Home » Newcomers » Newcomers » JRE not compatible with workspace .class file compatibility
JRE not compatible with workspace .class file compatibility [message #256470] Thu, 15 May 2008 16:40 Go to next message
Originally posted by: alfredo.ramos.networksolutions.com
I am loading up a project into Eclipse. I use jre1.5.0_09 - I don't have
any other JREs installed on my laptop. I can run the project fine from
command line, but when I try to run it from Eclipse by doing Run As->Open
Run Dialog and filling out the info... It says:
[JRE]: JRE not compatible with workspace .class file compatibility: 1.6
The odd part is that this works fine when run from command line. Any hint?
Thank you
Re: JRE not compatible with workspace .class file compatibility [message #256475 is a reply to message #256470] Thu, 15 May 2008 17:42 Go to previous messageGo to next message
Alfredo,
If you look in Window->Preferences->Java->Installed JREs, is the one
you're expecting actually there? Were these .class files produced by
Eclipse? In Eclipse you'd want to set our source compatibility in the
preferences to be 1.5...
> have any other JREs installed on my laptop. I can run the project fine
> from command line, but when I try to run it from Eclipse by doing Run
> As->Open Run Dialog and filling out the info... It says:
> hint?
> Thank you
Re: JRE not compatible with workspace .class file compatibility [message #256498 is a reply to message #256475] Fri, 16 May 2008 10:15 Go to previous messageGo to next message
I went to Window -> Preferences -> Java -> Installed JREs: the only JRE
listed there was jre1.5.0__09. That said, Under Java -> Compiler, the
"Compiler compliance level" was set to 6.0 and I switched it to 5.0 - that
got rid of the error message.
Thank you :)
Re: JRE not compatible with workspace .class file compatibility [message #257704 is a reply to message #256470] Thu, 05 June 2008 14:15 Go to previous messageGo to next message
Originally posted by: jaywalkersys.kkkkkk.com
Hi!
Go to Window > Preferences > Java > Compiler and change the "Compiler
compliance level" to 5.0 and try again...
Maybe your project workspace had been sailing over the Java 1.6 seas
before you started working, even in another station...
Good luck and be happy!
Silvio
Re: JRE not compatible with workspace .class file compatibility [message #892564 is a reply to message #256470] Thu, 28 June 2012 11:57 Go to previous message
Basically You have installed two java versions in your machine.
and you have created the project with the version which is not default. So in the project properties, under JAVA compiler change the version to ur jdk version
This will solve your problem.
Let me know if you need more info
Previous Topic:Missing Build Path menu item in context menu
Next Topic:"Raw Type" Problem
Current Time: Fri Nov 28 15:21:42 EST 2025
Powered by FUDForum. Page generated in 0.09409 seconds
