HandlerAuthority.java:636)
org.eclipse.ui.internal.handlers.HandlerAuthority.access$1(H andlerAuthority.java:610)
org.eclipse.ui.internal.handlers.HandlerAuthority$1.property Change(HandlerAuthority.java:175)
org.eclipse.ui.internal.services.EvaluationAuthority$1.run(E valuationAuthority.java:252)
org.eclipse.ui.internal.services.EvaluationAuthority.fireSer viceChange(EvaluationAuthority.java:246)
org.eclipse.ui.internal.services.EvaluationAuthority.endSour ceChange(EvaluationAuthority.java:197)
org.eclipse.ui.internal.services.EvaluationAuthority.sourceC hanged(EvaluationAuthority.java:135)
org.eclipse.ui.internal.services.ExpressionAuthority.sourceC hanged(ExpressionAuthority.java:310)
org.eclipse.ui.internal.services.ExpressionAuthority.sourceC hanged(ExpressionAuthority.java:289)
org.eclipse.ui.AbstractSourceProvider.fireSourceChanged(Abst ractSourceProvider.java:99)
org.eclipse.ui.internal.services.ActiveShellSourceProvider.a ccess$13(ActiveShellSourceProvider.java:1)
org.eclipse.ui.internal.services.ActiveShellSourceProvider$3 .handleEvent(ActiveShellSourceProvider.java:302)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:113 0)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1560)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1585)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1566)
at org.eclipse.swt.widgets.Shell.kEventWindowActivated(Shell.ja va:1002)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:2035)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4163 )
at org.eclipse.swt.internal.carbon.OS.CallNextEventHandler(Nati ve Method)
at org.eclipse.swt.widgets.Tree.kEventMouseDown(Tree.java:2599)
at org.eclipse.swt.widgets.Widget.mouseProc(Widget.java:1326)
at org.eclipse.swt.widgets.Display.mouseProc(Display.java:2925)
at org.eclipse.swt.internal.carbon.OS.SendEventToEventTarget(Na tive Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3047)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
FUDForum. Page generated in 0.04537 seconds
