Home » Language IDEs » Java Development Tools (JDT) » generated build.xml without hardcoded path
generated build.xml without hardcoded path [message #256395] Mon, 15 September 2008 12:05 Go to next message
Hello
I browsed through the email but didn't find similar topic, so here is my
question.
When I generate a build.xml through "eclipse-> export -> ant buildfiles"
it always includ a harcoded ECLIPSE_HOME path and also external jar full
path.
Is there a way in the settings of the java project to not have hardcoded
path and instead use the full power of <property environment="env"/> that
is anyway put in the build.xml but never used ?
When people does not have exactly the same eclipse path, or jar
installation, it is a bit hard to share the same build.xml over a version
control system if it has hard coded path.
Thanks for your help and tips
regards
lg
Re: generated build.xml without hardcoded path [message #256596 is a reply to message #256395] Tue, 23 September 2008 11:28 Go to previous message
Hello
Is it something that is not possible to achieve in Eclipse ?
regards
lg
Previous Topic:Eclipse 3.5 draft plans
Next Topic:Modifying the Eclipse Java Compiler/Grammar
Current Time: Sat Nov 08 16:26:59 EST 2025
Powered by FUDForum. Page generated in 0.03815 seconds
